Compile Fail
Hello, everyone I got trouble in compiling the code even i use the examples code from but it "exit status 1 Error compiling for board Arduino/Genuino Uno." it used to work but now it is not working when i complie ever code .even i uninstall and install it again.
I need help please???????? Thank you
@kidelec, you need to post your program if you expect help with it. See How to use the Forum
...R
Hi kidelec,
In addition to that error, you should more information. Usually the compiler will indicate where the error is and what it doesn't like about the code.
