Compiler error when adding a library
(this post was originally in the adafruit forums here Adafruit customer service forums • View topic - Adding Music Maker library causes compiling error and was moved because it appears to be an arduino problem).
I’m working to modify this script:
viewtopic.php?f=31&t=79525&p=402768&hilit=+music+maker+music+maker+trigger#p402768
to work with the plastic flow meter (https://www.adafruit.com/products/828). However, I keep getting an compiling error:
collect2: error: ld returned 1 exit status
exit status 1
In an attempt to isolate the problem, I restarted building the sketch from the flow meter test script. It seems that as soon as I add the line
#include <Adafruit_VS1053.h>
To the script I get the same error. (Full code below). What can I do to fix this? I’m running the arduino IDE 1.6.12 on ubuntu 16.04.
thanks!
#include "SPI.h"
#include <SD.h>
This is example code for using the Adafruit liquid flow meters.
Tested and works great with the Adafruit plastic and brass meters
    ------> http://www.adafruit.com/products/828
    ------> http://www.adafruit.com/products/833
Connect the red wire to +5V,
the black wire to common ground
and the yellow sensor wire to pin #2
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above must be included in any redistribution
//&&&&&sensor stuff&&&&&&
// which pin to use for reading the sensor? can use any pin!
#define FLOWSENSORPIN 2
int counter;
// count how many pulses!
volatile uint16_t pulses = 0;
// track the state of the pulse pin
volatile uint8_t lastflowpinstate;
// you can try to keep time of how long it is between pulses
volatile uint32_t lastflowratetimer = 0;
// and use that to calculate a flow rate
volatile float flowrate;
// Interrupt is called once a millisecond, looks for any pulses from the sensor!
SIGNAL(TIMER0_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN);
  if (x == lastflowpinstate) {
    lastflowratetimer++;
    return; // nothing changed!
  if (x == HIGH) {
    //low to high transition!
    pulses++;
  lastflowpinstate = x;
  flowrate = 1000.0;
  flowrate /= lastflowratetimer;  // in hertz
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
//&&&&&endsensortstuff&&&&&&&
   Serial.print("Flow sensor test!");
   pinMode(FLOWSENSORPIN, INPUT);
   digitalWrite(FLOWSENSORPIN, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN);
   useInterrupt(true);
void loop()                     // run over and over again
  Serial.print("Freq: "); Serial.println(flowrate);
  Serial.print("Rate: "); Serial.println(flowrate/7.5);
  // if a plastic sensor use the following calculation
  // Sensor Frequency (Hz) = 7.5 * Q (Liters/min)
  //Liters = Q * time elapsed (seconds) / 60 (seconds/minute)
  //Liters = (Frequency (Pulses/second) / 7.5) * time elapsed (seconds) / 60
  //Liters = Pulses / (7.5 * 60)
  float liters = pulses;
  liters /= 7.5;
  liters /= 60.0;
  Serial.print(liters); Serial.println(" Liters");
Did you ever download the library from github? That isn't a standard Arduino library, so you have to download it before it knows what you're trying to do.
That should be a start. If it still doesn't recognize the library, you may need to get it in the files and unzip it (extract all) into program files>arduino>libraries
Yes, the library is installed. I also tried to use the arduino web IDE and had the same problem, and adafruit support confirms that they experienced the same issue.
Turn on verbose output for compilation (file/preferences) and you will see what is wrong.
multiple definition of `__vector_14'
This is defined (differently) in both the library .cpp file and the sketch.
Thanks! What is the best way to fix something like that? As far as I can tell the sketch doesn't obviously define __vector_14.
TIMER0_COMPA_vect is __vector_14.
Well you can't define the same ISR/SIGNAL twice. So you will have to use something else in the sketch. Configure another timer and use that perhaps. There are libraries available for timer 1 and timer 2.
Thank you! I changed the timer references in three places and the error appears to have disappeared. In case it is helpful to someone else, the three changes were:
became
SIGNAL(TIMER1_COMPA_vect) {
became
TIMSK1 |= _BV(OCIE0A);
became
TIMSK1 &= ~_BV(OCIE0A);
That makes the full sketch:
#include "SPI.h"
#include <SD.h>
int counter;
  if (x == HIGH) {
    pulses++;
  flowrate = 1000.0;
  if (v) {
    OCR0A = 0xAF;
   useInterrupt(true);
  liters /= 7.5;
  liters /= 60.0;
