Compiling error: error: stray '\' in program
I don't see any "\" in this sketch. But Arduino says there is. What am I doing wrong?
// Which pins are connected to which LED
 const byte greenLED = 8 ;
 const byte redLED = 10 ;
// Time periods of blinks in milliseconds (1000 milliseconds to a second).
 // Time variable and constants are always unsigned long
 const unsigned long greenLEDinterval = 555UL;
 const unsigned long redLEDinterval = 1234UL;
// Variable holding the timer value so far. One for each “Timer”
 unsigned long greenLEDtimer = 0 ;
 unsigned long redLEDtimer = 0 ;
// Variable to know what the current LED state is
 int greenLEDState = LOW ;
 int redLEDState = LOW ;
 pinMode (greenLED,OUTPUT) ;
 pinMode (redLED,OUTPUT) ;
 greenLEDtimer = millis () ;
 redLEDtimer = millis () ;
if ((millis() – greenLEDtimer) gt= greenLEDinterval) {
 if (greenLEDState == LOW)
 greenLEDState = HIGH ;
 // Write new state
 digitalWrite (greenLED, greenLEDState ) ;
 // Reset timer
// The other LED is controlled the same way. Repeat for more LEDs
if ( (millis () – redLEDtimer) gt= redLEDinterval ) {
 if (redLEDState == LOW)
 redLEDState = HIGH ;
 redLEDState = LOW ;
 digitalWrite (redLED, redLEDState ) ;
What's the gt= ...?
would be only one line of code as
 greenLEDState = !greenLEDState;
Your long minuses, -, are becoming unicode and breaking stuff. Replace them with a normal dash/minus. This is what the compiler sees:
#line 1 "sketch_jun11a.ino"
 #include "Arduino.h"
void setup();
void loop();
void loop();
#line 1
// Variable holding the timer value so far. One for each \u201cTimer\u201d
if ((millis() \u2013 greenLEDtimer) gt= greenLEDinterval) {
 // Write new state
 // Reset timer
if ( (millis () \u2013 redLEDtimer) gt= redLEDinterval ) {
 redLEDState = LOW ;
What's a "long minus" ?
Looks normal on my screen.
EDIT: I dropped his code into the IDE and it did break on the "long minus" (and the gt= of course), there's also a missing } at the end.
Rob
In typesetting there are multiple lengths of dash used for different purposes.
The normal "hyphen" on your keyboard is used as a minus sign.
You then also have the "em dash" and the "en dash" which are both longer than a standard keyboard minus sign.
minus: - en dash: – em dash: —
If you use the wrong one in a program it throws a wobbly.
I see, I'm familiar with them because I've done a lot of desk top publishing, but how on earth did they wind up in a program, did he write it in a word processor instead of a text editor?
Rob
Probably cut-and-pasted from a web site.
Thanks guys, i got it to compile.
Arduino: 1.5.6-r2 (Windows XP), Board: "Arduino Uno"
_2014:29: error: stray '\' in program _2014:24: error: expected initializer before 'code_table' _2014.ino: In function 'void send(unsigned char)': _2014:29: error: expected initializer before 'uff0ctemp' _2014:30: error: 'i' was not declared in this scope _2014:32: error: 'P2' was not declared in this scope _2014:32: error: expected primary-expression before '=' token _2014:33: error: 'temp' was not declared in this scope _2014:35: error: expected primary-expression before '=' token _2014:36: error: 'else' without a previous 'if' _2014:37: error: expected primary-expression before '=' token _2014:39: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Write(unsigned char, unsigned char)': _2014:45: error: 'P2' was not declared in this scope _2014:45: error: expected primary-expression before '=' token _2014:48: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Write_1(unsigned char, unsigned char)': _2014:53: error: 'P2' was not declared in this scope _2014:53: error: expected primary-expression before '=' token _2014:54: error: 'sent' was not declared in this scope _2014:56: error: expected primary-expression before '=' token _2014:59: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Init()': _2014:113: error: 'P2' was not declared in this scope _2014:113: error: expected primary-expression before '=' token _2014:114: error: expected primary-expression before '=' token _2014:115: error: expected primary-expression before '=' token
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
I don't know how to fix it. Please help me !!!!`
What is the "it" you cannot fix?
void send (uchar datain)
char I?temp;
for (i=8; i>0; i–)
CLK=0;
temp=datain&0x80;
if (temp==0x80)
DATA=1;
DATA=0;
datain<<=1;
CLK=1;
void MAX7219_Write (uchar add1, uchar dat1)
CS=0;
send(add1);
send(dat1);
CS=1;
void MAX7219_Write_1(uchar add2,uchar dat2)
CS=0;
sent(add2);
sent(dat2);
CLK=1;
sent(REG_NO_OP);
sent(0x00);
CS=1;
Whee is "setup()"? Where is "loop()"? Where are the code tags?
#define uchar unsigned char
#define REG_NO_OP 0x00 // ??? register
#define DIG_1 0x01 // ???1 register
#define DIG_2 0x02 // ???2 register
#define DIG_3 0x03 // ???3 register
#define DIG_4 0x04 // ???4 register
#define DIG_5 0x05 // ???5 register
#define DIG_6 0x06 // ???6 register
#define DIG_7 0x07 // ???7 register
#define DIG_8 0x08 // ???8 register
#define REG_DECODE 0x09 // ??? register
#define REG_INTENSITY 0x0a // ??? register
#define REG_SCAN_LIMIT 0x0b // ??? register
#define REG_SHUTDOWN 0x0c // ??“shutdown”?? register
#define REG_DISPLAY_TEST 0x0f // ??“display test”?? register
#define INTENSITY_MIN 0x00 // ???
