Compile OK 2 days ago, now 2.3.2 won't
I made a sketch a few years ago. It uses a Nano with DS18B20 and 433Mhz receiver connected. Display is an ST7735 TFT. All was fine but there was an intermittent power connection so I pulled it apart to fix it.
Somehow the magic disappeared and I had to start again. New V3 Nano and new ST7735 display.
After sorting out the wiring, I got graphicstest_kbv running fine. I then recompiled my original sketch and downloaded OK. The screen text loaded, and some data from an outside Nano/DS18b20/433 tx was received.
Once again, the magic stopped! The screen text appeared but no data. Also there was nothing on the Serial monitor.
I tried to re-run graphicstest_kbv but I got multiple error messages about duplicate ADAfruit_GFX libraries amongst other things. I deleted the libraries and reinstalled but gott the same errors even though the folders and files complained about were deleted.
I then went to C:\Users\merid\AppData\Local\Temp\arduino\sketches\
and deleted the sketch C5D0A89903979CFC56C7B73F4C86620C\ which contained \libraries\Adafruit_GFX_Library.
This is a typical error after the folder is recreated:
Adafruit_GFX.cpp.o (symbol from plugin): In function `Adafruit_GFX::writeLine(int, int, int, int, unsigned int)':
I also got erors about the MCUFriend_KBV libraries.
I really can't understand what has changed to cause these errors when it was fine a few days ago.
Paul VK2AHB
After deleting folders, libraries and reinstalling, this is the latest error.
Multiple lines like this:
(.text+0x0): multiple definition of `Adafruit_GFX::setTextSize(unsigned char)'
C:\Users\merid\AppData\Local\Temp\arduino\sketches\C5D0A89903979CFC56C7B73F4C86620C\libraries\TFT\utility\Adafruit_GFX.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Hi @vk2ahb. I'm going to ask you to provide the full verbose output from a compilation.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
  3. Click the "OK" button.
    The "Preferences" dialog will close.
  4. Select Sketch > Verify/Compile from the Arduino IDE menus.
  5. Wait for the compilation to fail.
  6. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  7. Open a forum reply here by clicking the "Reply" button.
  8. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block icon on toolbar
  9. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  10. Move the cursor outside of the code block markup before you add any additional text to your reply.
  11. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    Upload icon on toolbar
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
t has only just started complaining about RadioHead.
I think this all started with starting backups of Documents to OneDrive.
I just loaded graphictest_kbv from Examples, and it did compile and download OK.
loading library from C:\Users\merid\Documents\Arduino\libraries\AceTime: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\Adafruit_GPS_Library: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\LibAPRS_Tracker: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\NeoGPS: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\NeoSWSerial: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\Timezone-1.2.4: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\TinyGPS: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\TinyGPSPlus-master: invalid library: no header files foundloading library from C:\Users\merid\Documents\Arduino\libraries\arduino_943135: invalid library: no header files found
FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for Adafruit_GFX.h: [Adafruit GFX Library@1.11.9]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit GFX Library@1.11.9]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.16.0]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit BusIO@1.16.0]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for RH_ASK.h: [RadioHead@1.122.1]
ResolveLibrary(RH_ASK.h)
  -> candidates: [RadioHead@1.122.1]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for Adafruit_ST7735.h: [Adafruit ST7735 and ST7789 Library@1.10.3]
ResolveLibrary(Adafruit_ST7735.h)
  -> candidates: [Adafruit ST7735 and ST7789 Library@1.10.3]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for OneWire.h: [OneWire@2.3.7]
ResolveLibrary(OneWire.h)
  -> candidates: [OneWire@2.3.7]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Alternatives for DallasTemperature.h: [DallasTemperature@3.9.0]
ResolveLibrary(DallasTemperature.h)
  -> candidates: [DallasTemperature@3.9.0]
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Using cached library dependencies for file: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c
Using cached library dependencies for file: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHCRC (2022_10_17 11_42_59 UTC).cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHCRC.cpp
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHDatagram (2022_10_17 11_42_59 UTC).cpp -o nul
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHDatagram.cpp
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver (2022_10_17 11_42_59 UTC).cpp -o nul
Error while detecting libraries included by C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver (2022_10_17 11_42_59 UTC).cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver.cpp
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp -o nul
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericDriver.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericSPI (2022_10_17 11_42_59 UTC).cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericSPI.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHHardwareSPI (2022_10_17 11_42_59 UTC).cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHHardwareSPI.cpp
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHMesh (2022_10_17 11_42_59 UTC).cpp -o nul
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHMesh.cpp
Using cached library dependencies for file: C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver (2022_10_17 11_42_59 UTC).cpp
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHReliableDatagram (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHReliableDatagram.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHRouter (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHRouter.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHSPIDriver (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHSPIDriver.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_ABZ.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_ASK (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_CC110 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_CC110.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_E32 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_E32.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_LoRaFileOps.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_MRF89 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_MRF89.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF24 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF24.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF51 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF51.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF905 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_NRF905.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF22 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF22.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF24 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF24.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF69 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF69.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF95 (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_RF95.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_Serial (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_TCP (2022_10_17 11_42_59 UTC).cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\RadioHead\RH_TCP.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7735.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7789.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST77xx.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\OneWire\OneWire - Copy.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\OneWire\OneWire.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\DallasTemperature\DallasTemperature - Copy.cpp -o nul
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp -o nul
Generating function prototypes...
