I struggled to get the VS code to work and compile my ESP32 code. I did the following:
- Downloaded Arduino compiler extension.
- Added C/C++ extension.
- Setup the compiler/libraries path.
- Solved all include issues.
It worked but still I get a library include error:
[Starting] Verifying sketch 'tft_espi.ino'
[Warning] Output path is not specified. Unable to reuse previously compiled files. Build will be slower. See README.
E:\projects_electronics_programming\tft\tft_espi\tft_espi.ino:3:10: fatal error: TFT_eSPI.h: No such file or directory
#include <TFT_eSPI.h>
compilation terminated.
Error during build: exit status 1
[Warning] Failed to generate IntelliSense configuration.
[Error] Verifying sketch 'tft_espi.ino': Exit with code=1
I'm including all the libraries in the main source file, the code is compiled ok in the Arduino IDE perfectly:
#include <SPI.h>
#include <Wire.h>
#include <PNGdec.h>
#include <Adafruit_PWMServoDriver.h>
#include <stepper_dev_prj.h>
#include "system_variables.h"
#include "task_manager.ino"
#include "ui_tools.ino"
#include "control_page.ino"
TFT_eSPI tft = TFT_eSPI();
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
void setup(void) {
// serial & communication setting
// Serial.begin(9600);
// Serial.println("\n\nStarting..."); // for ESP32, not for STM32 over ST-Link
// ets_printf("isr setup\n"); // for ESP32, can be used inside ISR
// pwm setup
pwm.begin();
// pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
pwm.setPWMFreq(330); // Digital servos run at ~330 Hz updates
// pin setting for Black Pill for test LEDs
// pinMode(PB9, OUTPUT);
// pinMode(PB8, OUTPUT);
// tft setting
tft.init();
tft.setRotation(0);
// tft start setting
tft_start_setting();
text_setting();
main_menu_page();
tft_task_manager();
This is the c_cpp_properties.json:
"configurations": [
"name": "arduino",
"includePath": [
"${workspaceFolder}/**",
"E:/Programs_Files/Arduino/hardware",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/variants/esp32",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/cores/esp32",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/libraries/SPI/src",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/dio_qspi/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/qio_qspi/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/dout_qspi/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/qout_qspi/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/libraries/Wire/src",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/freertos/include/freertos",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/freertos/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/freertos/include/esp_additions/freertos",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_common/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/freertos/port/xtensa/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/xtensa/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/xtensa/esp32/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_rom/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_rom/include/linux",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_hw_support/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/hal/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/soc/esp32/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/hal/esp32/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/soc/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_system/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_timer/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/newlib/platform_include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/heap/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/log/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/driver/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/spi_flash/include",
"E:/Programs_Files/Arduino/hardware/arduino-esp32-master/tools/sdk/esp32/include/esp_hw_support/include/soc",
"E:/Programs_Files/Arduino/libraries",
"E:/Programs_Files/Arduino/libraries/TFT_eSPI",
"E:/Programs_Files/Arduino/libraries/PNGdec-master/src",
"E:/Programs_Files/Arduino/libraries/Adafruit-PWM-Servo-Driver-Library-master",
"E:/Programs_Files/Arduino/libraries/stepper_dev_prj/src",
"E:/Programs_Files/Arduino/libraries/my_keywords"
"defines": [
"_DEBUG",
"UNICODE",
"_UNICODE"
"compilerPath": "C:/Users/eagle/AppData/Local/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-gcc"
"version": 4
What could be the problem ?
