That is the contents of the power shell after Arduino IDE became stable:
Versão: 2.1.1
Data: 2023-06-30T16:04:40.277Z
Versão do CLI : 0.32.3Copyright © 2023 Arduino SA [undefined]
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.1
Starting backend process. PID: 5992
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Projetos/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-18T19:37:32.641Z root INFO Backend Object.initialize: 5.8 ms [Finished 2.072 s after backend start]
2023-07-18T19:37:32.641Z root INFO Backend Object.configure: 4.7 ms [Finished 2.072 s after backend start]
2023-07-18T19:37:32.641Z root INFO Backend MessagingContribution.onStart: 1.9 ms [Finished 2.072 s after backend start]
2023-07-18T19:37:32.642Z root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 2.120 s after backend start]
2023-07-18T19:37:32.643Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.120 s after backend start]
2023-07-18T19:37:32.645Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 2.120 s after backend start]
2023-07-18T19:37:32.646Z root INFO Backend PluginLocalizationBackendContribution.initialize: 48.5 ms [Finished 2.121 s after backend start]
2023-07-18T19:37:32.646Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 2.121 s after backend start]
2023-07-18T19:37:32.648Z root INFO Backend ElectronTokenBackendContribution.configure: 1.6 ms [Finished 2.123 s after backend start]
2023-07-18T19:37:32.648Z config INFO >>> Initializing CLI configuration...
2023-07-18T19:37:32.649Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 2.123 s after backend start]
2023-07-18T19:37:32.649Z root INFO Backend ConfigServiceImpl.onStart: 1.2 ms [Finished 2.124 s after backend start]
2023-07-18T19:37:32.650Z config INFO Loading CLI configuration from c:\Users\Projetos\.arduinoIDE\arduino-cli.yaml...
2023-07-18T19:37:32.651Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 2.125 s after backend start]
2023-07-18T19:37:32.652Z root INFO Backend ArduinoDaemonImpl.onStart: 1.4 ms [Finished 2.126 s after backend start]
2023-07-18T19:37:32.652Z root INFO Backend NodeFileUploadService.configure: 2.8 ms [Finished 2.127 s after backend start]
2023-07-18T19:37:32.652Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-18T19:37:32.653Z discovery-log INFO start
2023-07-18T19:37:32.653Z discovery-log INFO start new deferred
2023-07-18T19:37:32.653Z root INFO Backend HostedPluginLocalizationService.initialize: 0.7 ms [Finished 2.128 s after backend start]
2023-07-18T19:37:32.653Z root INFO Backend BoardDiscovery.onStart: 1.8 ms [Finished 2.129 s after backend start]
2023-07-18T19:37:32.654Z root INFO Backend FileDownloadEndpoint.configure: 1.3 ms [Finished 2.130 s after backend start]
2023-07-18T19:37:32.654Z root INFO Backend AuthenticationServiceImpl.onStart: 0.5 ms [Finished 2.132 s after backend start]
2023-07-18T19:37:32.654Z root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 2.132 s after backend start]
2023-07-18T19:37:32.656Z root INFO Backend HostedPluginReader.configure: 1.0 ms [Finished 2.134 s after backend start]
2023-07-18T19:37:32.656Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.134 s after backend start]
2023-07-18T19:37:32.657Z root INFO Backend PlotterBackendContribution.configure: 1.3 ms [Finished 2.136 s after backend start]
2023-07-18T19:37:32.660Z root INFO Theia app listening on http://localhost:57428.
2023-07-18T19:37:32.661Z root INFO Finished starting backend application: 7.5 ms [Finished 2.140 s after backend start]
2023-07-18T19:37:32.662Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Projetos/.arduinoIDE/plugins does not exist.
2023-07-18T19:37:32.671Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Projetos/.arduinoIDE/extensions does not exist.
