As a neophtye I admit to only having a cursory understanding of the C language. I get by, barely. Lol.
I have some sort of a mental block understanding this compiler error. If i add "char" to the Alm_Relay[4] variable in the void loop the compiler error changes to "unused variable."
I have a C Programming Absolute Beginners Guide and have looked up online the "cons char*
to char" snafu but still no eureka moment for me.
Any explanation would be appreciated despite my feeling rather obtuse right now.
char Alm_Relay[4] = "OFF"; // defined in my constants.h file
void Alm_Relay_ON() // Building alarm relay ON command
{ // TWO triggers: temp OR pressure
if (cycle_OFF_timer == false)
digitalWrite(relay1_outPin, HIGH);
if (digitalRead(relay1_outPin) == HIGH)
Alm_Relay[4] = "ON"; // Building Alm relay 'ON' status
Serial.println(" Building Alarm Relay ON"); // turn buzzer alarm OFF after X mins; cycle OFF/ON
currentMillis = millis(); //get current "time" (actually the number of milliseconds since program started)
if (currentMillis - startMillis >= period_1) //check whether the Buzzer ON period has elapsed
cycle_OFF_timer = true;
void Alm_Relay_OFF();
startMillis = currentMillis;
void Alm_Relay_OFF() // Building alarm relay OFF command
digitalWrite(relay1_outPin, LOW);
Serial.println(" Building Alarm Relay OFF");
// char Temp_Alm[4] = "OFF";
// char Pressure_Alm[4] = "OFF";
// char Alm_Relay[4] = "OFF";
if (digitalRead(relay1_outPin) == LOW)
Alm_Relay[4] = "OFF"; // Building Alm relay 'OFF' status
if (currentMillis - startMillis >= period_2) //test whether the Buzzer OFF period has elapsed
cycle_OFF_timer = false;
WARNING: library StackString claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
/tmp/arduino_modified_sketch_946312/Pump_House__Monitor_ver7C.ino.ino: In function 'void Alm_Relay_ON()':
Pump_House__Monitor_ver7C.ino:215:23: error: invalid conversion from 'const char*' to 'char' [-fpermissive]
/tmp/arduino_modified_sketch_946312/Pump_House__Monitor_ver7C.ino.ino: In function 'void Alm_Relay_OFF()':
Pump_House__Monitor_ver7C.ino:236:21: error: invalid conversion from 'const char*' to 'char' [-fpermissive]
exit status 1
Do I have to redefine the declaration "char Alm_Relay[4]"
Pump_House__Monitor_ver7C.ino:105:38: error: statement has no effect [-Werror=unused-value]
/tmp/arduino_modified_sketch_255981/Pump_House__Monitor_ver7C.ino.ino: In function 'void Alm_Relay_ON()':
Pump_House__Monitor_ver7C.ino:215:15: error: 'Alm_relay' was not declared in this scope
strcpy(Alm_relay, "ON"); // Building Alm relay 'ON' status
/tmp/arduino_modified_sketch_255981/Pump_House__Monitor_ver7C.ino.ino:215:15: note: suggested alternative: 'Alm_Relay'
Alm_Relay
/tmp/arduino_modified_sketch_255981/Pump_House__Monitor_ver7C.ino.ino: In function 'void Alm_Relay_OFF()':
Pump_House__Monitor_ver7C.ino:236:13: error: 'Alm_relay' was not declared in this scope
strcpy(Alm_relay, "OFF"); // Building Alm relay 'OFF' status
/tmp/arduino_modified_sketch_255981/Pump_House__Monitor_ver7C.ino.ino:236:13: note: suggested alternative: 'Alm_Relay'
Alm_Relay
Here it is, some is commented out as I work through errors.
