compile error: RTC_DS3234 library on Due
I am trying to get the RTC_DS3234 library working with the Due and have a compile error I don’t understand. I’ve had some success with other libraries but this is a new error that I don’t know how to approach. A simple code is below along with the error generated. It works fine when compiled for the Mega. I can’t seem to see how ‘_BV’ is defined or used though… any help greatly appreciated.
#include <SPI.h>
#include <Wire.h>
#include <RTC_DS3234.h>
RTC_DS3234 RTclock(7);
  Serial.print("Starting RTC...");
  if (RTclock.begin())
    Serial.print("Setting time to ");
    Serial.print(__DATE__);
    Serial.print(' ');
    Serial.println(__TIME__);
    // following line sets the RTC to the date & time this sketch was compiled
    RTclock.adjust(DateTime(__DATE__, __TIME__));
    Serial.println("ok");
    DateTime now = RTclock.now();
    Serial.println("RTC failed to Initialise");
Arduino: 1.5.4 (Windows 7), Board: “Arduino Due (Programming Port)”
C:\Users\fe112331\Documents\Arduino\libraries\RTClib\RTC_DS3234.cpp: In member function ‘uint8_t RTC_DS3234::isrunning()’:
C:\Users\fe112331\Documents\Arduino\libraries\RTClib\RTC_DS3234.cpp:69: error: ‘_BV’ was not declared in this scope
The _BV code is in the library and is coding low level on the AVR (“classic”) Arduinos. You should see if anyone has made a SAM/Due compatible library. If not, you’ll need to read up on AVR code and equivalent SAM code (yuck).
If you just need a RTC module, the Adafruit DS1307 breakout has a library that will work with AVR and Due.