2023-07-18T19:37:32.672Z root WARN The local plugin referenced by local-dir:C:\Users\Projetos\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Comum\CONSENG\_Clientes\4Ground\_DEV\VOXfreezer\SW\VOXfreezer_v1xx
isTempSketch: false. Input was c:\Comum\CONSENG\_Clientes\4Ground\_DEV\VOXfreezer\SW\VOXfreezer_v1xx\Apoio.ino
2023-07-18T19:37:32.707Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.708Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-07-18T19:37:32.710Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.713Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-07-18T19:37:32.713Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.721Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-07-18T19:37:32.724Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.727Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-07-18T19:37:32.738Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.738Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-07-18T19:37:32.738Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-07-18T19:37:32.739Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.739Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-07-18T19:37:32.739Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-07-18T19:37:32.739Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-07-18T19:37:32.740Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.740Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-07-18T19:37:32.740Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-07-18T19:37:32.741Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.741Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-07-18T19:37:32.741Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-07-18T19:37:32.742Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-07-18T19:37:32.742Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.742Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-07-18T19:37:32.742Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-07-18T19:37:32.743Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.743Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-07-18T19:37:32.743Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-07-18T19:37:32.744Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-07-18T19:37:32.744Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.744Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-07-18T19:37:32.745Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-18T19:37:32.745Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-07-18T19:37:32.757Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://dl.espressif.com/dl/package_esp32_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"]},"daemon":{"port":"50051"},"directories":{"data":"c:\\Users\\Projetos\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\Projetos\\Documents\\Arduino"},"ide":{"bundled":false,"portable":false},"library":{"enable_unsafe_install":false},"locale":"pt-br","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-18T19:37:32.775Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-18T19:37:32.780Z config INFO Loaded the CLI configuration.
2023-07-18T19:37:32.834Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Projetos/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Projetos/Documents/Arduino","additionalUrls":["https://dl.espressif.com/dl/package_esp32_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"],"network":"none","locale":"pt-br"}
2023-07-18T19:37:32.835Z config INFO Validating the CLI configuration...
2023-07-18T19:37:32.842Z config INFO The CLI config is valid.
2023-07-18T19:37:32.845Z config INFO <<< Initialized the CLI configuration.
2023-07-18T19:37:32.864Z root INFO Resolve plugins list: 213.5 ms [Finished 2.344 s after backend start]
2023-07-18T19:37:32.873Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 8.8 ms [Finished 2.353 s after backend start]
2023-07-18T19:37:32.877Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 4.5 ms [Finished 2.358 s after backend start]
2023-07-18T19:37:32.892Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 15.0 ms [Finished 2.373 s after backend start]
2023-07-18T19:37:32.896Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 3.7 ms [Finished 2.376 s after backend start]
2023-07-18T19:37:32.898Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.7 ms [Finished 2.378 s after backend start]
2023-07-18T19:37:33.020Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 121.8 ms [Finished 2.500 s after backend start]
2023-07-18T19:37:33.059Z daemon INFO INFO[0000] Using config file: c:\Users\Projetos\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:57429
{"IP":"127.0.0.1","Port":"57429"}
2023-07-18T19:37:33.061Z daemon INFO Daemon is running.
2023-07-18T19:37:33.213Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 192.9 ms [Finished 2.693 s after backend start]
2023-07-18T19:37:33.223Z daemon INFO INFO[0000] Loading hardware from: c:\Users\Projetos\AppData\Local\Arduino15\packages
2023-07-18T19:37:33.372Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 159.2 ms [Finished 2.852 s after backend start]