And no, I have no intentions of becoming a code writer. LOL
// 2/4 added code from WiFiWebServer ex. sketch to create
// browser client access; 2/24 added local alarm relay w/ 2 triggers
// 2/6 added low water pressure alarm
// 3/6 Note: this sketch works properly when Board assignment is for "ESP32 Dev Module"
// Code source: https://esp32io.com/tutorials/esp32-temperature-sensor
// 3/24 changed descriptors to char array w/ StackString function to reduce memory usage
// & added cycle timer to building alarm buzzer
#include "hashtag_includes.h" // see tabs at top
#include "constants.h"
// ***************** VOID SETUP ***************
startMillis = millis(); //initial start time for counter/timer
DS18B20.begin(); // initialize the DS18B20 space sensor
pinMode(ONBOARD_LED, OUTPUT); // Blink LED function
pinMode(relay1_outPin, OUTPUT); // Alarm relay
pinMode(switchPin, INPUT); // Pressure Alarm Input
while (WiFi.status() != WL_CONNECTED)
Serial.println("Attempting to Connect To Local LAN: ");
Serial.println(wifissid);
WiFi.begin(wifissid, wifipass);
delay(4000);
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println("Attempting to connect to WPA network...");
server.begin(); // added 2/4 testing
// you're connected now, so print out the status:
Serial.print("WiFi Status: ");
Serial.println(WiFi.status());
Serial.print("ESP Board MAC Address: ");
Serial.println(WiFi.macAddress());
// *********** VOID LOOP ************
DS18B20.requestTemperatures(); // send the command to get temperatures
space_temp_1 = DS18B20.getTempCByIndex(0); // read temperature in °C
sp_temp_1F = (space_temp_1 * 9 / 5) + 32; // convert C to F
sp_temp_1 = sp_temp_1F + tmp_adj_1; // sensor calibration
digitalWrite(ONBOARD_LED,HIGH); // Blink for run indicator
delay(100);
digitalWrite(ONBOARD_LED, LOW);
// ***************** Low Temp Alarm Function ***************
/* if (sp_temp_1 <= Low_Tmp_Alm)
temp_alarm = true;
else {temp_alarm = false;}
// ********************* If temp alarm initiate API msg **********
if (temp_alarm == true && temp_alarm_state == false)
if(DEBUG){Serial.println(" Pump House Temp Alarm is True / Send message");}
temp_alarm_state = true;
Alm_Relay_ON(); // turn local alrm relay/buzzer on
char Temp_Alm[4] = "ON";
sendToPushingBox(DEVID1); // Send request to PushingBox when temp alm is true
} // AND alm state "was" false; this ensures alm is not repeatedly sent.
if (temp_alarm == false && temp_alarm_state == true) // Temp alarm is OFF.
if(DEBUG){Serial.println(" Pump House Temp Alarm is false / No message sent.");}
temp_alarm_state = false;
Alm_Relay_OFF(); // turn local alrm relay/buzzer off
// ***************** Low Pressure Alarm Function ***************
switchState = digitalRead(switchPin); //Pressure Switch Input Pin Read
if (switchState == HIGH) // check if pressure switch has changed state
pressure_alarm = true;
else {pressure_alarm = false;}
if (pressure_alarm == true && press_alarm_state == false) // send out alarm on web
if(DEBUG){Serial.println(" Pressure alarm is TRUE / Send message");}
press_alarm_state = true; // Send request to PushingBox when pressure alm is true
sendToPushingBox(DEVID2); // AND alm state "was" false; this ensures alm is not repeatedly sent.
Alm_Relay_ON(); // turn building alrm relay/buzzer on
char Pressure_Alm[4] = "ON";
if (pressure_alarm == false && press_alarm_state == true) // Pressure alarm is OFF.
if(DEBUG){Serial.println(" Pressure alarm is FALSE / No message sent ");}
press_alarm_state = false;
// ******************** WiFiWebServer Code***********
WiFiClient client = server.available(); // listen for incoming clients
if (client)
Serial.println("new client");
// an http request ends with a blank line
// boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n') // && currentLineIsBlank)
client.println();
client.println();
StackString<50> AString = StackString<50>(" Pump House");
client.println(AString.c_str());
StackString<50> BString = StackString<50>(" **********");
client.println(BString.c_str());
client.println();
client.println();
StackString<50> CString = StackString<50>(" Pump House Temp = ");
CString.append(sp_temp_1);
client.println(CString.c_str());
StackString<50> DString = StackString<50>(" Temp Alarm Setpoint = ");
DString.append(Low_Tmp_Alm);
client.println(DString.c_str());
StackString<50> EString = StackString<50>(" Low Temp Alarm = ");
EString.append(Temp_Alm);
client.println(EString.c_str());
StackString<50> FString = StackString<50>(" Low Pressure Alarm = ");
FString.append(Pressure_Alm);
client.println(FString.c_str());
StackString<50> GString = StackString<50>(" Building Alarm Relay = ");
GString.append(Alm_Relay);
client.println(GString.c_str());
delay(2000); // give the web browser time to receive the data
client.stop(); // close the connection:
Serial.println("client disonnected");
// this write the response from PushingBox Server.