C:\Users\merid\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src -IC:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src -IC:\Users\merid\Documents\Arduino\libraries\RadioHead -IC:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library -IC:\Users\merid\Documents\Arduino\libraries\OneWire -IC:\Users\merid\Documents\Arduino\libraries\DallasTemperature C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\sketch\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp -o C:\Users\merid\AppData\Local\Temp\4013124747\sketch_merged.cpp
C:\Users\merid\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\merid\AppData\Local\Temp\4013124747\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\sketch\\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\sketch\\RH_Rx_DHT_garage_ADA_TFT_GPS_DS18B20_Horiz.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit GFX Library"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Compiling library "Adafruit BusIO"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Wire\utility\twi.c.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\Wire\Wire.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\SPI\SPI.cpp.o
Compiling library "RadioHead"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHEncryptedDriver (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHEncryptedDriver (2022_10_17 11_42_59 UTC).cpp.o"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHDatagram (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHDatagram (2022_10_17 11_42_59 UTC).cpp.o"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp.o"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHGenericDriver.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHEncryptedDriver.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHCRC.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHDatagram.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHCRC (2022_10_17 11_42_59 UTC).cpp.o
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHMesh (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHMesh (2022_10_17 11_42_59 UTC).cpp.o"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHGenericSPI (2022_10_17 11_42_59 UTC).cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHHardwareSPI (2022_10_17 11_42_59 UTC).cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHGenericSPI.cpp.o
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHNRFSPIDriver.cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHNRFSPIDriver.cpp.o"
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHHardwareSPI.cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHNRFSPIDriver (2022_10_17 11_42_59 UTC).cpp.o
Using previously compiled file: C:\Users\merid\AppData\Local\Temp\arduino\sketches\74CE489A458BDB2D81AD7CE02643A50D\libraries\RadioHead\RHMesh.cpp.o
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHReliableDatagram (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHReliableDatagram (2022_10_17 11_42_59 UTC).cpp.o"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHRouter (2022_10_17 11_42_59 UTC).cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHRouter (2022_10_17 11_42_59 UTC).cpp.o"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHReliableDatagram.cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHReliableDatagram.cpp.o"
"C:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\merid\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\merid\\Documents\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\merid\\Documents\\Arduino\\libraries\\RadioHead\\RHRouter.cpp" -o "C:\\Users\\merid\\AppData\\Local\\Temp\\arduino\\sketches\\74CE489A458BDB2D81AD7CE02643A50D\\libraries\\RadioHead\\RHRouter.cpp.o"
In file included from C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver (2022_10_17 11_42_59 UTC).cpp:7:0:
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHEncryptedDriver.h:248:2: error: #error "You have included RHEncryptedDriver.h, but not enabled RH_ENABLE_ENCRYPTION_MODULE in RadioHead.h"
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHDatagram (2022_10_17 11_42_59 UTC).cpp:57:6: error: prototype for 'void RHDatagram::waitAvailable()' does not match any in class 'RHDatagram'
In file included from C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHDatagram (2022_10_17 11_42_59 UTC).cpp:6:0:
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHDatagram.h:103:21: error: candidate is: void RHDatagram::waitAvailable(uint16_t)