2023-07-18T19:37:33.373Z daemon INFO INFO[0000] Loading package arduino from: C:\Users\Projetos\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.2\\installed.json" signatureFile="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.2\\installed.json.sig"
INFO[0000] Loaded platform platform="arduino:mbed_rp2040@4.0.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\Projetos\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\Projetos\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:arm-none-eabi-gcc@7-2017q4"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool tool="arduino:bossac@1.9.1-arduino2"
INFO[0000] Loaded tool tool="arduino:dfu-util@0.10.0-arduino1"
INFO[0000] Loaded tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0000] Loaded tool tool="arduino:openocd@0.11.0-arduino2"
INFO[0000] Loaded tool tool="arduino:rp2040tools@1.0.6"
INFO[0000] Loading package builtin from: C:\Users\Projetos\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\Projetos\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\Projetos\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.5"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.3"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.5"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.10.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.12.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.9.1"
INFO[0000] Loading package esp32 from: C:\Users\Projetos\AppData\Local\Arduino15\packages\esp32\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\installed.json" signatureFile="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\installed.json.sig"
INFO[0000] Loaded platform platform="esp32:esp32@2.0.10"
INFO[0000] Checking existence of 'tools' path: C:\Users\Projetos\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loading tools from dir: C:\Users\Projetos\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loaded tool tool="esp32:ESP32LittleFS@tool"
INFO[0000] Loaded tool tool="esp32:esptool_py@4.5.1"
INFO[0000] Loaded tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0000] Loaded tool tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0000] Loaded tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0000] Loaded tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loaded tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0000] Loading package rp2040 from: C:\Users\Projetos\AppData\Local\Arduino15\packages\rp2040\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.3.0\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.3.0\\installed.json" signatureFile="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.3.0\\installed.json.sig"
2023-07-18T19:37:33.479Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 107.2 ms [Finished 2.959 s after backend start]
2023-07-18T19:37:33.480Z daemon INFO INFO[0000] Loaded platform platform="rp2040:rp2040@3.3.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\Projetos\AppData\Local\Arduino15\packages\rp2040\tools
INFO[0000] Loading tools from dir: C:\Users\Projetos\AppData\Local\Arduino15\packages\rp2040\tools
INFO[0000] Loaded tool tool="rp2040:pqt-elf2uf2@1.5.0-b-c7bab52"
INFO[0000] Loaded tool tool="rp2040:pqt-gcc@1.5.0-b-c7bab52"
INFO[0000] Loaded tool tool="rp2040:pqt-mklittlefs@1.5.0-b-c7bab52"
INFO[0000] Loaded tool tool="rp2040:pqt-openocd@1.5.0-b-c7bab52"
INFO[0000] Loaded tool tool="rp2040:pqt-picotool@1.5.0-b-03f2812"
INFO[0000] Loaded tool tool="rp2040:pqt-pioasm@1.5.0-b-c7bab52"
INFO[0000] Loaded tool tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
INFO[0000] Checking signature index="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified." index="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_esp32_index.json" signatureFile="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig"
INFO[0000] Checking signature error="opening signature file: open c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_rp2040_index.json.sig: The system cannot find the file specified." index="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_rp2040_index.json" signatureFile="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\package_rp2040_index.json.sig"
INFO[0000] Searching tools required for platform rp2040:rp2040@3.3.0
INFO[0000] Required tool tool="rp2040:pqt-elf2uf2@1.5.0-b-c7bab52"
INFO[0000] Required tool tool="rp2040:pqt-gcc@1.5.0-b-c7bab52"
INFO[0000] Required tool tool="rp2040:pqt-mklittlefs@1.5.0-b-c7bab52"
INFO[0000] Required tool tool="rp2040:pqt-openocd@1.5.0-b-c7bab52"
INFO[0000] Required tool tool="rp2040:pqt-picotool@1.5.0-b-03f2812"
INFO[0000] Required tool tool="rp2040:pqt-pioasm@1.5.0-b-c7bab52"
INFO[0000] Required tool tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
INFO[0000] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.3.0\\libraries" location=platform
2023-07-18T19:37:33.488Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.2\\libraries" location=platform
2023-07-18T19:37:33.562Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 82.9 ms [Finished 3.042 s after backend start]
2023-07-18T19:37:33.563Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\libraries" location=platform
