When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
I didn't see that last reply! That's what I was suspecting about the libraries...
I added full path to "WaveRP.h" "SdFat.h" call. This is part of the bastl LIBRARY provided.
I cannot paste all the errors, it's too long... Here's a part:
Arduino : 1.8.5 (Linux), Carte : "Arduino/Genuino Uno"
In file included from /home/jean/Arduino/eurorack/grandPa_1_2/grandPa_1_2.ino:34:0:
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:93:19: error: 'SdBaseFile' does not name a type
 volatile static SdBaseFile *sdFile;
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:136:13: error: 'SdBaseFile' has not been declared
 bool play(SdBaseFile* file); //,uint32_t _pos=0
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:137:15: error: 'SdBaseFile' has not been declared
 bool record(SdBaseFile* file, uint16_t rate, uint8_t pin, uint8_t ref);
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:141:13: error: 'SdBaseFile' has not been declared
 bool trim(SdBaseFile* file);
grandPa_1_2:84: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t noteSampleRateTable[65]={
grandPa_1_2:226: error: 'prog_uint16_t' has not been declared
uint32_t curveMap(uint16_t value, uint8_t numberOfPoints, prog_uint16_t * tableMap){
In file included from /home/jean/arduino-1.8.5/hardware/arduino/avr/cores/arduino/Arduino.h:28:0,
        from sketch/grandPa_1_2.ino.cpp:1:
/home/jean/Arduino/eurorack/grandPa_1_2/grandPa_1_2.ino: In function 'uint32_t mapVOct(uint16_t)':
grandPa_1_2:194: error: 'noteSampleRateTable' was not declared in this scope
   if(abs(value-cvInputCalibrate[i])<3) return pgm_read_word_near(noteSampleRateTable+(i*6));
grandPa_1_2:195: error: 'noteSampleRateTable' was not declared in this scope
   if(abs(value-cvInputCalibrate[i+1])<3) return pgm_read_word_near(noteSampleRateTable+((1+i)*6));
grandPa_1_2:206: error: 'noteSampleRateTable' was not declared in this scope
   outMax=pgm_read_word_near(noteSampleRateTable+((i*6)+_note+1));//tableMap[numberOfPoints+i+1];
grandPa_1_2:207: error: 'noteSampleRateTable' was not declared in this scope
   outMin=pgm_read_word_near(noteSampleRateTable+(i*6)+_note+0);
/home/jean/Arduino/eurorack/grandPa_1_2/grandPa_1_2.ino: At global scope:
grandPa_1_2:219: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t granSizeMap[16]={
grandPa_1_2:223: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t shiftSpeedMap[20]={
MEM:2: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t clearTo[]={
MEM:31: error: 'prog_char' does not name a type
PROGMEM prog_char labels[]={
MEM:78: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t maxValue[]={
/home/jean/Arduino/eurorack/grandPa_1_2/MEM.ino: In function 'int maxVal(uint8_t)':
MEM:101: error: 'maxValue' was not declared in this scope
 return  pgm_read_word_near(maxValue+_maxVal);
/home/jean/Arduino/eurorack/grandPa_1_2/MEM.ino: In function 'void clearSound(unsigned char)':
MEM:308: error: 'clearTo' was not declared in this scope
  setVar(i,j, pgm_read_word_near(clearTo+j));
/home/jean/Arduino/eurorack/grandPa_1_2/SD.ino: In function 'bool play(uint8_t)':
SD:128: error: no matching function for call to 'WaveRP::play(SdFile*)'
  if (!wave.play(&file)) { //,uint32_t _pos=0
/home/jean/Arduino/eurorack/grandPa_1_2/SD.ino:128:25: note: candidate is:
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:136:8: note: bool WaveRP::play(int*)
/home/jean/Arduino/libraries/bastl-master/WaveRP.h:136:8: note: Â no known conversion for argument 1 from 'SdFile*' to 'int*'
/home/jean/Arduino/eurorack/grandPa_1_2/SOUND.ino: At global scope:
SOUND:27: error: 'prog_uint16_t' does not name a type
PROGMEM prog_uint16_t usefulLengths[17]={
/home/jean/Arduino/eurorack/grandPa_1_2/SOUND.ino: In function 'void updateSound()':
SOUND:57: error: no matching function for call to 'WaveRP::play(SdFile*)'
     wave.play(&file);
/home/jean/Arduino/eurorack/grandPa_1_2/SOUND.ino:57:26: note: candidate is:
Ganjouille:
When you need to post text that exceeds the 9000 character limit of the forum you can always save it to a .txt file and then post the file as an attachment. You will see the "Attachments and other options" link after clicking the "Reply" button on a thread.
In this case it's usually best to fix the first errors at the top of the output, then recompile, as often later errors are caused by the prior errors.
Ganjouille:
I didn't see a file named WaveRP.h in the bastl repository you provided a link to.
Ganjouille:
This is another symptom of the old code. It's easily fixed though. You need to change all instances of prog_uint16_t to const uint16_t. See:
An alternative is to use Arduino IDE 1.0.6, but it's annoying to use such an old IDE version.
Yes sorry! This is another point. I found this file in the microGranny library.
I merged the two bastl libs into the bastl directory in home/Arduino/libraries/bastl...
Im was on the way making a github repo with all changes I make in the programm, don't know if it can be usefull... I get no response from support email from bastl instruments sadly.
So first I try with the 1.0.6 IDE version.
If not working I will go for make this code compile!
Just for saying: There's also a hex file for granPa_1_1 I already uploaded to the MCU but I have v1.2 PCB...
So I tried the older IDE version and it's not working. The actual SdFat library is not recognized by the IDE. I probably need the older version... Maybe I can find it.
Next I replaced all prog_uint16_t. Know I get less errors:
On way could be to replace the code concerning SD card. It look like that's the node of the errors. But there's a huge gap in my knowledges for doing that...
Ah, the library thing is a problem. It's unfortunate that the old releases (assuming they actually were making releases) of the SdFat library don't seem to be available from their original home on Google Code and are also not present in the GitHub repository. The oldest release of the library is still in the 1.5 library format, which is incompatible with Arduino IDE 1.0.6. You can go back farther in history from there. The oldest available version of the library on GitHub is here: https://github.com/greiman/SdFat/archive/3f7f5cd8e9afb876ecfe9eda19679ebab33109ce.zip
Note that version is in 1.0 library format and also contains the SdFatUtil.h file that is missing from more recent versions of the library. So give that a try. Make sure to remove the #include <SD.h> line so that the Arduino SD library will no longer be used. Now that you've fixed the prog_* type errors you are probably better off to continue using Arduino IDE 1.8.5.
