Compile Error - initializer fails to determine size of 'servo_delay'
Hello all,
I searched and could not find an answer to my problem. Any help would be appreciated.
I'm new to all of this so please excuse my ignorance. I've built a 3D printer from a kit (FLSun Prusa I3 C clone), and was able to compile a configuration and upload it to the board a few days ago with no problem. Yesterday I went to make a small change to the configuration (Invert Endstop), and compile it, and now I get the following error:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\MarlinConfig.h:30:0,
from sketch\servo.cpp:53:
sketch\servo.cpp: In member function 'void Servo::move(int)':
Configuration.h:1545: error: initializer fails to determine size of 'servo_delay'
define SERVO_DELAY 300
sketch\servo.cpp:311:38: note: in expansion of macro 'SERVO_DELAY'
constexpr uint16_t servo_delay[] = SERVO_DELAY;
Configuration.h:1545: error: array must be initialized with a brace-enclosed initializer
servo.cpp:312: error: static assertion failed: SERVO_DELAY must be an array NUM_SERVOS long.
static_assert(COUNT(servo_delay) == NUM_SERVOS, "SERVO_DELAY must be an array NUM_SERVOS long.");
exit status 1 initializer fails to determine size of 'servo_delay'
How do I resolve this error?
Thanks in advance,
-Jorden
By the way, here is the current setting I have in my configuration.h
OK, did some more troubleshooting. I still don't know why it's a problem, but here is some more info:
Using Marlin 1.1.2, these setting work fine, but won't work for me using Marlin 1.1.6:
//#define FIX_MOUNTED_PROBE
/** * Z Servo Probe, such as an endstop switch on a rotating arm. */
define Z_ENDSTOP_SERVO_NR 0 // Defaults to SERVO 0 connector.
define Z_SERVO_ANGLES {40,85} // Z Servo Deploy and Stow angles
define NUM_SERVOS 2 // Servo index starts with 0 for M280 command
// Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle. // 300ms is a good value but you can try less delay. // If the servo can't reach the requested position, increase it.
define SERVO_DELAY 500
// Servo deactivation // // With this option servos are powered only during movement, then turned off to prevent jitter.
define DEACTIVATE_SERVOS_AFTER_MOVE
Using Marlin 1.1.6, I have to set those settings to the following, in order to prevent the SERVO_DELAY error:
/** * Z Servo Probe, such as an endstop switch on a rotating arm. */ //#define Z_ENDSTOP_SERVO_NR 0 // Defaults to SERVO 0 connector. //#define Z_SERVO_ANGLES {40,85} // Z Servo Deploy and Stow angles
. . . //#define NUM_SERVOS 2 // Servo index starts with 0 for M280 command
// Servo deactivation // // With this option servos are powered only during movement, then turned off to prevent jitter. //#define DEACTIVATE_SERVOS_AFTER_MOVE
Any idea why?
Thanks in advance.
-Jorden