INFO[0000] Loading libraries index file index="c:\\Users\\Projetos\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-18T19:37:33.634Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 72.1 ms [Finished 3.115 s after backend start]
2023-07-18T19:37:33.709Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 74.3 ms [Finished 3.189 s after backend start]
2023-07-18T19:37:33.808Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 99.2 ms [Finished 3.288 s after backend start]
2023-07-18T19:37:33.809Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="c:\\Users\\Projetos\\Documents\\Arduino\\libraries" location=user
2023-07-18T19:37:33.893Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 85.3 ms [Finished 3.374 s after backend start]
2023-07-18T19:37:33.923Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 29.1 ms [Finished 3.403 s after backend start]
2023-07-18T19:37:34.007Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 84.5 ms [Finished 3.487 s after backend start]
2023-07-18T19:37:34.087Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 79.5 ms [Finished 3.567 s after backend start]
2023-07-18T19:37:34.173Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 86.5 ms [Finished 3.653 s after backend start]
2023-07-18T19:37:34.258Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 85.0 ms [Finished 3.738 s after backend start]
2023-07-18T19:37:34.312Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 54.0 ms [Finished 3.792 s after backend start]
2023-07-18T19:37:34.380Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 67.7 ms [Finished 3.860 s after backend start]
2023-07-18T19:37:34.411Z root INFO Deploy plugins list: 213.5 ms [Finished 3.861 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-07-18T19:37:35.714Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 254.5 ms [Finished 2.896 s after frontend start]
2023-07-18T19:37:36.041Z discovery-log INFO start request start watch
2023-07-18T19:37:36.041Z discovery-log INFO start requested start watch
2023-07-18T19:37:36.043Z discovery-log INFO start resolved watching
2023-07-18T19:37:36.051Z daemon INFO INFO[0003] starting discovery rp2040 process
INFO[0003] starting discovery builtin:serial-discovery process
INFO[0003] starting discovery builtin:mdns-discovery process
INFO[0003] starting discovery builtin:dfu-discovery process
2023-07-18T19:37:36.064Z daemon INFO INFO[0003] started discovery builtin:dfu-discovery process
INFO[0003] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:dfu-discovery
2023-07-18T19:37:36.076Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Comum\CONSENG\_Clientes\4Ground\_DEV\VOXfreezer\SW\VOXfreezer_v1xx\Apoio.ino>, response: <c:\Comum\CONSENG\_Clientes\4Ground\_DEV\VOXfreezer\SW\VOXfreezer_v1xx>.
2023-07-18T19:37:36.081Z daemon INFO INFO[0003] started discovery rp2040 process
INFO[0003] sending command HELLO 1 "arduino-cli 0.32.3" to discovery rp2040
2023-07-18T19:37:36.084Z daemon INFO INFO[0003] started discovery builtin:serial-discovery process
INFO[0003] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:serial-discovery
2023-07-18T19:37:36.100Z daemon INFO INFO[0003] started discovery builtin:mdns-discovery process
INFO[0003] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:mdns-discovery
2023-07-18T19:37:36.116Z daemon INFO INFO[0003] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0003] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0003] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2023-07-18T19:37:36.136Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 305.7 ms [Finished 3.357 s after frontend start]
2023-07-18T19:37:36.162Z daemon INFO INFO[0003] from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1
INFO[0003] sending command START_SYNC to discovery builtin:dfu-discovery
INFO[0003] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0003] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0003] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM13
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM10
INFO[0003] from discovery builtin:serial-discovery received message type: add, port: COM11
INFO[0003] from discovery builtin:dfu-discovery received message type: start_sync, message: OK
2023-07-18T19:37:36.192Z root INFO Start frontend contributions: 817.5 ms [Finished 3.371 s after frontend start]
2023-07-18T19:37:36.193Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-07-18T19:37:36.219Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-07-18T19:37:36.221Z root INFO >>> Restoring the layout state...
2023-07-18T19:37:36.223Z root INFO ------- SERIALIZED LAYOUT DATA -------
