compile image goes wrong
Hello again,
I have another Yun which is upgraded to Firmware 1.6.2. I need the package kmod-ath9k-htc for it, so I compiled an Image with it and get no errors.
When it is installed, the boot Process stucks and i get the following message:
U-Boot 1.1.4-g80b2b7c3-dirty (Feb 22 2016 - 11:48:17)
Arduino Yun (ar9331) U-boot
DRAM:  64 MB
Top of RAM usable for U-Boot at: 84000000
Reserving 143k for U-Boot at: 83fdc000
Reserving 192k for malloc() at: 83fac000
Reserving 44 Bytes for Board Info at: 83fabfd4
Reserving 36 Bytes for Global Data at: 83fabfb0
Reserving 128k for boot params() at: 83f8bfb0
Stack Pointer at: 83f8bf98
Now running in RAM - U-Boot at: 83fdc000
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16777216, sector count = 256
Flash: 16 MB
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   ag7240_enet_initialize...
No valid address in Flash. Using fixed address
: cfg1 0x5 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
athrs26_reg_init_lan
ATHRS26: resetting s26
ATHRS26: s26 reset done
eth1 up
eth0, eth1
autoboot in 4 seconds (type 'ard' to enter u-boot console)...
## Booting image at 9fea0000 ...
   Image Name:   MIPS OpenWrt Linux-3.18.23
   Created:      2016-06-14  17:49:50 UTC
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    1206578 Bytes =  1.2 MB
   Load Address: 80060000
   Entry Point:  80060000
   Verifying Checksum at 0x9fea0040 ...OK
   Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 80060000) ...
## Giving linux memsize in bytes, 67108864
Starting kernel ...
[    0.000000] Linux version 3.18.23 (simon@debian) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r48749) ) #2 Tue Jun 14 19:48:40 CEST 2016
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[    0.000000] SoC: Atheros AR9330 rev 1
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] User-defined physical RAM map:
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03ffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000-0x03ffffff]
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line:  board=YUN console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,14656k(rootfs),1280k(kernel),64k(nvram),64k(art),15936k@0x50000(firmware) rootfstype=squashfs,jffs2 noinitrd mem=64M rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 60676K/65536K available (2932K kernel code, 145K rwdata, 332K rodata, 228K init, 201K bss, 4860K reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[    0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.080000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.090000] NET: Registered protocol family 16
[    0.090000] MIPS: machine is Arduino Yun
[    0.570000] Setting DogStick2 GPIO
[    0.590000] Switched to clocksource MIPS
[    0.590000] NET: Registered protocol family 2
[    0.590000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.590000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.600000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.600000] TCP: reno registered
[    0.600000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.600000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.610000] NET: Registered protocol family 1
[    0.610000] RPC: Registered named UNIX socket transport module.
[    0.610000] RPC: Registered udp transport module.
[    0.610000] RPC: Registered tcp transport module.
[    0.620000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.620000] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.630000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.640000] NFS: Registering the id_resolver key type
[    0.640000] Key type id_resolver registered
[    0.640000] Key type id_legacy registered
[    0.640000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.650000] msgmni has been set to 118
[    0.650000] io scheduler noop registered
[    0.650000] io scheduler deadline registered (default)
[    0.650000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) i{ a AR933X UART
[    0.660000] console [ttyATH0] enabled
[    0.660000] bootconsole [early0] disabled
[    0.670000] m25p80 spi0.0: found w25q128, expected m25p80
[    0.670000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.670000] 7 cmdlinepart partitions found on MTD device spi0.0
[    0.680000] Creating 7 MTD partitions on "spi0.0":
[    0.680000] 0x000000000000-0x000000040000 : "u-boot"
[    0.680000] 0x000000040000-0x000000050000 : "u-boot-env"
[    0.680000] 0x000000050000-0x000000ea0000 : "rootfs"
[    0.690000] mtd: device 2 (rootfs) set to be root filesystem
[    0.690000] 1 squashfs-split partitions found on MTD device rootfs
[    0.690000] 0x000000430000-0x000000ea0000 : "rootfs_data"
[    0.690000] 0x000000ea0000-0x000000fe0000 : "kernel"
[    0.700000] 0x000000fe0000-0x000000ff0000 : "nvram"
[    0.700000] 0x000000ff0000-0x000001000000 : "art"
[    0.700000] 0x000000050000-0x000000fe0000 : "firmware"
[    0.740000] libphy: ag71xx_mdio: probed
[    1.330000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[    1.360000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[    1.950000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[    1.950000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[    1.950000] TCP: cubic registered
[    1.960000] NET: Registered protocol family 17
[    1.960000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.960000] 8021q: 802.1Q VLAN Support v1.8
[    1.970000] Key type dns_resolver registered
[    1.970000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    1.980000] Freeing unused kernel memory: 228K (803b7000 - 803f0000)
/bin/sh: can't resolve symbol 'mallopt' in lib '/bin/sh'.
[    2.950000] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[    2.950000]
[    2.950000] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
[    2.950000]
[   82.370000] random: nonblocking pool is initialized
My .config file is here.
I copyed this from the ImageBuilder to my Buildroot and added my required Package with make menuconfig.
Was it the wrong way? What can I do now to make it run?
EDIT: Maybe there is an easier way to get this package. Like crosscompiling or something. But I don't know how. Maybe someone can explain it.
