Compiler error I don't understand
I had something like this working previously, but now i get an error. I'm trying to set up a call back
 class parseAscii
  using SomeEvent = void (*)(uint8_t); //type aliasing
  public:
    void RegisterCallback(SomeEvent InEvent)
      BtnEvent = InEvent;
And the error that I get is
AscClockSpoof.h:6:29: error: expected ';' before '(' token
If I make it void(*)(); I don't get the error.
The context of this is that this is one class of a fairly large compile and I don't know if there's some pollution from another file, but I haven't seen this before. Any suggestion are welcome. I've been searching for a while.
wish you posted the entire file; line # 6 is the one with using?
isn't "using" intended to describe a name space? looks like your associating it with an unnamed function pointer.
what are you trying to do?
dduehren:
The function signature you passed in must match that of the declaration.
wouldn't a function pointer for defined as follows, for example
   void (*someEvent)(uint8_t);
is C++ version of
typedef void (*SomeEvent)(uint8_t);
Perhaps I should have posted the entire file. I think the problem was related to where in the file it was located. And I was moving things around too much. Its working now, but your suggestion might be a better way. If I were a real programmer I think I'd have figured it out myself.
Thanks,
David
dduehren:
yes
Perhaps I should have posted the entire file. I think the problem was related to where in the file it was located. And I was moving things around too much. Its working now, but your suggestion might be a better way. If I were a real programmer I think I’d have figured it out myself.
Thanks,
David
