Compile Trouble
Hello
because when I compile the code I get written this error
Error during compilation for the Arduino / Genuino MKR1000 board.
it seems that the bookshop <MudbusWiFi.h> does not like it
gnusso:
Good Morning,
is there a way to use TCP and UDP with mkr 1000 without that the client has been disconnected after a few moments ?
WiFi Web Server
A simple web server that shows the value of the analog input pins.
using a WiFi shield.
This example is written for a network using WPA encryption. For
WEP or WPA, change the WiFi.begin() call accordingly.
Circuit:
  • WiFi shield attached
  • Analog inputs attached to pins A0 through A5 (optional)
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi101.h>
//#include <WiFiUdp.h>
char ssid = “Gnux2”;      //  your network SSID (name)
char pass = “Ab123456”;  // your network password
//byte test;
int keyIndex = 0;                // your network key Index number (needed only for WEP)
byte mac[6];                    // the MAC address of your Wifi shield
byte messaggio[28];        // mex to send out for registration
String test ;
int status = WL_IDLE_STATUS;
int i = 0;
int k = 0;
//WiFiUDP Udp;
WiFiServer server(1337);
WiFiClient client;
WiFiClient client2(1338);
unsigned int localPort = 21;      // local port to listen on
char packetBuffer[255]; //buffer to hold incoming packet
//Dichiarazione di funzione che punta all’indirizzo zero
void(* Riavvia)(void) = 0;
  //Initialize serial and wait for port to open:
  pinMode(9, OUTPUT);      // set the LED pin mode
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println(“WiFi shield not present”);
    // don’t continue:
    while (true);
// attempt to connect to WiFi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you’re connected now, so print out the status:
  printWiFiStatus();
  Udp.begin(21);
  SendMessageBroadCast();
i++;
  //k++;
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    Serial.println(“new client”);
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you’ve gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == ‘\n’ && currentLineIsBlank) {
          // send a standard http response header
          client.println(“HTTP/1.1 200 OK”);
          client.println(“Content-Type: text/html”);
          client.println(“Connection: close”);  // the connection will be closed after completion of the response
          client.println(“Refresh: 5”);  // refresh the page automatically every 5 sec
          client.println();
          client.println("");
          client.println("");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print(“analog input “);
            client.print(analogChannel);
            client.print(” is “);
            client.print(sensorReading);
            client.println(”
          client.println(””);
        if (c == ‘\n’) {
          // you’re starting a new line
        else if (c != ‘\r’) {
          // you’ve gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
// close the connection:
    client.stop();
    Serial.println(“client disonnected”);
if (i > 700000){
      i=0;
      //Serial.println(“MAnda mes”);
void printWiFiStatus() {
  // print the SSID of the network you’re attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
// print your WiFi shield’s IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
// print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print(“signal strength (RSSI):”);
  Serial.print(rssi);
  Serial.println(" dBm");
  if (rssi >= -67 ){
    Serial.println(“Perfect Signal Signal - greem led”);
  else if (rssi >= -80 && rssi <= -67){
    Serial.println(“Normal Signal - Yellow Led”);
  else if (rssi < -90){
    Serial.println(“Bad Signal - Red Led”);
  // print where to go in a browser:
  Serial.print(“To see this page in action, open a browser to http://”);
  Serial.println(ip);
WiFi.macAddress(mac);
  Serial.print(“MAC: “);
  Serial.print(mac[5]);
  Serial.print(”:”);
  Serial.print(mac[4]);
  Serial.print(":");
  Serial.print(mac[3]);
  Serial.print(":");
  Serial.print(mac[2]);
  Serial.print(":");
  Serial.print(mac[1]);
  Serial.print(":");
  Serial.println(mac[0]);
    messaggio[0]= 0;
    messaggio[1]= 0;
    messaggio[2]= 0;
    messaggio[3]= 0;
    messaggio[4]= mac[5] >> 4;
    messaggio[5]= 0;
    messaggio[6]= mac[5] & 0xF;
    messaggio[7]= 0;
    messaggio[8]= mac[4] >> 4;
    messaggio[9]= 0;
    messaggio[10]= mac[4] & 0xF;
    messaggio[11]= 0;
    messaggio[12]= mac[3] >> 4;
    messaggio[13]= 0;
    messaggio[14]= mac[3] & 0xF;
    messaggio[15]= 0;
    messaggio[16]= mac[2] >> 4;
    messaggio[17]= 0;
    messaggio[18]=  mac[2] & 0xF;
    messaggio[19]= 0;
    messaggio[20]= mac[1] >> 4;
    messaggio[21]= 0;
    messaggio[22]= mac[1] & 0xF;
    messaggio[23]= 0;
    messaggio[24]= mac[0] >> 4;
    messaggio[25]= 0;
    messaggio[26]= mac[0] & 0xF;
    //messaggio[27]= ‘\n’;
void SendMessageBroadCast(){
  Udp.beginPacket(“255.255.255.255”, 21);
  Udp.write(messaggio, 115);
  Udp.endPacket();
void ReconnectWiFi(){
    Serial.print("Reconnect to SSID: ");
    delay(10000);
// server.begin();
[code/]
Thanks
Andrea
Joseph this is not the same issue
Please dont hijack threads.
That looks like quite an old sketch. Is it part of the current WiFi101 examples or the much older (retired) WiFi101 examples ?
Thread split.
