(thanks to jremington for helping me make the post better)
PreInfo:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno R3"
After writing code for the Arduino and trying to verify said code, I ran into the error message:
Code:
#include <Wire.h>
// Define the rotary encoder pins
#define enc1PinA 3
#define enc1PinB 4
#define enc2PinA 5
#define enc2PinB 6
#define enc3PinA 7
#define enc3PinB 8
// Define the LCD properties
#define LCD_COLS 20
#define LCD_ROWS 4
#define LCD_ADDR 0x27
// Create the LCD object
LiquidCrystal_I2C lcd(LCD_ADDR, LCD_COLS, LCD_ROWS);
// Define the variables to store the encoder values
int enc1Val = 0;
int enc2Val = 0;
int enc3Val = 0;
// Define the interrupt service routines for the rotary encoders
void enc1ISR() {
if (digitalRead(enc1PinB) == HIGH) {
enc1Val++;
enc1Val--;
void enc2ISR() {
if (digitalRead(enc2PinB) == HIGH) {
enc2Val++;
enc2Val--;
void enc3ISR() {
if (digitalRead(enc3PinB) == HIGH) {
enc3Val++;
enc3Val--;
// Set the encoder pins as inputs
pinMode(enc1PinA, INPUT);
pinMode(enc1PinB, INPUT);
pinMode(enc2PinA, INPUT);
pinMode(enc2PinB, INPUT);
pinMode(enc3PinA, INPUT);
pinMode(enc3PinB, INPUT);
// Enable the internal pull-up resistors for the encoder pins
digitalWrite(enc1PinA, HIGH);
digitalWrite(enc1PinB, HIGH);
digitalWrite(enc2PinA, HIGH);
digitalWrite(enc2PinB, HIGH);
digitalWrite(enc3PinA, HIGH);
digitalWrite(enc3PinB, HIGH);
// Attach the interrupt service routines to the encoder pins
attachInterrupt(digitalPinToInterrupt(enc1PinA), enc1ISR, CHANGE);
attachInterrupt(digitalPinToInterrupt(enc2PinA), enc2ISR, CHANGE);
attachInterrupt(digitalPinToInterrupt(enc3PinA), enc3ISR, CHANGE);
// Initialize the LCD
lcd.init();
lcd.backlight();
// Read the encoder values
int enc1Mapped = map(enc1Val, -100, 100, 0, 255);
int enc2Mapped = map(enc2Val, -100, 100, 0, 255);
int enc3Mapped = map(enc3Val, -100, 100, 0, 255);
// Display the encoder values on the LCD
lcd.setCursor(0, 0);
lcd.print("Encoder 1: ");
lcd.print(enc1Mapped);
lcd.setCursor(0, 1);
lcd.print("Encoder 2: ");
lcd.print(enc2Mapped);
lcd.setCursor(0, 2);
lcd.print("Encoder 3: ");
lcd.print(enc3Mapped);
// Delay for a short period to reduce screen flicker
delay(50);
Error:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\100964\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\100964\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\100964\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\100964\AppData\Local\Temp\arduino_build_780319 -warnings=none -build-cache C:\Users\100964\AppData\Local\Temp\arduino_cache_60639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\100964\Documents\Arduino\sketch_apr16b\sketch_apr16b.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\100964\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\100964\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\100964\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\100964\AppData\Local\Temp\arduino_build_780319 -warnings=none -build-cache C:\Users\100964\AppData\Local\Temp\arduino_cache_60639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\100964\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\100964\Documents\Arduino\sketch_apr16b\sketch_apr16b.ino
Using board 'uno' from platform in folder: C:\Users\100964\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\100964\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
recipe.preproc.macros pattern is missing
Error compiling for board Arduino Uno.
And nothing more.
Does anyone know how to fix this?