2023-07-18T19:37:36.231Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/VOXfreezer_v1xx.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":99,\"column\":48},\"position\":{\"lineNumber\":99,\"column\":48}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":69,\"column\":1},\"firstPositionDeltaTop\":-12},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1072,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/EepromSerial.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":89,\"column\":4},\"position\":{\"lineNumber\":89,\"column\":29}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":76,\"column\":1},\"firstPositionDeltaTop\":-7},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":148,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/EepromSerial.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":869,\"column\":37},\"position\":{\"lineNumber\":869,\"column\":37}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":851,\"column\":1},\"firstPositionDeltaTop\":-5},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":981,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/Apoio.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":137,\"column\":123},\"position\":{\"lineNumber\":137,\"column\":123}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":126,\"column\":1},\"firstPositionDeltaTop\":-17},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":309,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/Signage.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":652,\"column\":10},\"position\":{\"lineNumber\":652,\"column\":17}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":641,\"column\":1},\"firstPositionDeltaTop\":-17},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":921,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/SensorPorta.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":43,\"column\":46},\"position\":{\"lineNumber\":43,\"column\":46}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":3,\"column\":1},\"firstPositionDeltaTop\":-4},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":155,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/Controle.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":113,\"column\":78},\"position\":{\"lineNumber\":113,\"column\":78}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":97,\"column\":1},\"firstPositionDeltaTop\":-7},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":715,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/Audio.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":326,\"column\":45},\"position\":{\"lineNumber\":327,\"column\":24}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":295,\"column\":1},\"firstPositionDeltaTop\":-7},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":391,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/ESP32pinout.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":14,\"column\":78},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":53,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/HDvirtual.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":191,\"column\":62},\"position\":{\"lineNumber\":191,\"column\":62}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":181,\"column\":1},\"firstPositionDeltaTop\":-12},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":414,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/SDCARD.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":59,\"column\":1},\"position\":{\"lineNumber\":59,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":32,\"column\":1},\"firstPositionDeltaTop\":-18},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":499,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/CRC32.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":4,\"column\":84},\"position\":{\"lineNumber\":9,\"column\":85}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":30,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/PROGMEM/AudioMP3.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":21,\"column\":1},\"position\":{\"lineNumber\":21,\"column\":8}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":8,\"column\":1},\"firstPositionDeltaTop\":-10},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":18320,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/AINDA_NAO_REVISADO/FabricaBLK2.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":157,\"column\":1},\"position\":{\"lineNumber\":267,\"column\":2}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":241,\"column\":1},\"firstPositionDeltaTop\":-5},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":450,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/AINDA_NAO_REVISADO/FabricaBLK1.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":467,\"column\":5},\"position\":{\"lineNumber\":467,\"column\":27}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":455,\"column\":1},\"firstPositionDeltaTop\":-2},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":691,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/AINDA_NAO_REVISADO/EepromConfigBLK1.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":1081,\"column\":10},\"position\":{\"lineNumber\":1081,\"column\":17}}],\"viewState\":{\"scrollLeft\":93,\"firstPosition\":{\"lineNumber\":1081,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1811,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":1,"kind":"navigatable","uri":"file:///c%3A/Comum/CONSENG/_Clientes/4Ground/_DEV/VOXfreezer/SW/VOXfreezer_v1xx/AINDA_NAO_REVISADO/Ethernet.