Hello,
I am having an issue adding a couple new webpage entries to my
sketch due to a " call of overloaded 'append(long unsigned int&)' is ambiguous" compile error. I am unsure if this is a quirk with the ESP32 being used because I can use the Stackstring function with these various integer types on a UNO Wifi Rev2 with no compile error. I have tried assigning different integer types but so far nothing is accepted compiling the ESP32 code.
Compiler error message:
WARNING: library StackString claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8J\Pump_House_Monitor_ver8J.ino: In function 'void loop()':
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8J\Pump_House_Monitor_ver8J.ino:335:48: error: call of overloaded 'append(long unsigned int&)' is ambiguous
In file included from C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8J\hashtag_includes.h:6,
from C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8J\Pump_House_Monitor_ver8J.ino:17:
c:\Users\Ed\IDE 2.0 Sketches-Libraries\libraries\StackString\src/StackString.hpp:83:6: note: candidate: 'void Stack::StackString<LENGTH>::append(char) [with int LENGTH = 50]'
void StackString<LENGTH>::append(const char character)
c:\Users\Ed\IDE 2.0 Sketches-Libraries\libraries\StackString\src/StackString.hpp:92:6: note: candidate: 'void Stack::StackString<LENGTH>::append(int) [with int LENGTH = 50]'
void StackString<LENGTH>::append(int number)
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8J\Pump_House_Monitor_ver8J.ino:340:48: error: call of overloaded 'append(long unsigned int&)' is ambiguous
Multiple libraries were found for "WiFi.h"
Used: C:\Users\Ed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9\libraries\WiFi
Not used: C:\Users\Ed\IDE 2.0 Sketches-Libraries\libraries\WiFiNINA
exit status 1
Compilation error: call of overloaded 'append(long unsigned int&)' is ambiguous
It is the lines with "current_pump_cycle_sec" & "current_pump_cycle_min" that is
generating the error. I am using signed and unsigned long in the UNO sketch that compiles w/o an error.
ESP32 Sketch code:
if (c == '\n') // && currentLineIsBlank)
client.println();
client.println();
StackString<50> AString = StackString<50>(" Pump House");
client.println(AString.c_str());
StackString<50> BString = StackString<50>(" **********");
client.println(BString.c_str());
client.println();
client.println();
StackString<50> HString = StackString<50>(" Pump Status = ");
HString.append(Pump_Status);
client.println(HString.c_str());
client.println();
StackString<50> KString = StackString<50>(" Current Pump Cycle [seconds] = ");
KString.append(current_pump_cycle_sec);
client.println(KString.c_str());
client.println();
client.println();
StackString<50> LString = StackString<50>(" Current Pump Cycle [minutes] = ");
LString.append(current_pump_cycle_min);
client.println(LString.c_str());
client.println();
client.println();
StackString<50> CString = StackString<50>(" Pump House Temp = ");
CString.append(sp_temp_1);
client.println(CString.c_str());
client.println();
client.println();
StackString<50> IString = StackString<50>(" Building Alarm = ");
IString.append(Bldg_Alarm);
client.println(IString.c_str());
client.println();
client.println();
StackString<50> JString = StackString<50>(" Audible Alarm/Pump Shutdown = ");
JString.append(Alm_Relay);
client.println(JString.c_str());
client.println();
client.println();
StackString<50> DString = StackString<50>(" Temp Alarm Setpoint = ");
DString.append(Low_Tmp_Alm);
client.println(DString.c_str());
client.println();
client.println();
StackString<50> EString = StackString<50>(" Low Temp Alarm = ");
EString.append(Temp_Alm);
client.println(EString.c_str());
client.println();
client.println();
StackString<50> FString = StackString<50>(" Low Pressure Alarm = ");
FString.append(Pressure_Alm);
client.println(FString.c_str());
client.println();
client.println();
StackString<50> GString = StackString<50>(" Pump Runtime Alarm = ");
GString.append(Pump_Alm);
client.println(GString.c_str());
From ESP32 defintion file constants.h:
static uint32_t max_pump_runtime = 600000; // 10 minutes maximum run time before an alarm
unsigned long current_pump_cycle = 0;
unsigned long current_pump_cycle_sec = 0;
unsigned long current_pump_cycle_min = 0;
unsigned long pump_runtime_hours = 0;
unsigned long pump_daily_run_hrs = 0;
