open NUL: The system cannot find the file specified.
I get this error when I try to compile, tried with version 12 and 11
Can't find any useful information about this. I have windows 10
Enable verbose upload and compiler output in preferences, try it again and post the output here
Here it is
Arduino: 1.6.12 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries C:\Users*\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10612 -build-path C:\Users*\AppData\Local\Temp\arduino_build_247191 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users*\AppData\Local\Temp\untitled1034511125.tmp\sketch_oct30a\sketch_oct30a.ino
D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries C:\Users*\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10612 -build-path C:\Users*\AppData\Local\Temp\arduino_build_247191 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users*\AppData\Local\Temp\untitled1034511125.tmp\sketch_oct30a\sketch_oct30a.ino
Using board 'pro' from platform in folder: D:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users*\AppData\Local\Temp\arduino_build_247191\sketch\sketch_oct30a.ino.cpp" -o "nul"
Generating function prototypes...
"D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users*\AppData\Local\Temp\arduino_build_247191\sketch\sketch_oct30a.ino.cpp" -o "C:\Users*\AppData\Local\Temp\arduino_build_247191\preproc\ctags_target_for_gcc_minus_e.cpp"
Error compiling for board Arduino Pro or Pro Mini.
Did you edit out your user name, or is it actually displaying an asterisk there?
I did
