Hi All,
I installed 1.8.5 on new Win10 laptop, and get the following error when compiling. I have previous IDE on WIN7 at home, and no problems there.
Look at the last highlited lines. How do I get around this?
and is the last line error a consequent of the first error?
I'm using a NodeMCU 2.0, which does not exist in board library yet. I have tried generic Esp8266 as well, no luck.
Many Thanks
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\username\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\username\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\username\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\username\AppData\Local\Temp\arduino_build_544323 -warnings=none -build-cache C:\Users\username\AppData\Local\Temp\arduino_cache_934761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\username\Documents\Arduino\DS18B20\ESP8266_EmonCMS_1wire_Temp\ESP8266_EmonCMS_1wire_Temp.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\username\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\username\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\username\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\username\AppData\Local\Temp\arduino_build_544323 -warnings=none -build-cache C:\Users\username\AppData\Local\Temp\arduino_cache_934761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\username\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\username\Documents\Arduino\DS18B20\ESP8266_EmonCMS_1wire_Temp\ESP8266_EmonCMS_1wire_Temp.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\username\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\username\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
open C:\Users\username\AppData\Local\Temp\arduino_build_544323\sketch\ESP8266_EmonCMS_1wire_Temp.ino.cpp: Access is denied.
Error compiling for board NodeMCU 1.0 (ESP-12E Module)
