Compile error message plz help.
Hello All =(
plz when i compile the code this message appear
In function 'boolean sendMyPage(char*)':
:113: error: 'Wiserver' was not declared in this scope
WiServer.print("<html><center>");
WiServer.print("<img src=\"logo.png\">");
WiServer.print("<table width=200 cellspacing=0 cellpadding=0 border=0>");
WiServer.print("<tr><td> <form>");
WiServer.print("Chemical Lab Security System");
WiServer.print("</td></tr>");
WiServer.print("<tr><td>");
WiServer.print("Date:</td>");
WiServer.print("<td>");
WiServer.print(day());
Wiserver.print(month());
Wiserver.print(year());
WiServer.print("Tempreture Value </td>");
WiServer.print("<td> <input type=\"text\" name=\"temperature\" value=");
WiServer.print(Temp);
WiServer.print("<td BGCOLOR=/""");
Wiserver.print(colorTemp);
Wiserver.print("\"");
Wiserver.print(stateT);
WiServer.print("</table>");
Wiserver.print("</td></tr><tr><td><p>Gas leak: </p> </td><td><input type=\"text\" name=\"gas\" value=\"");
Wiserver.print(gas);
Wiserver.print("\"></td><td BGCOLOR=\"");
Wiserver.print(colorgas);
Wiserver.print("\">");
Wiserver.print(stateG);
Wiserver.print("</td></tr><tr><td><p>Flame: </p> </td><td><input type=\"text\" name=\"flame\" value=\"");
Wiserver.print(flame);
Wiserver.print("\"/></td><td BGCOLOR=");
Wiserver.print(colorFlame);
Wiserver.print(">");
Wiserver.print(stateF);
Wiserver.print("</td></tr></table> <a href=\"results.php\">For more resuts click here</a>");
WiServer.print("</center></html>");
    return true;}
    return false;
i want to change the Bgcolor based on the value recieved for example if the tempreture value more than 30 i want the BGcolor red otherwise i want it green.
i test the vaues if it more than 30 the variable ColorT will be Red and StateT will be Warining. how can do this
plz help me how can i solve this probelm.
Thanx in advance
That code snippet doesn't seem to be the right bit? Have you got the case right 'WiServer' and 'Wiserver' are not the same note.
Thank You :grin: :smiley: XD
