Compile error "redeclared as different kind of symbol"
Hello, I’m having trouble completing this code for the arduino due.
“‘volatile int P’ redeclared as different kind of symbol”
"‘volatile int V [2]’ redeclared the different kind of symbol '.
Does anyone have any idea why?
//comments in portuguese
volatile String Operasao = "M";
volatile int P = 0;
volatile int V[2] = {0,0};
volatile String Posisao;
attachInterrupt(digitalPinToInterrupt (2), A, HIGH);
attachInterrupt(digitalPinToInterrupt (3), B, HIGH);
attachInterrupt(digitalPinToInterrupt (4), C, HIGH);
attachInterrupt(digitalPinToInterrupt (5), D, HIGH);
attachInterrupt(digitalPinToInterrupt (6), E, HIGH);
attachInterrupt(digitalPinToInterrupt (7), f, HIGH);
attachInterrupt(digitalPinToInterrupt (8 ), G, HIGH);
attachInterrupt(digitalPinToInterrupt (9), H, HIGH);
attachInterrupt(digitalPinToInterrupt (10), I, HIGH);
attachInterrupt(digitalPinToInterrupt (11), J, HIGH);
attachInterrupt(digitalPinToInterrupt (12), K, HIGH);
attachInterrupt(digitalPinToInterrupt (13), L, HIGH);
attachInterrupt(digitalPinToInterrupt (21), M, HIGH);
attachInterrupt(digitalPinToInterrupt (22), N, HIGH);
attachInterrupt(digitalPinToInterrupt (23), O, HIGH);
attachInterrupt(digitalPinToInterrupt (24), P, HIGH);
attachInterrupt(digitalPinToInterrupt (25), Q, HIGH);
attachInterrupt(digitalPinToInterrupt (26), R, HIGH);
attachInterrupt(digitalPinToInterrupt (27), S, HIGH);
attachInterrupt(digitalPinToInterrupt (28), T, HIGH);
attachInterrupt(digitalPinToInterrupt (29), U, HIGH);
attachInterrupt(digitalPinToInterrupt (30), V, HIGH);
attachInterrupt(digitalPinToInterrupt (31), W, HIGH);
attachInterrupt(digitalPinToInterrupt (32), X, HIGH);
attachInterrupt(digitalPinToInterrupt (33), Y, HIGH);
attachInterrupt(digitalPinToInterrupt (34), Z, HIGH);
attachInterrupt(digitalPinToInterrupt (35), AA, HIGH);
attachInterrupt(digitalPinToInterrupt (36), AB, HIGH);
attachInterrupt(digitalPinToInterrupt (37), AC, HIGH);
attachInterrupt(digitalPinToInterrupt (38), AD, HIGH);
attachInterrupt(digitalPinToInterrupt (39), AE, HIGH);
attachInterrupt(digitalPinToInterrupt (40), AF, HIGH);
attachInterrupt(digitalPinToInterrupt (41), AG, HIGH);
attachInterrupt(digitalPinToInterrupt (42), AH, HIGH);
attachInterrupt(digitalPinToInterrupt (43), AI, HIGH);
attachInterrupt(digitalPinToInterrupt (44), AJ, HIGH);
attachInterrupt(digitalPinToInterrupt (45), AK, HIGH);
attachInterrupt(digitalPinToInterrupt (46), AL, HIGH);
attachInterrupt(digitalPinToInterrupt (47), AM, HIGH);
attachInterrupt(digitalPinToInterrupt (48), AN, HIGH);
attachInterrupt(digitalPinToInterrupt (49), AO, HIGH);
attachInterrupt(digitalPinToInterrupt (50), AP, HIGH);
attachInterrupt(digitalPinToInterrupt (51), AQ, HIGH);
attachInterrupt(digitalPinToInterrupt (52), AR, HIGH);
attachInterrupt(digitalPinToInterrupt (53), AS, HIGH);
void A() { // manual
Operasao = "M"
void B() { // automatico
Operasao = "A"
void C() { // cima
P = P+1;
void D() { // baixo
if (P>0){
P = P-1;
void E() { // Parametros
P = 0;
Posisao = "IN"+ P;
void f() { // injeção
if (Operasao = "A"){
P = 0;
Posisao = "IN"+ P;
void G() { // dosagem
P = 0;
Posisao = "DO"+ P;
void H() { // descompressão
P = 0;
Posisao = "DE"+ P;
void I() { // ciclo
P = 0;
Posisao = "CI"+ P ;
void J() { // temperatura
P = 0;
Posisao = "TE"+ P;
void K() { // abertura
P = 0;
Posisao = "AB"+ P;
void L() { // fechamento
P = 0;
Posisao = "FE"+ P;
void fe() { // paramentros + injeção
P = 0;
Posisao = "IN"+ P;
void ge() { // paramentros + dosagem
P = 0;
Posisao = "DO"+ P;
void he() { // paramentros + descompressão
P = 0;
Posisao = "DE"+ P;
void ke() { // paramentros + abertura
P = 0;
Posisao = "AB"+ P;
void le() { // paramentros + fechamento
P = 0;
Posisao = "FE"+ P;
void M() { // editar
  Ed = Ed + 1;
void N() { // Entra
 Serial.println(Posisao);
 Serial.print(",");
 Serial.print(Ed);
 Serial.print(",");
 Serial.print(V[1]);
 Serial.print(V[2]);
// EXEMPLO DE  SAIDA : DO3,2,30
                                    // TECLADO NUMERICO
                                    void O() { // 1
                                    V[1] = V[2];
                                    V[2] = 1;
                                    void P() { // 2
                                      V[1] = V[2];
                                      V[2] = 2;
                                    void Q() { // 3
                                      V[1] = V[2];
                                      V[2] = 3;
                                    void R() { // 4
                                      V[1] = V[2];
                                      V[2] = 4;
                                    void S() { // 5
                                      V[1] = V[2];
                                      V[2] = 5;
                                    void T() { // 6
                                      V[1] = V[2];
                                      V[2] = 6;
                                    void U() { // 7
                                      V[1] = V[2];
                                      V[2] = 7;
                                    void V() { // 8
                                      V[1] = V[2];
                                      V[2] = 8;
                                    void W() { // 9
                                      V[1] = V[2];
                                      V[2] = 9;
                                    void X() { // 0
                                      V[1] = V[2];
                                      V[2] = 0;
void Y() { // Cancela edição
Ed = 0;
void Z() {
void AA() {
void AB() {
void AC() {
void AD() {
void AE() {
void AF() {
void AG() {
void AH() {
void AI() {
void AJ() {
void AK() {
void AL() {
void AM() {
void AN() {
void AO() {
void AP() {
void AQ() {
void AR() {
void AS() {
void loop(){
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
The problem is probably caused by the fact that P and V are already defined by the system. Try changing the names
Why are you using such an enormous number of interrupts ?
