I think that would do it, yes. (unless I needed the value of outer to be preserved for a starting condition for next time--and I think that was the case here. I was hoping to return to coding today, but that's apparently not going to happen. I think that the loops were about looking for something long term [i.e. past many iterations lf loop()] to do when none were being done {sprinkler controller that still needed to be able to talk over bluetooth, so I wouldn't want to start at the beginning of the search, either, as there could be times when an early unit had multiple pending runs in the queue, but I want the whole program to execute first}. )
I tend to be less than positive whether the language that I'm using at any given moment tests at the top or bottom of loops, and code so that I don't need an assumption about this.
But I definitely need to remember this approach . . .
Don't bet your family fortune on it until others have commented. I have a nasty feeling that it may be regarded as bad practice for one reason or another
That's easy because a for loop in C is the equivalent of a while loop and the exit condition is tested at the start of the loop
UKHeliBob:
Good point. And arduino_new may have one of those . . . come to think of it, is altering a control variable a defined behavior in C? I know that I've used languages where it is not, and can do strange things, or is permitted to, or . . .
UKHeliBob:
Over the course of a typical day, I'm likely using LiveCode, Arduino C++, shell scripts, Python, raw or and/or automated manipulation of postscript or pdf, and shell script. I try to write in a way that won't backfire if I mix'n'match quirks [ok, "forget which I'm using"]
All in all, it the present example, it still seems that the GOTO is the cleanest and least resource intensive. But the Fortran style exit would are even better . . .