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":195,\"column\":50},\"position\":{\"lineNumber\":195,\"column\":70}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":188,\"column\":1},\"firstPositionDeltaTop\":-4},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":227,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":638,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.20202020202020202,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":0.2,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Pesquisar\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Diferenciar Maiúsculas de Minúsculas\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Coincidir Palavra Inteira\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Usar Expressão Regular\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Incluir Arquivos Ignorados\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"templateValor\\\",\\\"replaceTerm\\\":\\\"FMT_SHOW_PARAM_VALOR\\\",\\\"showReplaceField\\\":true,\\\"searchHistoryState\\\":{\\\"history\\\":[\\\"CONFIGesp_CONST_VALOR_ESTRUTURA_VERSAO\\\",\\\"templateSeg\\\",\\\"controlSetupHW\\\",\\\"%d\\\",\\\"%dcccccccccccccc\\\",\\\"HARDserial_NOME_WATCHDOG_TIMER_SEG\\\",\\\"apoioEnviaRespostaSucesso\\\",\\\"strncpy\\\",\\\"CONFIGesp_DO_RESET\\\",\\\"CONFIGesp_DO_FACTORY_RESTORE\\\",\\\"CONFIGesp_DO_NOME_FACTORY_RESTORE\\\",\\\"CONFIGesp_DO_NOME_RESET\\\",\\\"HARDserial_DO_RESET\\\",\\\"executarColdboot\\\",\\\"HARDserial_DO_FACTORY_RESTORE\\\",\\\"doFactoryRestore\\\",\\\"ORIGEM_WIFI_CONFIG\\\",\\\"nCFGSERIAL-ERRO: origem do comando invalida: \\\\\\\\n\\\\\\\\n\\\",\\\"nCFGSERIAL-ERRO: origem do comando invalida \\\\\\\\n\\\\\\\\n\\\",\\\"provideWRU\\\",\\\"macAddressLocalTexto\\\",\\\"eepromConfigESP32changed\\\",\\\"serialDOfactoryRestore\\\",\\\"templateValor\\\"],\\\"index\\\":23},\\\"replaceHistoryState\\\":{\\\"history\\\":[\\\"FMT_SHOW_PARAM_SEG\\\",\\\"CONFIGesp_DO_RESET\\\",\\\"HARDserial__DO_RESET\\\",\\\"HARDserial_DO_RESET\\\",\\\"HARDserial_DO_FACTORY_RESTORE\\\",\\\"HARDserial_DO__FACTORY_RESTORE\\\",\\\"HARDserial_DO_NOME_FACTORY_RESTORE\\\",\\\"HARDserial_DO_NOME_RESET\\\",\\\"executaSoftReset()\\\",\\\"executaSoftReset\\\",\\\"serialDO\\\",\\\"serialDOre\\\",\\\"serialDOfactoru\\\",\\\"serialDOfactor\\\",\\\"serialDOfactory\\\",\\\"serialDOfactoryRes\\\",\\\"serialDOfactoryRestore\\\",\\\"nCFGSERIAL-ERRO: origem do comando invalida \\\\\\\\n\\\\\\\\n\\\",\\\"nCFGSERIAL-ERRO: origem do comando invalida: %u \\\\\\\\n\\\\\\\\n\\\",\\\"FMT_SHOW_PARAM_VALOR\\\"],\\\"index\\\":19},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Pesquisar\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":342},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"outputView"}
2023-07-18T19:37:36.236Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2023-07-18T19:37:36.237Z daemon INFO INFO[0003] from discovery rp2040 received message type: hello, message: OK, protocol version: 1
INFO[0003] sending command START_SYNC to discovery rp2040
INFO[0003] from discovery rp2040 received message type: start_sync, message: OK
2023-07-18T19:37:36.247Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM10","label":"COM10","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-18T19:37:36.250Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM11","label":"COM11","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-18T19:37:36.252Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM13","label":"COM13","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-07-18T19:37:36.517Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5] Waiting for backend deployment: 152.4 ms [Finished 3.513 s after frontend start]
2023-07-18T19:37:36.518Z root INFO Attached boards and available ports changed:
2023-07-18T19:37:36.519Z root INFO - New port is available on COM10 Serial Port
2023-07-18T19:37:36.520Z root INFO ------------------------------------------
2023-07-18T19:37:36.526Z root INFO Attached boards and available ports changed:
2023-07-18T19:37:36.526Z root INFO - New port is available on COM11 Serial Port
2023-07-18T19:37:36.527Z root INFO ------------------------------------------
2023-07-18T19:37:36.529Z root INFO Attached boards and available ports changed:
2023-07-18T19:37:36.529Z root INFO - New port is available on COM13 Serial Port
2023-07-18T19:37:36.530Z root INFO ------------------------------------------
2023-07-18T19:37:37.118Z root INFO [hosted-plugin: 3568] PLUGIN_HOST(3568) starting instance
2023-07-18T19:37:37.620Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5] Sync of 21 plugins: 1335.2 ms [Finished 4.848 s after frontend start]
2023-07-18T19:37:40.690Z root INFO <<< The layout has been successfully restored.
2023-07-18T19:37:43.178Z root INFO Initialize the workbench layout: 4485.0 ms [Finished 7.918 s after frontend start]
2023-07-18T19:37:43.181Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-07-18T19:37:43.183Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][marus25.cortex-debug]: Loaded contributions.
2023-07-18T19:37:43.188Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][arduino.vscode-arduino-tools]: Loaded contributions.
2023-07-18T19:37:43.193Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.cpp]: Loaded contributions.
2023-07-18T19:37:43.193Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.json]: Loaded contributions.
2023-07-18T19:37:43.196Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.json-language-features]: Loaded contributions.
