I tried using some working examples of code to program my WeMos D1 R2 board but for some reason the complier throws me an error regarding the SD.h include file. This happens regardless of the sample code I try.
I have selected the WeMos D1 R2 board from the dropdown list of supported boards, using IDE Version 1.6.8 and Version 1.0.5 of the SD(ESP8266)
I've searched the net for two days now and haven't found an answer.
Included is the code I'm trying and the output from the compiler.
Any help with this problem would be greatly appreciated. If you need more info, please ask.
Thanks.
SP
SAMPLE CODE
* Micro SD Shield - Datalogger
* This example shows how to log data from an analog sensor
* to an SD card using the SD library.
* The WeMos Micro SD Shield uses:
* D5, D6, D7, D8, 3V3 and G
* The shield uses SPI bus pins:
* D5 = CLK
* D6 = MISO
* D7 = MOSI
* D8 = CS
* The WeMos D1 Mini has one analog pin A0.
* The SD card library uses 8.3 format filenames and is case-insensitive.
* created 24 Nov 2010
* modified 9 Apr 2012 by Tom Igoe
* This example code is in the public domain.
* https://github.com/esp8266/Arduino/blob/master/libraries/SD/examples/Datalogger/Datalogger.ino
#include <SPI.h>
#include <SD.h>
const int chipSelect = D8;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
//for (int analogPin = 0; analogPin < 3; analogPin++) {
// int sensor = analogRead(analogPin);
// dataString += String(sensor);
// if (analogPin < 2) {
// dataString += ",";
// The WeMos D1 Mini only has one analog pin A0.
int sensor = analogRead(A0);
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
ERROR INFORMATION
In file included from E:\ARDUINO\SKETCHES\libraries\SD\src/utility/Sd2Card.h:26:0,
from E:\ARDUINO\SKETCHES\libraries\SD\src/utility/SdFat.h:29,
from E:\ARDUINO\SKETCHES\libraries\SD\src/SD.h:20,
from E:\ARDUINO\SKETCHES\WEMOS_SD_Card_Example2\WEMOS_SD_Card_Example2.ino:1:
E:\ARDUINO\SKETCHES\libraries\SD\src/utility/Sd2PinMap.h:510:2: error: #error Architecture or board not supported.
