Compile errors with arduino Due as board...why?
Before I start chasing red herrings.
What exactly is ambiguous about any of this when I select a Due as my board?
None of this is ambiguous if I select a Mega as my board.
Is it __FlashStringHelper that is causing the problem?
Can you not use __FlashStringHelper when compiling for Due?
sketch\List.cpp: In member function 'void CListItem::dump()':
List.cpp:48: error: call of overloaded 'dump(const __FlashStringHelper*, uint8_t&, int)' is ambiguous
   debug.dump(F("m_nStationNum"), m_nStationNum, false);
sketch\List.cpp:48:54: note: candidates are:
In file included from sketch\List.cpp:2:0:
sketch\Debug.h:37:10: note: void CDebug::dump(const __FlashStringHelper*, uint32_t, bool)
     void dump(const __FlashStringHelper* strVarName, const uint32_t nVal, const bool bNewLine = true);
exit status 1
Debug.cpp (13.6 KB)
Debug.h (2.68 KB)
You’re using two completely different architectures; the helper cast doesn’t work on the Due’s ARM
See this:
Not many candidates in that list, are there?
No. It is a different architecture, and doesn't need to keep string literals out of SRAM.
OK thank you.
I was going to try and adjust my code to work on Due and I thought it would be fairly minor.
But since I have used __FlashStringHelper every where it not going to be an easy code tweak.
And I am not fully up to speed with the precise differences in a architecture.
If I remember correctly the SRAM and flash are in two separate isolated banks on the mega and uno etc, which is why you need the P and __FlashStringHelper?
But presumably the memory on the Due is more like a PC - all in one block and continuously addressable?
So I take it that __FlashStringHelper is being re-defined as, perhaps char*, which means those functions are now conflicting with all my specific char* versions of the same functions?
It's a very simple tweak, surely?
Just redefine F()
AWOL:
Just redefine F()
I assumed that the IDE would do this #define F(STR) STR but obviously not.
But this wont solve all the duplicate functions I have, one with __Flash.... and one with const char* parameters.
