I am adding a Chronodot to my project. I looked up various libraries and found one that seemed simple, but when I try to run the basic test I get a compile error which I don't understand, i.e. I don't understand struct declarations well enough to know what I should do to fix it.
Chronodot RTC;
void setup () {
Serial.println("Initializing Chronodot.");
Wire.begin();
RTC.begin();
I get the compile error on the RTC.begin function:
request for member 'begin' in '1074666080u', which is of pointer type 'Rtc*' (maybe you meant to use '->' ?)
So, taking a hint, I tried changing the code to read RTC->begin. But that didn't make it happy.
It then complained : struct Rtc has no member named 'begin'.
I poked around a bit in the source and found no instances of "Rtc". Where is this mixed-case name coming from I wonder.
So hmmm. This is a bit beyond me. Just try another library? Or is this a Well Known Gotcha that can be fixed with one or two edits?
(a few minutes later) wow, I get the same error message with a different library for the Chronodot. More googling required...
http://forum.arduino.cc/index.php?topic=285059.0
OK. This I think I can do. But can't I delete this post which has become irrelevant?
