I've upgraded my IDEs on 2 computers to 2.3.2 (not sure exactly what they were before).
My code uses a library that has this in it (It's the SparkFunLIS3DH library):
#if defined(ARDUINO_ARCH_ESP32)
... code here that I believe is the correct code for the UNO R4 WiFi...
#elif defined(__MK20DX256__)
...other ignored code here...
#else
// probably __AVR__
...code here that's being compiled, but fails to compile because
...methods and constants from the SPI library that are
...referenced here aren't defined.
#endif
I think the constant ARDUINO_ARCH_ESP32 used to be defined for UNO R4 WiFi builds, and now it isn't.
I can't be positive that the IDE version upgrade caused the failures to start happening, but this code would compile a few days ago, and I did update my IDEs very recently, so I'm guessing the update somehow changed how compiler constants are defined.
I could, of course, just define this constant in my own code, but that just leads to other errors elsewhere that appear to be similarly fallout from incorrect compiler defines.
I do believe that have the correct board selected:
Anyone have any ideas what's going on here, and how I might fix it?