     void            waitAvailable(uint16_t polldelay = 0);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHDatagram (2022_10_17 11_42_59 UTC).cpp:72:6: error: prototype for 'bool RHDatagram::waitAvailableTimeout(uint16_t)' does not match any in class 'RHDatagram'
 bool RHDatagram::waitAvailableTimeout(uint16_t timeout)
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHDatagram.h:121:21: error: candidate is: bool RHDatagram::waitAvailableTimeout(uint16_t, uint16_t)
     bool            waitAvailableTimeout(uint16_t timeout, uint16_t polldelay = 0);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp:29:6: error: prototype for 'void RHGenericDriver::waitAvailable()' does not match any in class 'RHGenericDriver'
In file included from C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp:6:0:
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHGenericDriver.h:113:29: error: candidate is: virtual void RHGenericDriver::waitAvailable(uint16_t)
     virtual void            waitAvailable(uint16_t polldelay = 0);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHGenericDriver (2022_10_17 11_42_59 UTC).cpp:38:6: error: prototype for 'bool RHGenericDriver::waitAvailableTimeout(uint16_t)' does not match any in class 'RHGenericDriver'
 bool RHGenericDriver::waitAvailableTimeout(uint16_t timeout)
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHGenericDriver.h:132:27: error: candidate is: virtual bool RHGenericDriver::waitAvailableTimeout(uint16_t, uint16_t)
   virtual bool            waitAvailableTimeout(uint16_t timeout, uint16_t polldelay = 0);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHMesh (2022_10_17 11_42_59 UTC).cpp:155:6: error: prototype for 'bool RHMesh::recvfromAck(uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)' does not match any in class 'RHMesh'
 bool RHMesh::recvfromAck(uint8_t* buf, uint8_t* len, uint8_t* source, uint8_t* dest, uint8_t* id, uint8_t* flags)
In file included from C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHMesh (2022_10_17 11_42_59 UTC).cpp:14:0:
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHMesh.h:200:10: error: candidate is: bool RHMesh::recvfromAck(uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)
     bool recvfromAck(uint8_t* buf, uint8_t* len, uint8_t* source = NULL, uint8_t* dest = NULL, uint8_t* id = NULL, uint8_t* flags = NULL, uint8_t* hops = NULL);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHMesh (2022_10_17 11_42_59 UTC).cpp:227:6: error: prototype for 'bool RHMesh::recvfromAckTimeout(uint8_t*, uint8_t*, uint16_t, uint8_t*, uint8_t*, uint8_t*, uint8_t*)' does not match any in class 'RHMesh'
 bool RHMesh::recvfromAckTimeout(uint8_t* buf, uint8_t* len, uint16_t timeout, uint8_t* from, uint8_t* to, uint8_t* id, uint8_t* flags)
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHMesh.h:216:10: error: candidate is: bool RHMesh::recvfromAckTimeout(uint8_t*, uint8_t*, uint16_t, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)
     bool recvfromAckTimeout(uint8_t* buf, uint8_t* len,  uint16_t timeout, uint8_t* source = NULL, uint8_t* dest = NULL, uint8_t* id = NULL, uint8_t* flags = NULL, uint8_t* hops = NULL);
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHRouter (2022_10_17 11_42_59 UTC).cpp:206:6: error: prototype for 'bool RHRouter::recvfromAck(uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)' does not match any in class 'RHRouter'
 bool RHRouter::recvfromAck(uint8_t* buf, uint8_t* len, uint8_t* source, uint8_t* dest, uint8_t* id, uint8_t* flags)
In file included from C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHRouter (2022_10_17 11_42_59 UTC).cpp:14:0:
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHRouter.h:289:10: error: candidate is: bool RHRouter::recvfromAck(uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)
C:\Users\merid\Documents\Arduino\libraries\RadioHead\RHRouter (2022_10_17 11_42_59 UTC).cpp:293:6: error: prototype for 'bool RHRouter::recvfromAckTimeout(uint8_t*, uint8_t*, uint16_t, uint8_t*, uint8_t*, uint8_t*, uint8_t*)' does not match any in class 'RHRouter'
 bool RHRouter::recvfromAckTimeout(uint8_t* buf, uint8_t* len, uint16_t timeout, uint8_t* source, uint8_t* dest, uint8_t* id, uint8_t* flags)
C:\Users\merid\Documents\Arduino\libraries\RadioHead/RHRouter.h:304:10: error: candidate is: bool RHRouter::recvfromAckTimeout(uint8_t*, uint8_t*, uint16_t, uint8_t*, uint8_t*, uint8_t*, uint8_t*, uint8_t*)
