Compile error help please
Please help with compile error.
I'm not a programmer, I'm ok with writing simple C code, I often struggle with the compile and link process when errors occur. Some time ago I developed a custom board similar to a MKRZERO except it uses a SAMD21g17 instead of the SAMD21G18 used on the MKRZERO. I had this all working, compiling etc. with a custom boards.txt, I did all the JSON related stuff. Everything was working. The main difference between my custom board and the MkrZero is that the G17A has half the RAM and FLASH and I reconfigured one of the SPI ports (S2) to be a slave instead of a master
Fast forward 6 months or so I try to recompile and now I have compile/link errors. I have not modified the original .ino for the project, I did upgrade a few libraries along the way while working on other Arduino projects.
The compiler appears to be complaining about a missing sam.h
My questions:
  1. what is the correct location for sam.h?
  2. why is this now a problem and it was not a problem in the past?
  3. there are a plethora of sam.h on my pc in many locations with dates ranging from 2015 to 2019, how do I know which one to use or relocate.
BTW I copied a random sam.h to the folder that the compiler seemed to be looking in and this seemed to satisfy the compiler, but then it came up with the same missing error this time for samd21g18a.h. I would have thought the compiler would be using samd21g17a.h not samd21g18a, I'm not sure why?
This is the error message I get when I try to compile:
Arduino: 1.8.15 (Windows 7), Board: "EPC E105"
In file included from C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E105\hardware\samd\0.0.0\libraries\SPI/SPI.h:23:0,
                 from C:\Users\EPC-JRS\Documents\Arduino\ELS-1\ELS-1.ino:15:
C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPC E105\hardware\samd\0.0.0\cores\arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory
 #include "sam.h"
compilation terminated.
exit status 1
Error compiling for board EPC E105.
There are two "sam.h" files on my computer and they are not the same.
They are hidden deep in the build environment, and it is not something that you have to include in your sketch.
The locations are something like this:
  1. arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL
  2. arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd51/include
I assume that they are already in the include path.
The bootloader includes "sam.h" a number of times.
The only other file that includes "sam.h" is "startup_sam4e.c", but I can not find who uses that file.
My "Arduino.h" for the "samd" path does not include "sam.h", but it has:
#include <samd.h>
Perhaps something has changed in the build process and you have a mix of old and new.
:point_right: This makes sense: Arduino.h -> samd.h -> samd21/include/samd21.h -> samd21g17a.h and that last file includes everything for that processor.
Koepel,
Thanks for your response, I'm a little closer.
I have attached the latest error messages.
The first error states "Error while detecting libraries included by C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_338580\sketch\ELS-1.ino.cpp"
The 2nd error is a little more specific "Error while detecting libraries included by C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\EPDAC E105\hardware\samd\0.0.0\libraries\SPI\SPI.cpp
I'm not sure why it would have a problem detecting spi.h, as it is located in the path shown?
I'm not sure what to do next, can anyone suggest what to look for?
Arduino: 1.8.15 (Windows 7), Board: "epc E105"
C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware -hardware C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\tools-builder -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware\tools\avr -tools C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\libraries -libraries C:\Users\EPC-JRS\Documents\Arduino\libraries -fqbn= E105:samd:epc_E105 -vid-pid=2341_804F -ide-version=10815 -build-path C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_338580 -warnings=default -build-cache C:\Users\EPC-JRS\AppData\Local\Temp\arduino_cache_530709 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.openocd.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.CMSIS-4.0.0-atmel.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -verbose C:\Users\EPC-JRS\Documents\Arduino\ELS-1\ELS-1.ino
C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\arduino-builder -compile -logger=machine -hardware C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware -hardware C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\tools-builder -tools C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\hardware\tools\avr -tools C:\Users\EPC-JRS\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\EPC-JRS\AppData\Local\Arduino1.8.15\arduino-1.8.15\libraries -libraries C:\Users\EPC-JRS\Documents\Arduino\libraries -fqbn=epc E105:samd:epc_E105 -vid-pid=2341_804F -ide-version=10815 -build-path C:\Users\EPC-JRS\AppData\Local\Temp\arduino_build_338580 -warnings=default -build-cache C:\Users\EPC-JRS\AppData\Local\Temp\arduino_cache_530709 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.openocd.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -prefs=runtime.tools.CMSIS-4.0.0-atmel.path=C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.0.0-atmel -verbose C:\Users\EPC-JRS\Documents\Arduino\ELS-1\ELS-1.ino
Using board 'epc_E105' from platform in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0
Using core 'arduino' from platform in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0
Detecting libraries used...
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.13]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.10.13]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o nul
Alternatives for Adafruit_ILI9341.h: [Adafruit_ILI9341@1.5.10 arduino_829653@1.5.10]
ResolveLibrary(Adafruit_ILI9341.h)
  -> candidates: [Adafruit_ILI9341@1.5.10 arduino_829653@1.5.10]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o nul
Alternatives for XPT2046_Touchscreen.h: [XPT2046_Touchscreen@1.2]
ResolveLibrary(XPT2046_Touchscreen.h)
  -> candidates: [XPT2046_Touchscreen@1.2]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI\\SPI.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\libraries\SPI\SPI.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.10.1]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.10.1]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341\\Adafruit_ILI9341.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_ILI9341\Adafruit_ILI9341.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen\\XPT2046_Touchscreen.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\XPT2046_Touchscreen\XPT2046_Touchscreen.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire\\Wire.cpp" -o nul
Error while detecting libraries included by C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\libraries\Wire\Wire.cpp
Generating function prototypes...
"C:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_epc_E105 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D_SAMD21G17D_ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"epc Inc\"" "-DUSB_PRODUCT=\"epc E105\"" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" -I/CMSIS/Device/ATMEL/ "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\cores\\arduino" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\variants\\E105-00" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\SPI" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\XPT2046_Touchscreen" "-IC:\\Users\\EPC-JRS\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\EPC-JRS\\AppData\\Local\\Arduino15\\packages\\epc E105\\hardware\\samd\\0.0.0\\libraries\\Wire" "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\sketch\\ELS-1.ino.cpp" -o "C:\\Users\\EPC-JRS\\AppData\\Local\\Temp\\arduino_build_338580\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\cores\arduino/Arduino.h:48:0,
                 from C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\libraries\SPI/SPI.h:23,
C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\cores\arduino/sam.h:62:4: error: #error Library does not support the specified device
Multiple libraries were found for "Adafruit_ILI9341.h"
 Used: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_ILI9341
 Not used: C:\Users\EPC-JRS\Documents\Arduino\libraries\arduino_829653
Using library SPI at version 1.0 in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\libraries\SPI
Using library Adafruit_GFX_Library at version 1.10.13 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_ILI9341 at version 1.5.10 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_ILI9341
Using library XPT2046_Touchscreen at version 1.2 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\XPT2046_Touchscreen
Using library Adafruit_BusIO at version 1.10.1 in folder: C:\Users\EPC-JRS\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\EPC-JRS\AppData\Local\Arduino15\packages\epc E105\hardware\samd\0.0.0\libraries\Wire
exit status 1
Error compiling for board epc E105.
