My first time with a arduino UNO 3 (or any micro controller)
Error msg:
/usr/share/arduino/hardware/arduino/cores/arduino/main.cpp:14: undefined reference to `loop'
collect2: error: ld returned 1 exit status
I have searched for loop with no success in this sketch, this is to turnon a relay
Teleduino328.h - Teleduino328 library
Version 328-0.6.9
Nathan Kennedy 2009 - 2014
http://www.teleduino.org
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#ifndef Teleduino328_h
#define Teleduino328_h
#define TD328_PINS 22
#define TD328_SERVO_INSTANCES 6
#define TD328_SHIFT_REGISTERS 2
#define TD328_SHIFT_REGISTER_TIMERS 8
#include <Arduino.h>
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
// Used for Teleduino328Class::getFreeMemory()
extern unsigned int __data_start;
extern unsigned int __data_end;
extern unsigned int __bss_start;
extern unsigned int __bss_end;
extern unsigned int __heap_start;
extern void *__brkval;
typedef struct
byte mode;
byte expireAction;
unsigned long expireTime;
} Pin;
typedef struct
Servo servo;
byte position;
} ServoInstance;
typedef struct
byte clockPin;
byte dataPin;
byte enablePin;
byte latchPin;
byte outputs[32];
} ShiftRegister;
typedef struct
byte shiftRegister;
byte action;
byte outputs[32];
} ShiftRegisterTimer;
class Teleduino328Class
protected:
boolean _reset;
Pin _pins[TD328_PINS];
ServoInstance _servoInstances[TD328_SERVO_INSTANCES];
ShiftRegister _shiftRegisters[TD328_SHIFT_REGISTERS];
ShiftRegisterTimer _shiftRegisterTimers[TD328_SHIFT_REGISTER_TIMERS];
byte _statusLedPin;
char _version[17];
boolean _wireDefined;
public:
Teleduino328Class();
boolean checkAnalogPin(byte);
boolean checkDigitalPin(byte);
boolean checkPwmPin(byte);
void checkReset();
boolean definePinMode(byte, byte);
int getFreeMemory();
byte hexDecode(byte);
byte hexEncode(byte, boolean);
byte hexEncode(byte);
void instruction(byte*);
void loadPresets();
void pinTimers();
void reset();
boolean setDigitalOutput(byte, byte, unsigned int, byte);
boolean setDigitalOutput(byte, byte, unsigned int);
boolean setDigitalOutput(byte, byte);
void setStatusLed(unsigned int, boolean, long);
void setStatusLed(unsigned int, boolean);
void setStatusLed(unsigned int, long);
void setStatusLed(unsigned int);
boolean setStatusLedPin(byte);
void shiftRegisters();
void shiftRegisterTimers();
extern Teleduino328Class Teleduino328;
#endif
Any assistance would be appreciated
