Compiler Error for Arduino Due
Hi, I was using Arduino Uno previously, but due to high speed and high flash I have moved to Arduino Due.
But when I compiled a basic led blink example it gives following error...
Arduino: 1.6.7 (Windows 7), Board: "Arduino Due (Programming Port)"
Board arduino_due_x_dbg (platform sam, package arduino) is unknown
Error compiling.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Can anyone help me get out of this problem?
mithunkamat:
Arduino: 1.6.7 (Windows 7), Board: “Arduino Due (Programming Port)”
Error compiling.
“Show verbose output during compilation”
Yes. See above. Especially:
You did add your DUE to the interface with the Board Manager, correct?
Hi, I have added Arduino Due from board manager.
the verbose output is as follows
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\mithun\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\mithun\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "D:\ARDUINO\libraries" -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10607 -build-path "C:\Users\mithun\AppData\Local\Temp\build62def743cf6596a392e2ad13d2cf3c1f.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "C:\Users\mithun\AppData\Local\Temp\untitled2133304218.tmp\sketch_jan16a\sketch_jan16a.ino"
Error compiling.
Regards
Mithun
https://forum.arduino.cc/index.php?topic=365367.0
