Compile Error; Need another set of eyes [solved]
So I'm trying to put together a 5-digit 7-segment display. Unfortunately, I keep getting two compile errors that I can't track down the source of. I was hoping another set of eyes could catch it, because I'm not finding any undefined variables or other weirdness that I'd expect to result in these errors. Here're the errors:
"_7_seg_test_ver3:30: error: expected unqualified-id before 'return'
_7_seg_test_ver3:119: error: expected unqualified-id before 'return'"
I added inline comments to both lines so that they're easier to find below. Thanks in advance, this is driving me nuts.
#define PIN_G 1
#define PIN_F 2
#define PIN_E 3
#define PIN_D 4
#define PIN_DP 5
#define PIN_C 6
#define PIN_B 7
#define PIN_A 8
#define DIGIT_0 9
#define DIGIT_1 10
#define DIGIT_2 11
#define DIGIT_3 12
#define DIGIT_4 13
#define FONT_1 B11111001
#define FONT_2 B01001100
#define FONT_3 B01101000
#define FONT_4 B00111001
#define FONT_5 B00101010
#define FONT_6 B00001011
#define FONT_7 B11111000
#define FONT_8 B00001000
#define FONT_9 B00111000
#define FONT_0 B10001000
  pinMode(PIN_G, OUTPUT);
  digitalWrite(PIN_G, HIGH); // LINE 30
  pinMode(PIN_F, OUTPUT);
  digitalWrite(PIN_F, HIGH);
  pinMode(PIN_E, OUTPUT);
  digitalWrite(PIN_E, HIGH);
  pinMode(PIN_D, OUTPUT);
  digitalWrite(PIN_D, HIGH);
  pinMode(PIN_DP, OUTPUT);
  digitalWrite(PIN_DP, HIGH);
  pinMode(PIN_C, OUTPUT);
  digitalWrite(PIN_C, HIGH);
  pinMode(PIN_B, OUTPUT);
  digitalWrite(PIN_B, HIGH);
  pinMode(PIN_A, OUTPUT);
  digitalWrite(PIN_A, HIGH);
  pinMode(DIGIT_0, OUTPUT);
  digitalWrite(DIGIT_0, LOW);
  pinMode(DIGIT_1, OUTPUT);
  digitalWrite(DIGIT_1, LOW);
  pinMode(DIGIT_2, OUTPUT);
  digitalWrite(DIGIT_2, LOW);
  pinMode(DIGIT_3, OUTPUT);
  digitalWrite(DIGIT_3, LOW);
  pinMode(DIGIT_4, OUTPUT);
  digitalWrite(DIGIT_4, LOW);
byte segDisplay[10];
byte displayPosition = 0;
unsigned long currentValue = 0;
char decimalPosition = -1;
void tick(void)
  byte tmp;
  if(displayPosition > 4) displayPosition = 0;
  tmp = segDisplay[displayPosition];
  if(bitRead(tmp, 7) == 0) digitalWrite(PIN_G, LOW);
  if(bitRead(tmp, 6) == 0) digitalWrite(PIN_F, LOW);
  if(bitRead(tmp, 5) == 0) digitalWrite(PIN_E, LOW);
  if(bitRead(tmp, 4) == 0) digitalWrite(PIN_D, LOW);
  if(bitRead(tmp, 3) == 0) digitalWrite(PIN_DP, LOW);
  if(bitRead(tmp, 2) == 0) digitalWrite(PIN_C, LOW);
  if(bitRead(tmp, 1) == 0) digitalWrite(PIN_B, LOW);
  if(bitRead(tmp, 0) == 0) digitalWrite(PIN_A, LOW);
  switch(displayPosition)
    case 0:
      digitalWrite(DIGIT_0, HIGH);
      displayPosition++;
    case 1:
      digitalWrite(DIGIT_1, HIGH);
      displayPosition++;
    case 2:
      digitalWrite(DIGIT_2, HIGH);
      displayPosition++;
    case 3:
      digitalWrite(DIGIT_3, HIGH);
      displayPosition++;
    case 4:
      digitalWrite(DIGIT_4, HIGH);
      displayPosition++;
return byte setDigit(int val) // LINE 119
  byte tmp = 0;
  switch(val)
    case 0:
      tmp = FONT_0;
    case 1:
      tmp = FONT_1;
    case 2:
      tmp = FONT_2;
    case 3:
      tmp = FONT_3;
    case 4:
      tmp = FONT_4;
    case 5:
      tmp = FONT_5;
    case 6:
      tmp = FONT_6;
    case 7:
      tmp = FONT_7;
    case 8:
      tmp = FONT_8;
    case 9:
      tmp = FONT_9;
    default:
      tmp = 0;
  return tmp;
void setValue(unsigned long val)
  currentValue = val;
  for(char count = 9; count >= 0; count--)
    segDisplay[count] = setDigit(val%10);
    val = val / 10;
  tick();
  delay(10);
Change...
...to...
Oh, duh. I knew it had to be something stupid like that, but I wasn't seeing it.
Thank you very much!
I know that the cause of the error has been found and fixed but, as a matter of interest, why are there semi-colons at the end of lines 116 and 157 ?
I think I just forgot to remove them after an edit. :slight_smile:
