Compiler Issue
Hi I updated a few of my board library files through the IDE. Now I suddenly get this error message when I try to compile and not sure how to fix it. Any help would be greatly appreciated.
Thanks.
Arduino: 1.6.6 (Mac OS X), Board: "Pro Trinket 3V/12MHz (FTDI)"
WARNING: Spurious .github folder in 'Adafruit BNO055' library WARNING: Spurious .github folder in 'Adafruit BluefruitLE nRF51' library WARNING: Spurious .github folder in 'Adafruit MMA8451 Library' library avr-g++: error: missing filename after '-o' exit status 1 Error compiling.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
The error is caused by using Arduino AVR Boards 1.6.10 or higher with Arduino IDE 1.6.6, they are incompatible. The solution is to either:
  • Upgrade to Arduino IDE 1.6.7 or greater
  • Install Arduino AVR Boards 1.6.9 using Boards Manager(Tools > Board > Boards Manager... > Arduino AVR Boards(click on it) > Select version > 1.6.9 > Install) - I've had problems reinstalling the previous Arduino AVR Boards version with Boards Manager so you may have to reinstall the Arduino IDE if you can't compile after going back to Arduino AVR Boards 1.6.9.
Unless you have a good reason to stick with Arduino IDE 1.6.6 I'd recommend you to upgrade. 1.6.6 had a lot of problems.
pert: Unless you have a good reason to stick with Arduino IDE 1.6.6 I'd recommend you to upgrade. 1.6.6 had a lot of problems.
Amen! The new features they've added really make a difference. The latest version is good right now, (1.6.12, which ships with avr boards 1.6.14 - the version numbers somehow wound up being 2 minor versions apart, which causes confusion all the time).
