i have written a sketch for the receiver end of a remote control. i have completed the transmitter and it is compiled but i cant complie the receiver i am haveing error code after error code but im new to this and dont know what they mean or how to fix them
this is the current error message:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from sketch_may29b.ino:8:0:
C:\Program Files (x86)\Arduino\libraries\ServoTimer2/ServoTimer2.h:41:17: error: conflicting declaration 'typedef uint8_t boolean'
typedef uint8_t boolean;
In file included from C:\Program Files (x86)\Arduino\libraries\VirtualWire/VirtualWire.h:146:0,
from sketch_may29b.ino:5:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
Error compiling.
enabled in File > Preferences.
this is the code;
// RECIEVER CODE
//NOTE :- THIS CODE IS USED WHEN CONTROLLING THE ROBOT VIA THE BREADBORD REMOTE
#include <VirtualWire.h>
// this sketch cycles three servos at different rates
#include <ServoTimer2.h> // the servo library
// define the pins for the servos
#define rollPin 2
ServoTimer2 servoRoll; // declare variables for up to eight servos
Serial.begin(9600); // Debugging only
Serial.println("setup");
servoRoll.attach(rollPin); // attach a pin to the servos and they will start pulsing
// Initialise the IO and ISR
vw_setup(2000); // Bits per sec
vw_set_rx_pin(2); //Rx Data pin to Digital Pin 2
vw_rx_start(); // Start the receiver PLL running
// this function just increments a value until it reaches a maximum
int incPulse(int val, int inc){
if( val + inc > 2000 )
return 1000 ;
return val + inc;
}//close setup
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
for (i = 0; i < buflen; i++)
Serial.print(buf[i]);//print received command
if(buf[i] == '1')//if button 1 is pressed.... i.e.forward buton
servoRoll.write(0);
delay(10);
Serial.print(" ");
Serial.println("");
digitalWrite(13, false);
}//close if
}//close loop
