Compile with CLI and specify register emulation option [SOLVED]
Using the CLI, I am trying to compile a sketch for the Arduino Nano Every which uses the ATmega4809, but I want to disable ATmega328 register emulation.
When I run the command:
arduino-cli board details arduino:megaavr:nona4809
I get the following output:
Board name:     Arduino Nano Every
Required tools: arduino:avr-gcc            7.3.0-atmel3.6.1-arduino5
                arduino:avrdude            6.3.0-arduino17
                arduino:arduinoOTA         1.3.0
Option:         Registers emulation        mode
                ATMEGA328                ✔ mode=on
                None (ATMEGA4809)          mode=off
I do not want to use the "ATMEGA328 Register emulation" which is checked in this output and makes me think that is the default.
During compilation, and potentially upload, how do I turn that off via command line? It's easy to do in the IDE, but I'm not using the IDE.
I found the answer to my own question. By looking at the full output from the IDE, I saw that the specified FQBN was "arduino:megaavr:nona4809:mode=off". So the hint was in the output from "board list" where it said the option was "mode" and "mode=on" was the default.
When you do not want to use register emulation on the Arduino Nano Every, use the command:
arduino-cli compile --fqbn arduino:megaavr:nona4809:mode=off <sketch-name>
