I am struggling with compiling anything for the Due.
Download Arduino Beta (Build 38)
Add Arduino SAM Boards through the board manager
Select Due Programming Port
Verify a new scetch
Arduino: 1.9.0-beta (Windows 10), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\Ren�H�zser\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/Arduino.h:222:0,
from sketch\sketch_mar16a.ino.cpp:1:
C:\Users\Ren�H�zser\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/USB/USBAPI.h:55:14: error: 'avai' declared as a 'virtual' field
C:\Users\Ren�H�zser\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/USB/USBAPI.h:55:14: error: expected ';' at end of member declaration
C:\Users\Ren�H�zser\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/USB/USBAPI.h:55:14: error: expected '}' at end of input
C:\Users\Ren�H�zser\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/USB/USBAPI.h:55:14: error: expected unqualified-id at end of input
exit status 1
Error compiling for board Arduino Due (Programming Port).
option enabled in File -> Preferences.
The file USBAPI.h looks OK to me.
Any ideas on how to resolve the compiler problem?
Thanks
René
I can't reproduce the problem. Does it occur even with the bare minimum sketch (File > New)?
I have a suspicion the cause is the non-standard (sorry, I know that's not the correct term but you get what I mean) letters in your user name but that's just a guess. Do you have a different user on your computer that you could try to see if the problem still occurs?
pert:
Yes, it does.
pert:
At the time I wrote this post, I thought the same. I will create a new user and try again.
I suspected it was a problem specific to the Beta build. There is a new tool added in the Beta build which is still kind of rough around the edges. This looks like a relevant issue report:
So the developers are aware there is some issue and I think they'll be sure to get it fixed before making the 1.9.0 release of the Arduino IDE.
