I need this code done within the next hour and I can’t figure out the problem (I’m not very experienced and I recieved help on it from someone else)
It is for a MIDI keyboard.
Here is the code:
const byte keyPints = { 15,16,17,18,19,13,13,11,10,9,8,7,6,5,4,3,2};
const byte notes = {0,2,4,5,6,9,11,12,14,16,17,19,21,23,23,24,26,28,29,31,33,35,36,38,40,41,43,45,47,48};
const int keyThreshold = {85, 255, 426, 596, 767, 937, 1024};
const int musicKeyPin = A0; //key select alligator clip input pin
const int numberOfKeys = 17;
boolean keyUp[numberOfKeys];
byte channel = 0; //MIDI channel to send data on
byte octave = 3; //two below Middle C
byte lookUpOffset, keyOffset, playingKey;
void setup(){
Serial.begin(31250); //MIDI baud rate
for(int i=0; i<numberOfKeys; i++){
pinMode(keyPins*, INPUT_PULLUP);*
_ keyUp = true;_
* playingKey = findKey(); // 1 to 7 is A to G*
* keyOffset = notes[playingKey];*
_ lookUpOffset = 7+ (octave * 12);_
* // setup voice to use*
* controlSend(0, 0, channel); // set bank 0 MSB*
* controlSend(32, 0, channel); // set bank 0 LSB*
* programChange(19); // send voice number - Church Organ*
void loop(){
* boolean key;*
* for(int i=0; i<numberOfKeys; i++){*
_ key = digitalRead(keyPin*);
if(key != keyUp){ //change in key state*
if(keyUp*) {
midiSend(0x90, lookUpNote(i), 127; //note on*
else {
midiSend(0x80, lookUpNote(i), 0; //note off*
keyUp = key;
void midiSend(byte cmd, byte d1, byte d2){
cmd = cmd | channel;
Serial.write(cmd);
Serial.write(d1);
Serial.write(d2);
byte lookUpNote(int i){
byte note;
note = notes + lookUpOffset + keyOffset;
return note;
byte findKey(){ //look up what key we are in
int i = 0;
int clipVoltage = analogRead(musicKeyPin);
while(keyThreshhold < clipVoltage) i++;
i++;
return (byte) i;
void controlSend(byte CCnumber, byte CCdata, byte CCchannel) {
CCchannel |= 0xB0; //convert to Controller message*
* Serial.write(CCchannel);
Serial.write(CCnumber);
Serial.write(CCdata);
void programChange(byte voice){
Serial.write((byte)0xC0 | channel);
Serial.write(voice;
And here is the error:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\g\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10801 -build-path C:\Users\Scot\AppData\Local\Temp\arduino_build_508271 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\g\Documents\Arduino\ActualMIDIfinal\ActualMIDIfinal.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Scot\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10801 -build-path C:\Users\Scot\AppData\Local\Temp\arduino_build_508271 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Scot\Documents\Arduino\ActualMIDIfinal\ActualMIDIfinal.ino
Using board ‘uno’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…_
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\g\AppData\Local\Temp\arduino_build_508271\sketch\ActualMIDIfinal.ino.cpp” -o “nul”
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\g\AppData\Local\Temp\arduino_build_508271\sketch\ActualMIDIfinal.ino.cpp” -o “C:\Users\g\AppData\Local\Temp\arduino_build_508271\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\Scot\AppData\Local\Temp\arduino_build_508271\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\g\AppData\Local\Temp\arduino_build_508271\sketch\ActualMIDIfinal.ino.cpp” -o “C:\Users\g\AppData\Local\Temp\arduino_build_508271\sketch\ActualMIDIfinal.ino.cpp.o”
C:\Users\g\Documents\Arduino\ActualMIDIfinal\ActualMIDIfinal.ino: In function ‘void loop()’:
ActualMIDIfinal:23: error: a function-definition is not allowed here before ‘{’ token
void setup(){
_ ^
ActualMIDIfinal:85: error: expected ‘}’ at end of input
exit status 1
If you could help in fixing this error, along with any other errors that might be there, since it hasn’t gone through all the way, being stopped at that error way at the top of the code.
Also, I hate to be any bit rude, but I’d really like it if I could just get straight up help and not answers like I should learn C and C++ myself first, it will be a life long lesson and it will pay off, and I shouldn’t be asking for help cause I’m so inexperienced (sorry, that’s just what I’ve gotten in past posts from a long time ago when I really needed straight up help). I have learning it on my to do list, but I’m really tight on time. Any straight up edits and help would be greatly appreciated_
