Compiling Error "collect2.exe: error: ld returned 1 exit status"
I am a newbie so bare with me.
Compiling System OS: Windows 10
Board: Arduino Mega 2560
Error Message Snippet:
:(.text.startup+0x261a): undefined reference to `UTFT::print(char*, int, int, int)’
:(.text.startup+0x2646): undefined reference to `UTFT::setColor(unsigned char, unsigned char, unsigned char)’
:(.text.startup+0x265e): undefined reference to `UTFT::print(char*, int, int, int)’
Not sure where to start looking for this issue. Any help where to start would be greatly appreciated!
You can start by reading the sticky post at the top of the forum which explains how to best post a question that includes your code so we can all see it and possibly help. Also, posting the entire error message would be useful as often times the first error (at the top of the window) is the true problem and following errors are just a result.
It appears you don't have your TFT library properly included since the linker is complaining about missing function references.
<artificial>:(.text.startup+0x265e): undefined reference to `UTFT::print(char*, int, int, int)'
This kind of linker (ld) error generally means that the functions were declared (probably in a library .h file) but they were not actually defined (usually done in a library .cpp file). This is probably because the library did not get installed correctly and completely.
