Compiler Error, ESP8266, NodeMCU (ESP-12E) | BearSS
Hello Everyone,
I am attempting to compile some code but keep running into the same error. I have done some digging via google, however I have yet to find a solution to the noted error. Any help here would be more than appreciated. Lastly, please forgive my ignorance, this is my first-time using ESP and Arduino.
Issue summary, while compiling the following error is given:
In file included from C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\Muell\AppData\Local\Temp\Temp5_Hal-Finney-Price-Checker-master.zip\Hal-Finney-Price-Checker-master\main\main.ino:7:
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:262:36: error: expected ')' before '*' token
WiFiClientSecure(ClientContext *client, const X509List *chain, unsigned cert_issuer_key_type,
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:264:35: error: expected ')' before '*' token
WiFiClientSecure(ClientContext* client, const X509List *chain, const PrivateKey *sk,
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
~WiFiClientSecure() override;
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:43:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:48:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\Muell\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:60:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Some of the posts I have read concerning similar problems include:
-Compiling Error - marked override, but does not override · Issue #2 · arpruss/vectordisplayarduino · GitHub -WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override. · Issue #2184 · esp8266/Arduino · GitHub
Thank you for your help and time, -JM