2023-07-18T19:37:43.197Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-07-18T19:37:43.197Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-07-18T19:37:43.205Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-07-18T19:37:43.210Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-07-18T19:37:43.211Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-07-18T19:37:43.212Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-07-18T19:37:43.213Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-07-18T19:37:43.217Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-07-18T19:37:43.219Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-07-18T19:37:43.221Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-07-18T19:37:43.222Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-07-18T19:37:43.223Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-07-18T19:37:43.224Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-07-18T19:37:43.225Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-07-18T19:37:43.225Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-07-18T19:37:43.226Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-07-18T19:37:43.227Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5] Load contributions of 21 plugins: 2484.1 ms [Finished 10.404 s after frontend start]
2023-07-18T19:37:43.338Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-07-18T19:37:43.339Z root WARN a registered grammar configuration for 'cpp' language is overridden
Checking for update
2023-07-18T19:37:45.186Z root INFO Replace loading indicator with ready workbench UI (animation): 1058.9 ms [Finished 11.465 s after frontend start]
2023-07-18T19:37:45.186Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-07-18T19:37:45.225Z root INFO Frontend application start: 9526.1 ms [Finished 14.662 s after backend start]
2023-07-18T19:37:45.457Z daemon INFO INFO[0012] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0012] Required tool tool="esp32:esptool_py@4.5.1"
INFO[0012] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0012] Required tool tool="esp32:mkspiffs@0.2.3"
INFO[0012] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0012] Required tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0012] Required tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0012] Required tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0012] Required tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0012] Required tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0012] Required tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-18T19:37:45.623Z daemon INFO INFO[0012] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
Update for version 2.1.1 is not available (latest version: 2.1.1, downgrade is allowed).
2023-07-18T19:37:45.935Z daemon INFO INFO[0012] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:46.057Z daemon INFO INFO[0013] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0013] Required tool tool="esp32:esptool_py@4.5.1"
INFO[0013] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0013] Required tool tool="esp32:mkspiffs@0.2.3"
INFO[0013] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0013] Required tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0013] Required tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0013] Required tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0013] Required tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0013] Required tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0013] Required tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-18T19:37:46.228Z root INFO [hosted-plugin: 3568] PLUGIN_HOST(3568): PluginManagerExtImpl/init()
PLUGIN_HOST(3568): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(3568): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(3568): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-07-18T19:37:46.928Z root ERROR ---- !!!SLOW!!! DURATION: search took 1743.659 ms. Args: [{"type":"Updatable"}] ----
2023-07-18T19:37:46.961Z daemon INFO INFO[0014] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0014] Required tool tool="esp32:esptool_py@4.5.1"
INFO[0014] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0014] Required tool tool="esp32:mkspiffs@0.2.3"
2023-07-18T19:37:46.962Z daemon INFO INFO[0014] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
INFO[0014] Required tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0014] Required tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0014] Required tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0014] Required tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0014] Required tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0014] Required tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-18T19:37:47.120Z root INFO [hosted-plugin: 3568] PLUGIN_HOST(3568): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-07-18T19:37:47.146Z daemon INFO INFO[0014] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:47.147Z daemon INFO INFO[0014] Required tool tool="esp32:mkspiffs@0.2.3"
2023-07-18T19:37:47.638Z root INFO [hosted-plugin: 3568] PLUGIN_HOST(3568): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
2023-07-18T19:37:47.683Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][marus25.cortex-debug]: Started plugin.
2023-07-18T19:37:47.685Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][arduino.vscode-arduino-tools]: Started plugin.
2023-07-18T19:37:47.686Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.cpp]: Started plugin.
2023-07-18T19:37:47.691Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.json]: Started plugin.
2023-07-18T19:37:47.692Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][vscode.json-language-features]: Started plugin.
