Your long minuses, -, are becoming unicode and breaking stuff. Replace them with a normal dash/minus. This is what the compiler sees:
#line 1 "sketch_jun11a.ino"
// Which pins are connected to which LED
#include "Arduino.h"
void setup();
void loop();
void loop();
#line 1
const byte greenLED = 8 ;
const byte redLED = 10 ;
// Time periods of blinks in milliseconds (1000 milliseconds to a second).
// Time variable and constants are always unsigned long
const unsigned long greenLEDinterval = 555UL;
const unsigned long redLEDinterval = 1234UL;
// Variable holding the timer value so far. One for each \u201cTimer\u201d
unsigned long greenLEDtimer = 0 ;
unsigned long redLEDtimer = 0 ;
// Variable to know what the current LED state is
int greenLEDState = LOW ;
int redLEDState = LOW ;
pinMode (greenLED,OUTPUT) ;
pinMode (redLED,OUTPUT) ;
greenLEDtimer = millis () ;
redLEDtimer = millis () ;
if ((millis() \u2013 greenLEDtimer) gt= greenLEDinterval) {
if (greenLEDState == LOW)
greenLEDState = HIGH ;
// Write new state
digitalWrite (greenLED, greenLEDState ) ;
// Reset timer
// The other LED is controlled the same way. Repeat for more LEDs
if ( (millis () \u2013 redLEDtimer) gt= redLEDinterval ) {
if (redLEDState == LOW)
redLEDState = HIGH ;
redLEDState = LOW ;
digitalWrite (redLED, redLEDState ) ;
