Compiler failed because multiple definition of a function, even is defined as "weak"
Hi all,
I'm trying to build a small software that is using DMA for STM32.
When I'm trying to define HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) the complier is failing with:
..\libraries\SrcWrapper\stm32\uart.c.o: in function `HAL_UART_RxCpltCallback':
uart.c:(.text.HAL_UART_RxCpltCallback+0x0): multiple definition of `HAL_UART_RxCpltCallback'; .. IR_RC_Airwell.ino.cpp:(.text.HAL_UART_RxCpltCallback+0x0): first defined here
This function is defined stm32f4xx_hal_uart.c in stm32core libraries as:
  * @brief  Rx Transfer completed callbacks.
  * @param  huart  Pointer to a UART_HandleTypeDef structure that contains
  *                the configuration information for the specified UART module.
  * @retval None
__weak void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
  /* Prevent unused argument(s) compilation warning */
  UNUSED(huart);
  /* NOTE: This function should not be modified, when the callback is needed,
           the HAL_UART_RxCpltCallback could be implemented in the user file
My function is written like this in my IR_RC_Airwell.ino:
  SerialUSB.begin(1152000);
  SerialUSB.setTimeout(100);
  memset(serUSB, '\0', BUFSIZE);
  HAL_UART_Receive_DMA (&huart1, UART1_rxBuffer, 12);
void TestFunction(char *buf) {
  //UNUSED(buf);
           the TestFunction could be implemented in the user file
   SerialUSB.print(buf);
   SerialUSB.print("\n");
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) {
   SerialUSB.print("OK");
    //HAL_UART_Transmit(&huart1, UART1_rxBuffer, 12, 100);
    //HAL_UART_Receive_DMA(&huart1, UART1_rxBuffer, 12);
I've repicate a test function in test.cpp and test.h:
#include "test.h"
__weak void TestFunction(char *buf) {
  UNUSED(buf);
and my test.h:
#if  defined ( __GNUC__ )
#ifndef __weak
#define __weak   __attribute__((weak))
#endif /* __weak */
#ifndef __packed
#define __packed __attribute__((__packed__))
#endif /* __packed */
#endif /* __GNUC__ */
#define UNUSED(X) (void)X      /* To avoid gcc/g++ warnings */
void TestFunction(char *);
And this function is working without any issues.
What I'm doing wrong?
Kind regards.
I'v only seen it with __attribute__((weak))to the RIGHT of the argument list. Maybe try:
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) __weak
Indeed the function is defined as weak here
but it's already implemented in uart.c
which seems to be what the compiler is complaining about
Hi J-M-L,
Thanks. Now I understand. Seems that is already implemented for Arduino. Now I'm curious if this serial port reading is DMA or not. I have to look in the code.
Thanks!
