Compile Error With Class
I try to create a class and fail somehow to compile it - I would be very happy if someone can help me.
Thank you all …
COMPILE ERROR:
/tmp/cc6pT0Gx.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_robard.ino.cpp.o.1735':
<artificial>:(.text.startup+0x64): undefined reference to `HCSRO4::HCSRO4(int, int)'
collect2: error: ld returned 1 exit status
Error during build: exit status 1
.ino - file
#include "libraries/HCSRO4/HCSRO4.h"
#define CatTriggerPin 30
#define CatEchoPin 31
HCSRO4 cat_sensor(CatTriggerPin, CatEchoPin);
  float hoho = cat_sensor.distincm;
  Serial.println(hoho);
.h - file
#ifndef HCSRO4_h
#define HCSRO4_h
#include "Arduino.h"
class HCSRO4
  public:
    HCSRO4(int trigpin, int echopin);
    void GetDistInCm();
    float distincm;
  private:
    float _distincm;
    float _duration;
    int _delay_ms = 10;
    int _trigpin;
    int _echopin;
#endif
.cpp - file
#include "HCSRO4.h"
HCSRO4::HCSRO4(int trigpin, int echopin) {
  pinMode(trigpin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echopin, INPUT); // Sets the echoPin as an Input
  int _trigpin = trigpin;
  int _echopin = echopin;
HCSRO4::GetDistInCm() {
  digitalWrite(_trigpin,LOW);
  delayMicroseconds(2);
  digitalWrite(_trigpin,HIGH);
  delayMicroseconds(_delay_ms);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  _duration = pulseIn(_echopin,HIGH);
  _distincm = (_duration - _delay_ms)* 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
  distincm = _distincm
The file structure is:
./libraries
./libraries/HCSRO4
./libraries/HCSRO4/HCSRO4.cpp
./libraries/HCSRO4/HCSRO4.h
./robard.ino
the message is the linker complaining, not the compiler. it's complaining that the constructor would be missing. but in the .cpp file you have the line "HCSRO4::GetDistInCm() {" without a return type, so i guess you missed the compiler error about this. that might be the reason why the .cpp isn't compiled and in turn the constructor is missing in the object file. at least that would be my guess. does adding "void " at the beginning of the line fix the problem?
Hi frozenrat
Thank you for the quick reply.
Im not quite shure if I understand you well - Do you mean the following?
VVVV ------------------------------- This ?
void HCSRO4::GetDistInCm() {
I still get the same error:
tmp/ccYLgxMa.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_robard.ino.cpp.o.1735':
Hi frozenrat
Thank you very much it was the described solution and I had to put the *.cpp and *.h files into the top directory to make it work ... And I also did som Copy&Pasting which was not very intelligent ... :slight_smile: Copy&Paste is not my friend.
Thank you 1000 * x times.
