Compiling my sketches with macOS Mojave (10.14.6) and Arduino 1.8.11 (and all versions before) compiles without error.
After upgrading to macOS Catalina (10.15.3) all sketches using Arduino Uno ends with:
HardwareSerial0.cpp.o (symbol from plugin): In function Serial': (.text+0x0): multiple definition of
__vector_18'
sketch/eg-ug.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
exit status 1
The problem seems to be my own serial routine using ISR (USART_RX_vect) and ISR (USART_TX_vect)
These routines were originally developed with Microship Studio 4 and are uses to connect 12 atMega328p (Arduino like) via RS485 in an multiple Master / multiple Slave environment.
As they are working (until now) I didn't want to use the arduino Serial Library.
In all sketches I don't use any arduino SerialHardware Library, but the compiler seems to use it.
Any idee why and how I can solve the problem ?