Using library Adafruit GFX Library at version 1.11.9 in folder: C:\Users\merid\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit BusIO at version 1.16.0 in folder: C:\Users\merid\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\merid\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
Using library RadioHead at version 1.122.1 in folder: C:\Users\merid\Documents\Arduino\libraries\RadioHead
Using library Adafruit ST7735 and ST7789 Library at version 1.10.3 in folder: C:\Users\merid\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library
Using library OneWire at version 2.3.7 in folder: C:\Users\merid\Documents\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.9.0 in folder: C:\Users\merid\Documents\Arduino\libraries\DallasTemperature
exit status 1
Compilation error: exit status 1
I
Your installation of the "RadioHead" library has been corrupted or tampered with in some manner (maybe by the OneDrive backup restoration system). Note that the filenames shown in the compiler output have this (2022_10_17 11_42_59 UTC) suffix. There are no such filenames in the real library.
You can fix the problem by uninstalling the bad copy of the library and then reinstall a fresh copy of library. I'll provide instructions you can follow to do that:
  1. Select Sketch > Include Library > Manage Libraries... from the Arduino IDE menus to open the "Library Manager" view in the left side panel.
  2. Type RadioHead in the "Filter your search..." field.
  3. Scroll down through the list of libraries until you see the "RadioHead" entry.
  4. Hover the mouse pointer over the "RadioHead" entry.
  5. You will see a ●●● icon appear near the top right corner of the library entry. Click on that icon.
    A context menu will open.
  6. Select "Remove" from the context menu.
    An "Uninstall" dialog will open.
  7. Click the "YES" button in the "Uninstall" dialog to confirm that you want to uninstall the library.
    The dialog will close.
  8. Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    ⓘ Successfully uninstalled library ...
  9. Select the newest version from the dropdown version menu at the bottom of the "RadioHead" entry.
  10. Click the "INSTALL" button at the bottom of the "RadioHead" entry.
  11. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    ⓘ Successfully installed library ...
Re-installed RadioHead library
Reply.txt (153.4 KB)
OK, this is actually progress! It looks like the problem with the "RadioHead" library is now fixed, but you have a similar problem with the "DallasTemperature" and "OneWire" library installation being corrupted. The same technique can be used to fix these as well:
Reinstall "DallasTemperature" Library
  2. Type DallasTemperature in the "Filter your search..." field.
  3. Scroll down through the list of libraries until you see the "DallasTemperature" entry.
  4. Hover the mouse pointer over the "3.9.0 installed" label on the "DallasTemperature" entry.
    The label text will change to "REMOVE".
  5. Click the "REMOVE" label.
  6. Click the "YES" button in the "Uninstall" dialog to confirm that you want to uninstall the library.
  7. Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
  8. Select the newest version from the dropdown version menu at the bottom of the "DallasTemperature" entry.
  9. Click the "INSTALL" button at the bottom of the "DallasTemperature" entry.
  10. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
Reinstall "OneWire" Library
  2. Type OneWire in the "Filter your search..." field.
  3. Scroll down through the list of libraries until you see the "OneWire" entry.
  4. Hover the mouse pointer over the "2.3.7 installed" label on the "OneWire" entry.
  8. Select the newest version from the dropdown version menu at the bottom of the "OneWire" entry.
  9. Click the "INSTALL" button at the bottom of the "OneWire" entry.
After reinstalling the two libraries, try compiling or uploading your sketch again. Hopefully this time it will be successful.
Yes, that fixed it.
COmpiled and uploaded fine. Now to sort out why it isn't receiveing data from the other Arduinos around the house.
Can I do a complete re-install of the IDE, keeping my current sketches?
Paul
Installing the IDE does not move, delete or rename the sketches and libraries in your sketchbook folder but if you are worried you could back it up first
Thanks for your help Bob. Now I just have to get it into the box! Many a time it's been fine on the bench then ...
Paul
Done!
