Compile problem with Nano Every and PU2CLR RDA5807 Library
Working with an Arduino Nano Every. When I try to compile any of the examples from this library I get the following errors listed below.
In file included from c:\users\mike\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
                 from c:\users\mike\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:90,
                 from C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/String.h:31,
                 from C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/IPAddress.h:24,
                 from C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/ArduinoAPI.h:30,
                 from C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/Arduino.h:23,
                 from C:\Users\mike\AppData\Local\Temp\arduino\sketches\4239D71B3DD53B19A3E44A84206853A5\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp:1:
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:236:17: error: expected unqualified-id before 'volatile'
         uint8_t GPIO1 : 2;      //!< General Purpose I/O 1. when gpio_sel=01; 00 = High impedance; 01 = Reserved; 10 = Low; 11 = High
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:236:17: error: expected ')' before 'volatile'
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:237:17: error: expected unqualified-id before 'volatile'
         uint8_t GPIO2 : 2;      //!< General Purpose I/O 2. when gpio_sel=01; 00 = High impedance; 01 = Reserved; 10 = Low; 11 = High
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:237:17: error: expected ')' before 'volatile'
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:238:17: error: expected unqualified-id before 'volatile'
         uint8_t GPIO3 : 2;      //!< General Purpose I/O 1. when gpio_sel=01; 00 = High impedance; 01 = Mono/Stereo indicator (ST); 10 = Low; 11 = High
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:238:17: error: expected ')' before 'volatile'
exit status 1
Compilation error: exit status 1
When I switch to a Uno R4 Minima the compiles with no errors.
Post your source code between code tags.
This is one of the examples sent with the library
    This sketch is useful to check the band setup of the RDA5807 in your location
    | Value | Description                 |
    | 00    | 87–108 MHz (US/Europe)      |
    | 01    | 76–91 MHz (Japan)           |
    | 10    | 76–108 MHz (world wide)     |
    | 11    | 65 –76 MHz (East Europe) or 50-65MHz (see bit 9 of gegister 0x06) |
    To use this aplication, please select the Arduino IDE Serial Monitor.
    Type ? to see the instructions.
    Arduino Pro Mini and RDA5807 wire up
    | Device  RDA5807 |  Arduino Pin  |
    | RESET           |     14/A0     |
    | SDIO            |     A4        |
    | SCLK            |     A5        |
  ATTENTION:
   Please, avoid using the computer connected to the mains during testing. Used just the battery of your computer.
   This sketch was tested on ATmega328 based board. If you are not using a ATmega328, please check the pins of your board.
   By Ricardo Lima Caratti, 2023.
#include <RDA5807.h>
#define RESET_PIN 14 // On Arduino Atmega328 based board, this pin is labeled as A0 (14 means digital pin instead analog)
#define MAX_DELAY_STATUS 5000
#define YOUR_LOCAL_STATION 8990  // Local station with good RDS service (Example: 89,90Mhz)
long rds_elapsed = millis();
long status_elapsed = millis();
uint8_t showrRdsInfo = 3; // Default: show RDS time.
char *bandTable[] = { (char *) "0 - 87–108 MHz (US/Europe)",
                      (char *) "1 - 76–91 MHz (Japan)",
                      (char *) "2 - 76–108 MHz (world wide)",
                      (char *) "3 - 65 –76 MHz (East Europe)",
                      (char *) "3 - 50 - 65 MHz"};
RDA5807 rx;
  while (!Serial)
  Serial.println(F("\nPU2CLR RDA5807 Arduino Library."));
  rx.setup();
  rx.setVolume(6);
  // Select a station with RDS service in your place
  Serial.print(F("\nTuning at the FM local station. See YOUR_LOCAL_STATION constant and chenge it if necessary."));
  rx.setFrequency(YOUR_LOCAL_STATION);
  rx.setLnaPortSel(3); // Trying improve sensitivity.
  rx.setAFC(true);    // Sets Automatic Frequency Control
  showHelp();
void showHelp()
  Serial.println(F("Type U to increase and D to decrease the frequency"));
  Serial.println(F("     S or s to seek station Up or Down"));
  Serial.println(F("     + or - to volume Up or Down"));
  Serial.println(F("     0 to use 87–108 MHz (US/Europe)"));
  Serial.println(F("     1 to use 76–91 MHz (Japan)"));
  Serial.println(F("     2 to use 76–108 MHz (world wide)"));
  Serial.println(F("     3 to use 65–76 MHz (East Europe) or 50-65MHz (see bit 9 of gegister 0x06)"));
  Serial.println(F("     4 to use 50–65 MHz"));
  Serial.println(F("     ? to this help."));
  Serial.println(F("=================================================="));
  delay(5000);
// Show current frequency
void showStatus()
  char aux[120];
  sprintf(aux,"\nCurrent band is:  %s", bandTable[rx.getBand()] );
  Serial.print(aux);
  sprintf(aux, "\nYou are tuned on %u MHz | RSSI: %3.3u dbUv | Vol: %2.2u | Stereo: %s | Band Status: %d\n", rx.getFrequency(), rx.getRssi(), rx.getVolume(), (rx.isStereo()) ? "Yes" : "No", rx.getBand3Status());
  Serial.print(aux);
  if ((millis() - status_elapsed) > MAX_DELAY_STATUS)
    showStatus();
  if (Serial.available() > 0)
    char key = Serial.read();
    switch (key)
    case '+':
      rx.setVolumeUp();
    case '-':
      rx.setVolumeDown();
    case 'U':
    case 'u':
      rx.setFrequencyUp();
    case 'D':
    case 'd':
      rx.setFrequencyDown();
    case 'S':
      rx.seek(RDA_SEEK_WRAP, RDA_SEEK_UP, showStatus);
    case 's':
      rx.seek(RDA_SEEK_WRAP, RDA_SEEK_DOWN, showStatus);
    case '0':
    case '1':
    case '2':
    case '3':
      rx.setBand( key - 48 );
      rx.setBand3_50_65_Mode(1); // Band 3 will work from  65 to 76 MHz;
      rx.setFrequencyToBeginBand();
      Serial.print(F("\n**** Switching to band: "));
      Serial.print(rx.getBand());
    case '4':
      // ATTENTION: The functions setFrequencyToBeginBand and setFrequencyToEnBand do not work for 50-65MHz setup. You have to control it by yourself.
