Just getting started with some tests using the LPD8806 examples with my UNO but can't get any of them to compile.
On the Rainbow_Chaser sample:
#include "LPD8806.h"
#define LEDS_START 40
#define LEDS_END 96
#define LEDS (LEDS_END - LEDS_START)
#define COLOURS 8
int dataPin = 2;
int clockPin = 3;
int thickness = 4;
int state = 0;
LPD8806 strip = LPD8806(LEDS_END, dataPin, clockPin);
int colourPos[7];
int colours[7];
strip.begin();
strip.show();
for (int i = 0; i < 7; i++) {
colourPos[i] = LEDS * i / 7;
colours[i] = 384 * i / 7;
int offset = 0;
int pos = (colourPos[i] + offset) % LEDS;
strip.setPixelColor(pos + LEDS_START, Wheel(colours[i], 1.0 - (float) pos / LEDS));
strip.show();
strip.setPixelColor(pos + LEDS_START, strip.Color(0, 0, 0));
if (++offset == LEDS) {
offset = 0;
uint32_t Wheel(uint16_t WheelPos, float progress)
byte r, g, b;
switch(WheelPos / 128)
case 0:
r = 127 - WheelPos % 128; //Red down
g = WheelPos % 128; // Green up
b = 0; //blue off
case 1:
g = 127 - WheelPos % 128; //green down
b = WheelPos % 128; //blue up
r = 0; //red off
case 2:
b = 127 - WheelPos % 128; //blue down
r = WheelPos % 128; //red up
g = 0; //green off
int intensity = 0;
if (progress > 0.75) {
intensity = 3;
} else if (progress > 0.5) {
intensity = 2;
} else if (progress > 0.25) {
intensity = 1;
return(strip.Color(r >> intensity,g >> intensity,b >> intensity));
I get this error:
"SPI_MODE0' was not declared in this scope
/Users/TV/Documents/Arduino/libraries/LPD8806/LPD8806.cpp:84: error: 'SPI_CLOCK_DIV8' was not declared in this scope"
Any idea why it won't compile? Similar errors on the other samples as well.
Thanks a bunch,
Carl
