Hi, I have been attempting to compile the arduino yun version of openwrt but have run into several problems.
Following advice from the forum, I have tried the compile using "nice -n 10 nohup make -j 1 V=s &". The error outputs from the last part of the nohup.out file reads:
Hi, I was away for a couple of days, now back, working at a compile.
I did as you recommended and I would like to post the output of "make package/feeds/packages/libowfat/compile V=s" but I would rather post it as an attachment, since it is a bit lengthy. Is there a way to do this?
miner_tom:
I did copy and paste the output of "make package/feeds/packages/libowfat/compile V=s" into xbmclogs.com at http://goo.gl/zBI3wP.
However, what I meant to say in my last post was that I did not know how to make an attachment at this forum. There seem to be no options to do that. If you could direct me I would do that in future.
I have tried to do a compile on a debian 7 64 bit virtual machine and a 32 bit virtual machine. The output that I have pasted is from the 32 bit virtual machine install.
Interestingly, and this might be important, after I installed the 32 bit virtual machine I tried doing the compile and it must have gone on for 4 hours before it failed. I used "nice -n 10 nohup make -j 1 V=s" so I have a rather large nohup.out file so rather than post that whole thing I will just post the last few lines here, where the failure appears to be. It appears to me that the install failed because aprx-2.00_r421.tar.bz2 could not be downloaded from the repository. So, I checked the dl directory and sure enough aprx-2.00_r421.tar.bz2 was not there. I found a repository and put it into the dl directory manually and tried restarting the compile but oddly enough the compile would not start.
Here is the last few lines of the 4 hour compile:
rm -rf /home/tom/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/root-ar71xx/tmp-appweb
touch /home/tom/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/root-ar71xx/stamp/.appweb_installed
make[3]: Leaving directory /home/tom/openwrt-yun/feeds/packages/net/appweb' make[3]: Entering directory /home/tom/openwrt-yun/feeds/packages/net/aprx'
mkdir -p /home/tom/openwrt-yun/dl
echo "Checking out files from the svn repository..."; mkdir -p /home/tom/openwrt-yun/tmp/dl && cd /home/tom/openwrt-yun/tmp/dl && rm -rf aprx-2.00_r421 && [ ! -d aprx-2.00_r421 ] && ( svn help export | grep -q trust-server-cert && svn export --non-interactive --trust-server-cert -r421 http://repo.ham.fi/svn/aprx/trunk/ aprx-2.00_r421 || svn export --non-interactive -r421 http://repo.ham.fi/svn/aprx/trunk/ aprx-2.00_r421 ) && echo "Packing checkout..." && /bin/tar cfj /home/tom/openwrt-yun/tmp/dl/aprx-2.00_r421.tar.bz2 aprx-2.00_r421 && mv /home/tom/openwrt-yun/tmp/dl/aprx-2.00_r421.tar.bz2 /home/tom/openwrt-yun/dl/ && rm -rf aprx-2.00_r421;
svn: OPTIONS of 'http://repo.ham.fi/svn/aprx/trunk': Could not read status line: connection was closed by server (http://repo.ham.fi)
make[3]: *** [/home/tom/openwrt-yun/dl/aprx-2.00_r421.tar.bz2] Error 1
make[3]: Leaving directory /home/tom/openwrt-yun/feeds/packages/net/aprx' make[2]: *** [package/feeds/packages/aprx/compile] Error 2 make[2]: Leaving directory /home/tom/openwrt-yun'
make[1]: *** [/home/tom/openwrt-yun/staging_dir/target-mips_r2_uClibc-0.9.33.2/stamp/.package_compile] Error 2
make[1]: Leaving directory `/home/tom/openwrt-yun'
make: *** [world] Error 2
miner_tom:
make package/feeds/packages/aprx/clean V=s
make package/feeds/packages/aprx/compile V=s
Ran for a couple of hours then blew up because the low power blue tooth "node-bleno-0.1.8" failed to compile. I tried compiling it seperately with "make package/feeds/packages/node-bleno/complile V=s" but got the following failure.
if I went into "make menuconfig" and disabled blue tooth capabilities would this help to get me through the build?
I don't believe that there was anything wrong with the download of bleno-0.1.8.tgz because I went to a repository and manually downloaded it, put it into the dl directory and attempted to manually compile it. the same error occured. Something is wrong (I am guessing, with the make file).
Using hypervisor (virtaul box) compare with bear metal will lost % performance, and different type hypervisor will be vary. Worst case you got hit by 80%
So far I have had to uninstall, as per your instruction, "node-ws", "node-noble" and "node-socket.io" because at each of these compile points, the compile stopped.
Compiling now but I fully expect the compile to fail at another "node" point.
Does this type of failure suggest a pattern to you?
Hi, I may have actually succeeded in building the software. I am not going to say that it was easy but the compile did finish without giving me an error message.
My question is, did it really finish successfully? There are a whole bunch of .bin files in the /bin directory that all seem to have the correct timestamp but I would not know which one of them to load?