// You should see a "200 OK"
/* if (client.available())
if(DEBUG){Serial.print(c);}
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected)
if(DEBUG){Serial.println();}
if(DEBUG){Serial.println(" disconnecting");}
client.stop();
lastConnected = client.connected();
// Function for sending the request to PushingBox
void sendToPushingBox(char devid[])
client.stop();
if(DEBUG){Serial.println(" connecting...");}
if(client.connect(serverName, 80))
if(DEBUG){Serial.println(" connected");}
if(DEBUG){Serial.println(" sending request to PushingBox API");}
client.print("GET /pushingbox?devid=");
client.print(devid);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(serverName);
client.println("User-Agent: ESP32");
client.println();
if(DEBUG){Serial.println(" connection failed");}
char Alm_Relay[4] = "ON"; // Building Alm relay 'ON' status
char Alm_Relay[4] = "OFF"; // Building Alm relay 'OFF' status
int status = WL_IDLE_STATUS; // the Wifi radio's status
WiFiClient client;
WiFiServer server(80); // added for testing 2/4
OneWire oneWire(SENSOR_PIN);
DallasTemperature DS18B20(&oneWire);
char wifissid[] = "hug2g842673"; //
char wifipass[] = "xxxxxxxsouth"; //
char DEVID1[] = ""; // token/key for low temp alarm [ xxxxxxx203ED29211 ]
char DEVID2[] = ""; // token/key for low wtr pressure alarm [ xxxxxxx10CAE86043 ]
boolean DEBUG = true; // Debug mode !!!!
char serverName[] = ""; // [ api.pushingbox.com ]
// int keyIndex = 0; WiFi Communication Parameter NEEDED????
const int relay1_outPin = 18; // Temp Alarm Relay output pinMode(GPIO, OUTPUT);
boolean temp_alarm = false;
boolean temp_alarm_state = false;
boolean lastConnected = false;
// ************* Low Water Pressure Alm Parameters ***********
int switchPin = 4; // Board Digital Input GPIO4; pinMode(GPIO, INPUT);
int switchState = 0;
boolean pressure_alarm = false;
boolean press_alarm_state = false;
// ***************** Low Temp Alarm Parameters ***************
// const int B = 4275; // B value of the thermistor; +- 275 = .6 C (1.0 F)
// const uint32_t R0 = 100000; // R0 = 100k; int type uint32_t required (unsigned 32 bit)
int tmp_adj_1 = 1; // sensor 1 calibration adjustment
float space_temp_1; // Dallas DS18B20 temp sensor
int sp_temp_1;
float sp_temp_1F;
int Low_Tmp_Alm = 38.00; // Low Alarm Setpoint
// Millis() timer function
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period_1 = 3000000; // X millisecs [period_1] is ON time
const unsigned long period_2 = 60000; // [period_2] is OFF time
boolean cycle_OFF_timer = false; // is only true after buzzer exceeds ON time duration
#include <SPI.h>
#include <WiFi.h>
#include <math.h>
#include <DallasTemperature.h>
// #include <DS18B20.h>
#include <OneWireNg.h>
#define ONBOARD_LED 2
#define SENSOR_PIN 21 // ESP32 pin GIOP21 connected to DS18B20
#include <StackString.hpp> // save memory using this function: character arrays
using namespace Stack;
Yes, I see...
I don't understand why do you need at all Alm_Relay[4] string? You only assign it, but newer use.
Your code has a lot of errors. Every time you start a variable with a type, for example :
-this is a new variable! When you create multiple variables with the same name in different part of the program, they don't exchange values...
If you intent to use variable between the procedures, you should define it only once beyond all the block - it means create global variable.
Whatever is simple, lasts a long time, and doesn't tax my neophytic brain.
I have never used ++C code before so a learning curve is definitely involved.
Sorry, when will be memory allocated for "ON" and "OFF" strings, if you declared just a pointer? A pointer to what?
And what will happen to the memory occupied by "ON" when we assign "OFF" to the same pointer?
This explains some compile errors I have seen. I need to go back and rethink my approach and maybe even "bone up" on character strings alot more. This is "OJT" for me. LOL
whenever you describe a string in code, the compiler allocates space for it somewhere (e.g string table).
when you define a pointer, in this case to a "const char *", the compiler allocates space for the pointer value. the pointer value can be changed, just like any other variable (e.g. a = 3.14;)
so in the code i posted, a pointer and 3 strings are allocated and the pointer is set to "new" in setup() -- the pointer value is set to the address that "new" is allocated in memory. in loop(), the pointer value is changed to either the address of "Off" or "On"