#define INTENSITY_MAX 0x0f // ???
#define DATA P2^3; //??P3_5??MAX7219 DATA??
#define CLK P2^5; //??P3_4??MAX7219 CLK ??
#define CS P2^4; //??P3_3??MAX7219 CS ??
uchar code code_table[10]=
{0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x7b};
char I?temp;
for (i=8; i>0; i–)
CLK=0; // CLK ??
temp=datain&0x80;
if (temp==0x80) // ???
DATA=1; // ??“1”
else // ?
DATA=0; // ??“0”
datain<<=1; //datain???0x80???
CLK=1; // CLK ??
void MAX7219_Write (uchar add1, uchar dat1) //???MAX7219???
CS=0; // CS??? MAX7219
send(add1); // ?register number ? MAX7219
send(dat1); // ? data ? MAX7219
CS=1; // ??CS???16???
void MAX7219_Write_1(uchar add2,uchar dat2) //???MAX7219???
CS=0;
sent(add2);
sent(dat2);
CLK=1; // ?16.5???MAX7219?DOUT???
sent(REG_NO_OP); //???MAX7219???
sent(0x00);
CS=1;
void MAX7219_DisplayChar (char digit, char character)
{ MAX7219_Write(digit, character);
void MAX7219_Clear ()
uchar i;
for (i=0; i < 8; i++)
MAX7219_Write(i, 0x00); // ???MAX7219???
void MAX7219_Clear_1()
uchar i;
for(i=1;i<=8;i++)
MAX7219_Write_1(i,0x00); //???MAX7219???
void MAX7219_SetBrightness (char brightness)
brightness &= 0x0f; // ???
MAX7219_Write(REG_INTENSITY, brightness); // ???
MAX7219_Write_1(REG_INTENSITY, brightness); //???MAX7219
void MAX7219_DisplayTestStart ()
MAX7219_Write(REG_DISPLAY_TEST, 1); //?MAX7219? test ??
MAX7219_Write_1(REG_DISPLAY_TEST, 1); //???MAX7219
void MAX7219_DisplayTestStop ()
MAX7219_Write(REG_DISPLAY_TEST, 0); //? MAX7219???
MAX7219_Write_1(REG_DISPLAY_TEST, 0); //???MAX7219
void MAX7219_ShutdownStart ()
MAX7219_Write(REG_SHUTDOWN, 0); //?MAX7219? shutdown ??
MAX7219_Write_1(REG_SHUTDOWN, 0); //???MAX7219
void MAX7219_ShutdownStop ()
MAX7219_Write(REG_SHUTDOWN, 1); //?MAX7219???
MAX7219_Write_1(REG_SHUTDOWN, 1); //???MAX7219
void MAX7219_Init ()
DATA=1; // ?DATA?1
CLK=1; // ?CLK ?1
CS=1; // ?CS ?1
MAX7219_Write(REG_SCAN_LIMIT, 7); // ???
MAX7219_Write_1(REG_SCAN_LIMIT, 7); //???MAX7219
MAX7219_Write(REG_DECODE, 0x00); // ???
MAX7219_Write_1(REG_DECODE, 0x00); //???MAX7219
MAX7219_ShutdownStop(); //?MAX7219??? (?shutdown??)
MAX7219_DisplayTestStop(); // ?MAX7219??? (?test??)
MAX7219_Clear(); // ???
MAX7219_Clear_1(); //???MAX7219
MAX7219_SetBrightness(INTENSITY_MAX); // ???
do not need to care about the chinese!!!thx
I don't care about the Chinese, I do care about the missing code tags.
char I?temp;
That ain't no comma.
#define DATA P2^3;
Two things wrong here - what is P2, and what is that semicolon doing there?
_2014:29: error: stray '\' in program _2014:24: error: expected initializer before 'code_table' _2014.ino: In function 'void send(unsigned char)': _2014:29: error: expected unqualified-id before '=' token _2014:30: error: 'i' was not declared in this scope _2014:32: error: 'P2' was not declared in this scope _2014:32: error: expected primary-expression before '=' token _2014:33: error: 'temp' was not declared in this scope _2014:35: error: expected primary-expression before '=' token _2014:36: error: 'else' without a previous 'if' _2014:37: error: expected primary-expression before '=' token _2014:39: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Write(unsigned char, unsigned char)': _2014:45: error: 'P2' was not declared in this scope _2014:45: error: expected primary-expression before '=' token _2014:48: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Write_1(unsigned char, unsigned char)': _2014:53: error: 'P2' was not declared in this scope _2014:53: error: expected primary-expression before '=' token _2014:54: error: 'sent' was not declared in this scope _2014:56: error: expected primary-expression before '=' token _2014:59: error: expected primary-expression before '=' token _2014.ino: In function 'void MAX7219_Init()': _2014:113: error: 'P2' was not declared in this scope _2014:113: error: expected primary-expression before '=' token _2014:114: error: expected primary-expression before '=' token _2014:115: error: expected primary-expression before '=' token
Yes, you've shown us the error messages, but where is the corrected code (inside code tags this time) ?
no,I don't know the correct answer
No, me neither. Good luck.
thank you for your teaching,good night
