Compile Error w/SEEED XIAO
Get this error trying to compile simple sketch
Using board 'seeed_XIAO_m0' from platform in folder: C:\Users\schre\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3
Using core 'arduino' from platform in folder: C:\Users\schre\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3
Detecting libraries used...
arm-none-eabi-g++: error: SEEED.ino""": Invalid argument
"C:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink" "SEEED.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS\\5.7.0/CMSIS/Core/Include/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS\\5.7.0/CMSIS/DSP/Include/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS-Atmel\\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\variants\\XIAO_m0" "C:\\Users\\schre\\AppData\\Local\\Temp\\arduino-sketch-F33B46273204A69B37896DCC5841F7E7\\sketch\\Blink SEEED.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\schre\AppData\Local\Temp\arduino-sketch-F33B46273204A69B37896DCC5841F7E7\sketch\Blink SEEED.ino.cpp
Generating function prototypes...
"C:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink" "SEEED.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS\\5.7.0/CMSIS/Core/Include/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS\\5.7.0/CMSIS/DSP/Include/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools\\CMSIS-Atmel\\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\cores\\arduino" "-IC:\\Users\\schre\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\samd\\1.8.3\\variants\\XIAO_m0" "C:\\Users\\schre\\AppData\\Local\\Temp\\arduino-sketch-F33B46273204A69B37896DCC5841F7E7\\sketch\\Blink SEEED.ino.cpp" -o "C:\\Users\\schre\\AppData\\Local\\Temp\\arduino-sketch-F33B46273204A69B37896DCC5841F7E7\\preproc\\ctags_target_for_gcc_minus_e.cpp"
exit status 1
Compilation error: exit status 1
As I see, the sketch name is
right?
Try to change name to Blink_SEEED.ino
In general, do not use the spaces in filenames.
That was the problem. Thanks!
Please mark the thread as solved
