Compile Error ?
Hi Guys
I have been trying to get a sketch to compile that I got from Tech-Zen.TV for a countdown timer. I have been able to run a sketch using a LCD and a keypad but when I try to get the sketch with timer added it will not compile. I get two errors. These are the two errors that I get. Does anyone have any idea what I am doing wrong.
count_down_timer:49: error: expected constructor, destructor, or type conversion before 'void'
count_down_timer:69: error: expected constructor, destructor, or type conversion before 'void'
/*############################## COUNTDOWN TIMER ##################################
This sketch takes input from a keypad to enter the number of minutes and
seconds to count down. When the countdown starts an LED that represents
a relay will turn on. Once the countdown is complete the LED will turn
off.
The user can enter times using a keypad in MM:SS format. The # starts
the countdown. The * will clear the time and also stop the current
countdown once it starts.
To read the keypad input that is is a 4x4 input, we are using a
library from the arduino website called Keypad. You can download this
library at: http://arduino.cc/playground/Code/Keypad
Let's Make It Episode 42 (http://letmakeit.tv)
http://tech-zen.tv
For the sample code, show notes, contact information and many more
videos, visit the show page at http://tech-zen.tv/letsmakeit
Please subscribe to our YouTube channel or our netcasts at any of
your favorite netcast / podcast outlets.
We normally record Let's Make It live on Tuesday evenings around
7pm eastern. You can watch it live by going to tech-zen.tv and clicking
the live link at the top of the page.
We also have a community setup for our viewers and listeners. You can
join the community by going to community.tech-zen.tv.
We love input on what you would like to know or if you have an idea for
a new Let's Make it episode, you can contact us via email or phone at
the show information page.
#include <Wire.h>
#include <Keypad.h>
//constants for Control Pin
int controlPin = 13;
char currentTimeValue[4];
int currentState = 1;
int timerSeconds = 0;
int lpcnt = 0;
//define the keypad
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
byte rowPins[rows] = {11,10,9,8};
byte colPins[cols] = {7,6,5,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
LiquidCrystal_I2C lcd(0x3F,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line
display
 lcd.init(); // initialize the lcd
 // Print a message to the LCD.
 lcd.backlight();
 //display main screen
 displayCodeEntryScreen();
 //setup and turn off relay
 pinMode(controlPin, OUTPUT);
 digitalWrite(controlPin, LOW);
 //setup default time to 00:00
 currentTimeValue[0]='0';
 currentTimeValue[1]='0';
 currentTimeValue[2]='0';
 currentTimeValue[3]='0';
 showEnteredTime();
 int l;
 char tempVal[3];
 char key = keypad.getKey();
 //key pressed and state is 1
 if (int(key) != 0 and currentState == 1) {
 switch (key) {
 case '*':
 relayStatus(false);
 showEnteredTime();
 currentState = 1;
 lpcnt = 0;
 timerSeconds = 0;
 case '#':
 tempVal[0] = currentTimeValue[0];
 tempVal[1] = currentTimeValue[1];
 tempVal[2] = 0;
 timerSeconds = atol(tempVal) * 60;
 tempVal[0] = currentTimeValue[2];
 tempVal[1] = currentTimeValue[3];
 tempVal[2] = 0;
 timerSeconds = timerSeconds + atol(tempVal);
 currentState = 2;
 default:
 currentTimeValue[0] = currentTimeValue[1];
 currentTimeValue[1] = currentTimeValue[2];
 currentTimeValue[2] = currentTimeValue[3];
 currentTimeValue[3] = key;
 showEnteredTime();
 if (currentState == 2) {
 if (int(key) != 0) {
 if (key == '*') {
 relayStatus(false);
 showEnteredTime();
 currentState = 1;
 lpcnt = 0;
 timerSeconds = 0;
 if (lpcnt > 9) {
 lpcnt = 0;
 --timerSeconds;
 showCountdown();
 if (timerSeconds <= 0) {
 currentState = 1;
 relayStatus(false);
 showEnteredTime();
 relayStatus(true);
 ++lpcnt;
 delay(100);
void showEnteredTime()
 lcd.setCursor(14,3);
 lcd.print(currentTimeValue[0]);
 lcd.print(currentTimeValue[1]);
 lcd.print(":");
 lcd.print(currentTimeValue[2]);
 lcd.print(currentTimeValue[3]);
void relayStatus(bool state)
 if (state)
 digitalWrite(controlPin, HIGH);
void showCountdown()
 char timest[6];\
 lcd.setCursor(0,0);
 lcd.print("********************");
 lcd.setCursor(0,1);
 lcd.print("** COUNTING DOWN **");
 lcd.setCursor(0,2);
 lcd.print("** ");
 sprintf(timest, "%d:%.2d", (timerSeconds/60), (timerSeconds - ((timerSeconds/60)*60)));
 lcd.print(timest);
 lcd.print(" **");
 lcd.setCursor(0,3);
void displayCodeEntryScreen()
 clearScreen();
 lcd.setCursor(0,0);
 lcd.print("Let's Make It Count");
 lcd.setCursor(0,1);
 lcd.print("Down Time...");
 lcd.setCursor(0,2);
 lcd.print("Enter Time mm:ss:");
void clearScreen()
 lcd.setCursor(0,0);
 lcd.print(" ");
 lcd.setCursor(0,1);
 lcd.print(" ");
 lcd.setCursor(0,2);
 lcd.print(" ");
 lcd.setCursor(0,3);
 lcd.print(" ");
display
Take display out.
Or put it on the same line as the comment.
Thank you guys very much ! :slight_smile:
GD
