Hello,
have some Trouble with a new application and I suppose that it could be related to some included libraries.
From the following Compiler Output I see
Alternatives for OneWire.h: [MAX31850_OneWire@1.0.2 OneWire@2.3.5 OneWire-2.3.3.06@2.3.3]
ResolveLibrary(OneWire.h)
-> candidates: [MAX31850_OneWire@1.0.2 OneWire@2.3.5 OneWire-2.3.3.06@2.3.3]
How do I know which library will be used?
How can I clearly define which library shout be used by the Compiler?
"C:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/lwip2/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Temp\\arduino_build_876866/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_191024=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10810 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\cores\\esp8266" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\variants\\d1_mini" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\ESP8266WebServer\\src" "-ID:\\Dokumente\\Arduino\\libraries\\WebSockets\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\Hash\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\Wire" "C:\\Users\\MiKo\\AppData\\Local\\Temp\\arduino_build_876866\\sketch\\THP-Sender_hw069_sw0085.ino.cpp" -o nul
"C:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/lwip2/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\MiKo\\AppData\\Local\\Temp\\arduino_build_876866/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_191024=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10810 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINIPRO\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\cores\\esp8266" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\variants\\d1_mini" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\ESP8266WebServer\\src" "-ID:\\Dokumente\\Arduino\\libraries\\WebSockets\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\Hash\\src" "-IC:\\Users\\MiKo\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.6.1\\libraries\\Wire" "-ID:\\Dokumente\\Arduino\\libraries\\OneWire" "C:\\Users\\MiKo\\AppData\\Local\\Temp\\arduino_build_876866\\sketch\\THP-Sender_hw069_sw0085.ino.cpp" -o nul