      //            Also, you must control the band limits from 50 to 65 MHz. The setFrequencyUp and setFrequencyDown do not work properly.
      rx.setBand(3);
      rx.setBand3_50_65_Mode(0); // Band 3 will work from  50 to 65 MHz;
      rx.setFrequency(5500); // 55 Mhz; rx.setFrequencyDown and rx.setFrequencyUP, rx.setFrequencyToBeginBand() and rx.setFrequencyToEndBand() do not work properly for this setup;
      Serial.print(F("\n**** Switching to band: 3 from 50 to 65 MHz) "));
    case '?':
      showHelp();
    default:
    showStatus();
That example compiles ok, show us the code for the one that failed.
That error is caused due to this missing I think
Screenshot 2024-08-29 at 12.56.21
OK I can't read that.
Here's a compile log with compiler warnings set default. Understand that I am just loading and compiling this.
loading library from C:\Users\mike\OneDrive\Documents\Arduino\libraries\LiquidCrystal_PCF8574-master: invalid library: no header files foundloading library from C:\Users\mike\OneDrive\Documents\Arduino\libraries\processing-4.1.2: invalid library: no header files found
FQBN: arduino:megaavr:nona4809
Using board 'nona4809' from platform in folder: C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Using core 'arduino' from platform in folder: C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Detecting libraries used...
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 C:\Users\mike\AppData\Local\Temp\arduino\sketches\9A0531E8D6ACF8C7F65AF069CAE11207\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp -o nul
Alternatives for RDA5807.h: [PU2CLR RDA5807@1.1.9]
ResolveLibrary(RDA5807.h)
  -> candidates: [PU2CLR RDA5807@1.1.9]
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src C:\Users\mike\AppData\Local\Temp\arduino\sketches\9A0531E8D6ACF8C7F65AF069CAE11207\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src C:\Users\mike\AppData\Local\Temp\arduino\sketches\9A0531E8D6ACF8C7F65AF069CAE11207\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp -o nul
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src\RDA5807.cpp -o nul
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\Wire.cpp -o nul
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\utility\twi.c -o nul
Generating function prototypes...
C:\Users\mike\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino/api/deprecated -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\cores\arduino -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\variants\nona4809 -IC:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src -IC:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src C:\Users\mike\AppData\Local\Temp\arduino\sketches\9A0531E8D6ACF8C7F65AF069CAE11207\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp -o C:\Users\mike\AppData\Local\Temp\462364526\sketch_merged.cpp
C:\Users\mike\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\mike\AppData\Local\Temp\462364526\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\mike\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\mike\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\mike\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\mike\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\mike\\OneDrive\\Documents\\Arduino\\libraries\\PU2CLR_RDA5807\\src" "-IC:\\Users\\mike\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\mike\\AppData\\Local\\Temp\\arduino\\sketches\\9A0531E8D6ACF8C7F65AF069CAE11207\\sketch\\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp" -o "C:\\Users\\mike\\AppData\\Local\\Temp\\arduino\\sketches\\9A0531E8D6ACF8C7F65AF069CAE11207\\sketch\\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp.o"
                 from C:\Users\mike\AppData\Local\Temp\arduino\sketches\9A0531E8D6ACF8C7F65AF069CAE11207\sketch\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino.cpp:1:
In file included from C:\Users\mike\AppData\Local\Temp\.arduinoIDE-unsaved2024729-8892-v9iaxj.mmvxk\RDA5807_01_BAND_TEST_SERIAL_MONITOR\RDA5807_01_BAND_TEST_SERIAL_MONITOR.ino:30:0:
C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807\src/RDA5807.h:567:7: warning: 'RDA5807' has a field 'RDA5807::reg04' whose type depends on the type 'rda_reg04 {aka volatile<unnamed union>}' which has no linkage [-Wsubobject-linkage]
 class RDA5807
Using library PU2CLR RDA5807 at version 1.1.9 in folder: C:\Users\mike\OneDrive\Documents\Arduino\libraries\PU2CLR_RDA5807
Using library Wire at version 1.0 in folder: C:\Users\mike\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire
exit status 1
If you look in the header files included with avr-gcc/7.3.0-atmel3.6.1-arduino7, you will find that GPIO1, GPIO2 and GPIO3 are used therein.
Simply rename GPIO1, GPIO2 and GPIO3 to gpio1, gpio2 and gpio3 in the RDA5807 library and it will compile.
That did it. I'll let the maintainer of the Github repository know. I'm sure I won't be the only person to hit that.
Still works with the R4 Uno Minima too.
Many thanks! That was a big help.
Michael Harpe
In order to make all relevant information available to any who are interested in this subject, I'll share a link to the formal bug report @mikeharpe submitted to the developers of the "PU2CLR RDA5807" library here:
I also forked it and created a pull request. Just FYI.
Michael
P.S. This is my first experience with the this forum and it's impressive. This IT Old Fart is pleased!
