Compile error in no-arg constructor (solved)
I’ve been trying to create a library class, and I get a compile error in the sketch when trying to access members of an instance, wich class has a no-arg constructor.
This is the library class, wich I’ve put in the hardware\libraries dir as usual:
This is Test.h:
#ifndef Test_h
#define Test_h
#include "WProgram.h"
class Test
  public:
       int testVar;
      Test();
      void testMethod();
#endif
This is Test.cpp:
#include "Test.h"
Test::Test()
      testVar = 1;
void Test::testMethod()
      testVar = 2;
And this is the sketch testing the Test class:
#include <Test.h>
  Test myTest();
  myTest.testVar = 34;
  myTest.testMethod();
When compiling the sketch, the compiler says:
In function ‘void setup()’:
error: request for member ‘testVar’ in ‘myTest’, wich is of non-class type ‘Test ()()’
This happens when accessing the member variable or the method.
But, when adding an integer parameter to the constructor, it compiles nicely. I suppose that it’s a bug, because no-arg constructor should be allowed, isn’t it?
Thanks in advance
I forgot to mention that I’m using compiler version 0017
It will probably not fix your problem, but remove the WProgram from the cpp.
Some compilers will roduce erratic code if both the header and the source includes the same file.
You should be able to instantiate a class with a single no-args constructor using the following syntax:
#include <Test.h>
  Test myTest;  // use constructor with no args
It worked, thanks.