If you looked at the error messages that showed up in the text box below your sketch you would see the problem:
sketch_oct20a:183: error: 'void P()' redeclared as different kind of symbol
 void P()   // 2
/Users/john/Documents/Arduino/sketch_oct20a/sketch_oct20a.ino:4:14: note: previous declaration 'volatile int P'
 volatile int P = 0;
sketch_oct20a:213: error: 'void V()' redeclared as different kind of symbol
 void V()   // 8
/Users/john/Documents/Arduino/sketch_oct20a/sketch_oct20a.ino:5:14: note: previous declaration 'volatile int V [2]'
 volatile int V[2] = {0, 0};
You have an int variable named 'P' and a function named 'P'. You have an int array named 'V' and a function named 'V'. Fix those, and then work on all the other problems, like missing ';'s.
Adding an integer to a string constant doesn't do what you might expect, although if you set the integer you add is zero it should not be damaging.
void E()   // Parametros
  P = 0;
  Posisao = "IN" + P;
Thanks for the help John and helibob. I am a beginner in Arduino and did not know how to find the error through the error notification window.
responding bob, I’m using interrupts to monitor a keyboard. I opted for the interrupt instead of digitalRead because it has a faster response, but for this application really does not make much difference, any recommendation against using this number of interrupts?
here is the compiled code:
(I had to remove the volatile strings)
volatile int Pi = 0;
String Posisao;
volatile int Ed = 0;
attachInterrupt(digitalPinToInterrupt (8), G, HIGH);
attachInterrupt(digitalPinToInterrupt (30), Vv, HIGH);
Operasao = "M";
Operasao = "A";
void C() { // cima
Pi = Pi+1;
void D() { // baixo
if (Pi>0){
Pi = Pi-1;
Pi = 0;
Posisao = "IN";
Pi = 0;
Posisao = "IN";
Pi = 0;
Posisao = "DO";
Pi = 0;
Posisao = "DE";
void I() { // ciclo
Pi = 0;
Posisao = "CI";
Pi = 0;
Posisao = "TE";
Pi = 0;
Posisao = "AB";
Pi = 0;
Posisao = "FE";
Pi = 0;
Posisao = "IN";
Pi = 0;
Posisao = "DO";
Pi = 0;
Posisao = "DE";
Pi = 0;
Posisao = "AB";
Pi = 0;
Posisao = "FE";
  Ed = Ed + 1;
void N() { // Entra
 Serial.print(Pi);
 Serial.print(Ed);
 Serial.print(V[1]);
 Serial.print(V[2]);
// EXEMPLO DE  SAIDA : DO3230
                                    // TECLADO NUMERICO
                                    void O() { // 1
                                    V[1] = V[2];
                                    V[2] = 1;
                                    void P() { // 2
                                      V[1] = V[2];
                                      V[2] = 2;
                                    void Q() { // 3
                                      V[1] = V[2];
                                      V[2] = 3;
                                    void R() { // 4
                                      V[1] = V[2];
                                      V[2] = 4;
                                    void S() { // 5
                                      V[1] = V[2];
                                      V[2] = 5;
                                    void T() { // 6
                                      V[1] = V[2];
                                      V[2] = 6;
                                    void U() { // 7
                                      V[1] = V[2];
                                      V[2] = 7;
                                    void Vv() { // 8
                                      V[1] = V[2];
                                      V[2] = 8;
                                    void W() { // 9
                                      V[1] = V[2];
                                      V[2] = 9;
                                    void X() { // 0
                                      V[1] = V[2];
                                      V[2] = 0;
Ed = 0;
void Z() {
void AA() {
void AB() {
void AC() {
void AD() {
void AE() {
void AF() {
void AG() {
void AH() {
void AI() {
void AJ() {
void AK() {
void AL() {
void AM() {
void AN() {
void AO() {
void AP() {
void AQ() {
void AR() {
void AS() {
void loop(){
Moderator edit:
tags added.
Why make things complicated by using interrupts ?
Put the pin numbers to be monitored in an array and iterate through it and use digitalRead() to determine their state. If the state is HIGH then act on it.