2023-07-18T19:37:47.693Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-07-18T19:37:47.694Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-07-18T19:37:47.694Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-07-18T19:37:47.695Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-07-18T19:37:47.696Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-07-18T19:37:47.702Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-07-18T19:37:47.703Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-07-18T19:37:47.704Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-07-18T19:37:47.704Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-07-18T19:37:47.709Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-07-18T19:37:47.713Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-07-18T19:37:47.714Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-07-18T19:37:47.717Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-07-18T19:37:47.717Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-07-18T19:37:47.718Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-07-18T19:37:47.718Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-07-18T19:37:47.761Z root INFO [hosted-plugin: 3568] PLUGIN_HOST(3568): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-07-18T19:37:47.822Z root INFO [hosted-plugin: 3568] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-07-18T19:37:47.828Z root INFO [hosted-plugin: 3568] GDB server console created
2023-07-18T19:37:47.858Z root INFO [f199faa3-7fa2-4455-a709-60e8379907d5] Start of 21 plugins: 4668.9 ms [Finished 15.085 s after frontend start]
2023-07-18T19:37:47.893Z daemon INFO INFO[0014] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:47.894Z daemon INFO INFO[0014] Required tool tool="esp32:mkspiffs@0.2.3"
2023-07-18T19:37:47.934Z daemon INFO INFO[0014] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:47.935Z daemon INFO INFO[0014] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2023-07-18T19:37:48.001Z root INFO Starting language server: esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none
2023-07-18T19:37:48.197Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2023-07-18T19:37:48.473Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
INFO[0015] Required tool tool="esp32:esptool_py@4.5.1"
INFO[0015] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0015] Required tool tool="esp32:mkspiffs@0.2.3"
INFO[0015] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2023-07-18T19:37:48.474Z daemon INFO INFO[0015] Required tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0015] Required tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
INFO[0015] Required tool tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
INFO[0015] Required tool tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0015] Required tool tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
INFO[0015] Required tool tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-18T19:37:48.511Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.513Z daemon INFO INFO[0015] Required tool tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2023-07-18T19:37:48.601Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.602Z daemon INFO INFO[0015] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2023-07-18T19:37:48.642Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.643Z daemon INFO INFO[0015] Required tool tool="esp32:mkspiffs@0.2.3"
2023-07-18T19:37:48.745Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.746Z daemon INFO INFO[0015] Required tool tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2023-07-18T19:37:48.783Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.784Z daemon INFO INFO[0015] Required tool tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2023-07-18T19:37:48.800Z daemon INFO INFO[0015] Required tool tool="arduino:dfu-util@0.11.0-arduino5"
2023-07-18T19:37:48.801Z daemon INFO INFO[0015] Required tool tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0015] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0015] Adding libraries dir dir="C:\\Users\\Projetos\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\libraries" location=platform
2023-07-18T19:37:48.803Z daemon INFO INFO[0015] Adding libraries dir dir="c:\\Users\\Projetos\\Documents\\Arduino\\libraries" location=user
2023-07-18T19:37:54.886Z daemon INFO INFO[0021] Resolving include EEPROM.h for arch esp32
INFO[0021] found better lib lib=EEPROM prio=64C
2023-07-18T19:37:58.428Z daemon INFO INFO[0025] Resolving include ArduinoJson.h for arch esp32
INFO[0025] found better lib lib=ArduinoJson prio=643
2023-07-18T19:38:02.533Z daemon INFO INFO[0029] Resolving include Arduino_CRC32.h for arch esp32
INFO[0029] found better lib lib=Arduino_CRC32 prio=643
2023-07-18T19:38:06.686Z daemon INFO INFO[0033] Resolving include Ticker.h for arch esp32
INFO[0033] found better lib lib=Ticker prio=64C
2023-07-18T19:38:11.078Z daemon INFO INFO[0038] Resolving include FS.h for arch esp32
INFO[0038] found better lib lib=FS prio=64C
2023-07-18T19:38:15.428Z daemon INFO INFO[0042] Resolving include SD.h for arch esp32
INFO[0042] found better lib lib=SD prio=64C
2023-07-18T19:38:19.548Z daemon INFO INFO[0046] Resolving include SPI.h for arch esp32
2023-07-18T19:38:19.549Z daemon INFO INFO[0046] found better lib lib=SPI prio=64C
2023-07-18T19:38:23.853Z daemon INFO INFO[0050] Resolving include LITTLEFS.h for arch esp32
INFO[0050] found better lib lib=LittleFS_esp32 prio=521
2023-07-18T19:38:27.687Z daemon INFO INFO[0054] Resolving include AudioFileSourcePROGMEM.h for arch esp32
INFO[0054] found better lib lib=ESP8266Audio prio=3F5
2023-07-18T19:39:07.126Z daemon INFO INFO[0094] Resolving include SPIFFS.h for arch esp32
INFO[0094] found better lib lib=SPIFFS prio=64C
2023-07-18T19:39:15.819Z daemon INFO INFO[0102] Resolving include HTTPClient.h for arch esp32
INFO[0102] found better lib lib=HTTPClient prio=64C
2023-07-18T19:39:18.768Z daemon INFO INFO[0105] Resolving include WiFiClient.h for arch esp32
INFO[0105] found better lib lib=WiFi prio=3F4
2023-07-18T19:39:21.606Z daemon INFO INFO[0108] Resolving include WiFiClientSecure.h for arch esp32
INFO[0108] found better lib lib=WiFiClientSecure prio=64C
[15372:0718/163931.509:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
