Compiling error: 'bye dns[]' declared as different kind of symbol
I am trying to build an automated watering system for my lucky bamboo plant. I am playing around with the original source code and have ran into a peculiar error. I have done quite a bit of googling and have come across a few discussions that suggest it may be an IDE related error.
Syntax reads:
sketch:51: error: 'byte dns[]' redeclared as different kind of symbol
\arduino-1.0.2-windows\arduino-1.0.2\libraries\Ethernet/Dhcp.h:64: error: previous decleration of '<anonymous enum> dns'
I tried running this code in IDE versions 1.0, 1.0.1, and 1.0.2 - the two earlier versions come out with a different kind of error. I’ve tried replacing the Ethernet library on 1.0.2 with an earlier version but that did not work. So I am sure there’s gotta be something wrong with the code. Any ideas?
#include <Ethernet.h>
#include <SPI.h>
#include <aJSON.h>
#include <SimpleTimer.h>
  Pin configuration
int moistureInputPin = 0;
int moistureOutputPinTop = 2;
int moistureOutputPinBottom = 3;
int valveOutputPin = 9;
  How often to check the plant needs watering
  and to send readings to the server
unsigned long pollMillis = 60000; // 1 min
  How dry the soil should get before watering.
  (Max) 1023 = Drier than the Atacama Desert
        400  = Damp
  (Min) 0    = Have you used copper instead of soil?
// Watered value = 75-76
int waterAtMoisture = 1023 - 400;
  When the soil gets dry enough to warrant a watering,
  how many millis to open the valve for.
int waterForMillis = 3500;
  Cube Server IP
byte server[] = { 23, 21, 244, 111 };
  Local IP settings
byte mac[] = { 0x6E, 0x58, 0xB8, 0x2F, 0xF7, 0x89 };
byte ip[] = { 192, 168, 2, 20 };
byte subnet[] = { 255, 255, 255, 0 };
byte gateway[] = { 192, 168, 2, 1 };
byte dns[] = { 8, 8, 8, 8 };
EthernetClient client;
SimpleTimer timer;
  pinMode(moistureOutputPinTop,OUTPUT);
  pinMode(moistureOutputPinBottom,OUTPUT);
  pinMode(valveOutputPin, OUTPUT);
  Ethernet.begin(mac, ip, dns, gateway, subnet);
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
  timer.setInterval(pollMillis, poll);
  timer.run();
  Main function that is run once per poll
void poll() {
  Serial.print("Polling... ");
  //Using int for watered rather than boolean
  //as the cube server doesn't report metrics
  //on booleans very well
  int moisture = getSoilMoisture();
  int watered = 0;
  Serial.println(moisture);
  if(moisture > waterAtMoisture) {
    waterThePlant();
    watered = 1;
  postToServer(moisture, watered);
  Drives a current though two digital pins
  and reads the resistance through the
  analogue pin
int getSoilMoisture(){
  //Drive a current through the divider in one direction
  digitalWrite(moistureOutputPinTop,HIGH);
  digitalWrite(moistureOutputPinBottom,LOW);
  //Take a reading
  int reading = analogRead(moistureInputPin);
  //Reverse the current
  digitalWrite(moistureOutputPinTop,LOW);
  digitalWrite(moistureOutputPinBottom,HIGH);
  //Stop the current
  return reading;
  Gives the plant a two second blast of water
void waterThePlant() {
  digitalWrite(valveOutputPin, HIGH);
  delay(waterForMillis);
  digitalWrite(valveOutputPin, LOW);
  Posts a JSON document to the cube server
  (see http://square.github.com/cube/)
  The JSON document describes the soil
  moisture and whether the plant was
  watered.
    "data": {
      "moisture": 600,
      "watered": 0
  Using int rather than boolean for 'watered'
  as cube metric querying is limited with booleans
void postToServer(int moisture, int watered) {
  while(!client.connected()) {
    client.stop();
    Serial.println("Connecting...");
    if (client.connect(server, 80)) {
      Serial.println("Connected");
      Serial.println("Connection failed");
      delay(5000);
  aJsonObject* rootJson = aJson.createArray();
  aJsonObject* event = aJson.createObject();
  aJson.addItemToArray(rootJson, event);
  aJson.addStringToObject(event, "type", "moisture");
  aJsonObject* data = aJson.createObject();
  aJson.addItemToObject(event, "data", data);
  aJson.addNumberToObject(data, "moisture", moisture);
  aJson.addNumberToObject(data, "watered", watered);
  char* moistureJsonStr = aJson.print(rootJson);
  client.println("POST /1.0/event/put HTTP/1.0");
  client.println("Content-Length: " + String(strlen(moistureJsonStr)));
  client.println("Connection: keep-alive");
  client.println();
  client.println(moistureJsonStr);
I should also mention that I tried changing 'dns' to another name, but the (aJson) library I am using starts generating multiple other errors.
I would assume dns is delcared already in <Ethernet.h>, and it may not be a type byte. You should research that and check some examples rather than randomly “hacking” or guessing/assuming. :wink:
I’ve forgotten the exact syntax for initializing an already declared array, but you might be able to simply drop “byte” from that statement. i.e. dns[] = { 8, 8, 8, 8 };
Thank you for your input!
I am a complete newbie when it comes to programming…so this is pretty difficult at this stage of the game hehe
What do I need to look for to tell if dns is defined in the Ethernet.h file? If I change or remove ‘byte,’ IDE gives the declaration of array error.
This is my Ethernet.h
#ifndef ethernet_h
#define ethernet_h
#include <inttypes.h>
//#include "w5100.h"
#include "IPAddress.h"
#include "EthernetClient.h"
#include "EthernetServer.h"
#include "Dhcp.h"
#define MAX_SOCK_NUM 4
class EthernetClass {
private:
  IPAddress _dnsServerAddress;
  DhcpClass* _dhcp;
public:
  static uint8_t _state[MAX_SOCK_NUM];
  static uint16_t _server_port[MAX_SOCK_NUM];
  // Initialise the Ethernet shield to use the provided MAC address and gain the rest of the
  // configuration through DHCP.
  // Returns 0 if the DHCP configuration failed, and 1 if it succeeded
  int begin(uint8_t *mac_address);
  void begin(uint8_t *mac_address, IPAddress local_ip);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway, IPAddress subnet);
  int maintain();
  IPAddress localIP();
  IPAddress subnetMask();
  IPAddress gatewayIP();
  IPAddress dnsServerIP();
  friend class EthernetClient;
  friend class EthernetServer;
extern EthernetClass Ethernet;
#endif
What other name? What other errors? The name "dns" is local to your sketch. You should be able to change it to anything you want.
