Compile fails after updating IDE
I just did an update to the IDE, I guess I'm on 1.6.6 now but not sure what version I had before.
Now I get a compile error every time I try to compile. I've pulled up old sketches that compiled fine before and they give the same error message.
I get: avr-g++: error: missing filename after '-o'
I have no idea where to go from here. Can I "un-update" the IDE?
Thanks,
Dean
The error is caused by using Arduino AVR Boards 1.6.10 with Arduino IDE 1.6.6 which are not compatible with each other. There are two options to fix this:
  • If you want to keep using Arduino IDE 1.6.6 then you will need to install a version of Arduino AVR Boards that is compatible. Unfortunately due to a bug you can't go back to Arduino AVR Boards 1.6.9 so you would need to do Tools > Board > Boards Manager... > Arduino AVR Boards(click on it) > Select version > 1.6.8 > Install.
  • Upgrade your Arduino IDE to 1.6.7 or 1.6.8.
