compiling code error: "undefined reference to `analogReference'"
i get the following error code when compiling in the IDE:
Arduino: 1.6.8 (Windows 7), Board: "SparkFun ESP8266 Thing, 80 MHz, 115200"
libraries\LinxESP8266\utility\LinxWiringDevice.cpp.o: In function `LinxWiringDevice::UartWrite(unsigned char, unsigned char, unsigned char*)':
C:\Users\Martin\Documents\Arduino\libraries\LinxESP8266\utility/LinxWiringDevice.cpp:366: undefined reference to `analogReference'
libraries\LinxESP8266\utility\LinxWiringDevice.cpp.o: In function `LinxWiringDevice::AnalogSetRef(unsigned char, unsigned long)':
collect2.exe: error: ld returned 1 exit status
exit status 1
Fehler beim Kompilieren für das Board SparkFun ESP8266 Thing.
Here is the code of LinxWiringDevice.cpp:
**  LINX - Wiring compatible device code
**  For more information see:           www.labviewmakerhub.com/linx
**  For support visit the forums at:    www.labviewmakerhub.com/forums/linx
**  Written By Sam Kristoff
** BSD2 License.
**  Defines
**  Includes
#include "LinxDevice.h"
#include "LinxWiringDevice.h"
#include <C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Arduino.h>
#include <SPI.h>
#include <Wire.h>
#include <EEPROM.h>
#include <Servo.h>
**  Variables
**  Constructors / Destructors
LinxWiringDevice::LinxWiringDevice()
	//LINX API Version
	LinxApiMajor = 1;
	LinxApiMinor = 2;
	LinxApiSubminor = 0;
	//Load User Config Data From Non Volatile Storage
	userId = NonVolatileRead(NVS_USERID) << 8 | NonVolatileRead(NVS_USERID + 1);
**  Functions
void LinxWiringDevice::DelayMs(unsigned long ms)
	delay(ms);
unsigned long LinxWiringDevice::GetMilliSeconds()
	return millis();
unsigned long LinxWiringDevice::GetSeconds()
	return (millis() / 1000);
//--------------------------------------------------------ANALOG-------------------------------------------------------
int LinxWiringDevice::AnalogRead(unsigned char numPins, unsigned char* pins, unsigned char* values)
	unsigned int analogValue = 0;
	unsigned char responseByteOffset = 0;
	unsigned char responseBitsRemaining = 8;
	unsigned char dataBitsRemaining = AiResolution;
	values[responseByteOffset] = 0x00;    //Clear First	Response Byte
	//Loop Over All AI Pins In Command Packet
	for(int i=0; i<numPins; i++)
		analogValue = analogRead(pins[i]);
		//Byte Packet AI Values In Response Packet
		while(dataBitsRemaining > 0)
			*(values+responseByteOffset) |= ( (analogValue>>(AiResolution - dataBitsRemaining)) << (8 - responseBitsRemaining) );
			//*(values+responseByteOffset) = 69;
			if(responseBitsRemaining > dataBitsRemaining)
				//Current Byte Still Has Empty Bits
				responseBitsRemaining -= dataBitsRemaining;
				dataBitsRemaining = 0;
				//Current Byte Full
				dataBitsRemaining = dataBitsRemaining - responseBitsRemaining;
				responseByteOffset++;
				values[responseByteOffset] = 0x00;    //Clear Next Response Byte
	return L_OK;
int LinxWiringDevice::AnalogSetRef(unsigned char mode, unsigned long voltage)
	switch(mode)
		case 0: //Default
			analogReference(DEFAULT);
			AiRefSet = AiRefDefault;
		case 1: //Internal
			if(NumAiRefIntVals > 0)
				//Check If Internal AI Ref Value Is Supported
				for(int i=0; i<NumAiRefIntVals; i++)
					//Voltage Is Supported
					if(AiRefIntVals[i] == voltage)
						analogReference(AiRefCodes[i]);
						AiRefSet = voltage;
						return L_OK;
				//Didn't Find Voltage
				return LANALOG_REF_VAL_ERROR;
				//No Internal Voltages, So Internal Mode Not Supported
				return LANALOG_REF_MODE_ERROR;
		case 2: //External
			if(voltage >= AiRefExtMin && voltage <= AiRefExtMax)
				analogReference(EXTERNAL);
				AiRefSet = voltage;
				return L_OK;
		default:
	return L_OK;
its not the full code it was to long. I attached the file instead. By Google I know so far that analogReference has something to do with Arduino.h so I tried to add the full path and tried to copy it to the My Documents/Arduino folder. I am new to Arduino and hope its not a simple question
LinxWiringDevice.cpp (17.2 KB)
Not all boards support analogReference(). Does yours?
