Compile error with class static member
This is very similar to previous post on this topic, but I am asking about one specific compiler link error I just can’t figure out.
As instructed in other similar posts I am creating a class to handle a timer interrupt via an ISR and to do so means I need a static function and in this case a static pointer to the class member function that will handle the ISR. I am including the working and broken code below.
My question is why when I initialize the member pointer in the class definition do I get a linking error but when I initialize it after the class definition does works?
The working version:
#include <TimerOne.h>
class A {
public:
//  static A *isr_instance=NULL;    // using this declaration of isr_instance causes link errors
  static A *isr_instance;           // using this declaration plus the initialization below seems to work, I don't understand.
  volatile unsigned long ticks=0;
  static void isr();
  void isr_function();
  A() {
    A::isr_instance = this;
A *A::isr_instance=NULL;
static void A::isr() {
  if (A::isr_instance) A::isr_instance->isr_function();
void A::isr_function() {
  ticks++;
A *my_a;
  my_a = new A();
  Timer1.initialize(100000); // set a 1/10 of a second just to test this out.
  Timer1.attachInterrupt( A::isr ); // attach the service routine here
  Serial.begin(250000);
  static unsigned long last_print_ms = 0;
  static unsigned long cur_ms;
  cur_ms = millis();
  if (cur_ms - last_print_ms > 1000) {
    Serial.print(F("ticks: "));
    Serial.println(my_a->ticks++);
    last_print_ms = cur_ms;
    my_a->ticks = 0;
The broken version (link error):
class A {
public:
//  static A *isr_instance;           // using this declaration plus the initialization below seems to work, I don't understand.
  static void isr();
  A() {
// have to remove this when initializing the variable in the class def
//A *A::isr_instance=NULL;
  ticks++;
A *my_a;
  my_a = new A();
  cur_ms = millis();
    my_a->ticks = 0;
Here is the errors I get when I compile the second version.
/var/folders/dy/ks2g_6657gzdt7wbhhvq65bm0000gq/T//cc1Yn0Eu.ltrans0.ltrans.o: In function `isr':
/Users/jrule/Documents/Arduino/isr_class_test/isr_class_test.ino:23: undefined reference to `A::isr_instance'
/var/folders/dy/ks2g_6657gzdt7wbhhvq65bm0000gq/T//cc1Yn0Eu.ltrans0.ltrans.o: In function `A::A()':
/Users/jrule/Documents/Arduino/isr_class_test/isr_class_test.ino:14: undefined reference to `A::isr_instance'
collect2: error: ld returned 1 exit status
Multiple libraries were found for "TimerOne.h"
 Used: /Users/jrule/Documents/Arduino/libraries/TimerOne-master
exit status 1
Error compiling for board Arduino/Genuino Uno.
The only difference is in how the first variable ‘isr_instance’ is declared in the public section of the class. If I initialize it in the class it does not link correctly. If I initialize it external to the class block it does work. I thought these two should be equivalent. What am I not understanding about C++ classes and how to write them here? Thanks in advance for any help.
By the way, I have tested the code and the ISR routine works great this way. It is Implemented as a class using a static member and a static member function.​
You can't initialize a non-constant static member with the class declaration. I'll defer to the C++ gurus to explain why.
It's kinda-sorta related to the notion that class definitions get put in .h files, and initializers need to be executed.
Say Foo.h contains
// FOO.h
class Foo {
  static int bar = perform_some_calculation();
That initialization would have to be performed when, exactly? How many times? Recall that once a .h is included by the preprocessor, it just looks to the compiler like inline code.
Languages with proper classes don't have this problem, of course.
